Question about Oster 12-Bottle Wine Cellar - Black
Taking a long time to cool down and when does the fan kick on
Taking along time to cool down and when does the fan kick on?
The evaporater fan should be opperating when the compressor is runnig ,as well as the condenser fan if you have one
Posted on May 20, 2009
I have a airwell GC-30RCC when put on heat the fan on the indoor unit wont kick in it works fine on cooling and plain fan mode but not on heat mode the red fan light is on too
How do you get it to kick in ?.Fid you spin it by hand ,if that's what you did and fan runs then you have a bad capicator. If fan runs fine in cooling and not in heat then you have a bad board
Jun 01, 2017 | Heating & Cooling
When taking off sometimes it sounds like a fan kicks on it is loud and through three gears before it stopped. It happens from time to time. Sound like it is under the hood but it seems to lag on the...
It's possible that your cooling fan on the front of the engine is going or gone bad it has a clucth on it that can sieze up and cause this problem it can also cause a slight vibration at higher RPM's .Open the hood with the engine off and try to spin the engines fan by hand if it turn hard its bad aloso try to wiggle the fan forward and back if their is play in the clutch bearing it's bad.
May 10, 2011 | 2007 Mercury Mountaineer
My durango heat gauge in height plase ---when i drive my car after the first 20 k m the heat guge rising near the red line then after 30 secnd com down
either the thermostat is on its way out or the heater fan is taking to long to kick in, leave the car stood running and see if the fan kicks in, in good time.
Jan 20, 2010 | 2005 Dodge Durango
F2E1 on stove after cooking on temps of 425-450 for 20mins stove shuts off and can not restart even if power is turned off and then started. must wait for stove to cool down and then press cancel and stove...
Is the background cooling fan running? Also, look under the oven and if possible take off the kick panel and clean all the rubbish out to ensure the cooling fan can circulate air round. As a check, when you turn any part of the oven on ( Main/top/grill) the cooling fan will run and you will feel a cool draft of air coming out of the gap just above the top of the main oven door. If the fan is not running, this will cause the unit to overheat and the overheat thermostats to kick in, turning the oven off.
If the fan is not running, you will have to take the whole unit out to gain access to the back panel.
Nov 28, 2009 | Stoves 720EF Electric Double Oven
My pontiac vibe Ac has stopped working..it started taking a long time to kick in ...now it only kicks on for a short time if im lucky.
the clutch on the ac compressor is going out.
replace the ac compressor (when you push the a/c button it should imidiately kick the compressor on).
also check the connection on the compressor, along with the fuses.
Aug 14, 2009 | 1995 Jeep Grand Cherokee
Compressor starts then shuts down like head pressure building to high
Make sure that your condenser fan is working. If your unit is water cooled make sure you have water flow.
Nov 05, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Air conditioning liberty 2002
I had the same problem. The cooling fan relay blew, along eith the harness. Chec and see if the cooling fan kicks on and cycles after a few minutes of running with the a/c on. If it doesn't, it is probably the relay not kicking it on. Cost me about $100.00 to do myself, ordered the replacement relay from the dealer, they had to look it up and it was replaced by a new version. Also, had to drill a new hole to mount, it came with a template. Was time consuming on a real hot day, but I did it myself and saved alot. If you are not afraid of trying, and have the time, it can be done.
Jul 30, 2008 | 2002 Jeep Liberty
Carrier Air Conditioner/Model # 38TG030300
Hmm It's passable that the condenser fan motor is not spinning at speed or is running for a period of time and over heating and the Condenser fan motors internal overload protection trips and takes it of line shortly thereafter, of course, the compressor internal overload trips and takes it of line. Spraying with the water hose sped up the cool down on the internal overloads but I'm afraid it probably didn't do much to help the original problem. You could try replacing the Fan condensing motor capacitor-(it's listed on the side of the motor if the capacitor cant be read) and oiling the motor if it has oil ports (2 small plugs located along the perimeter of each end of the motor). If the motor can be oiled and you replace the capacitor theres a fair chance you might get by another year without replacing the condenser fan motor. Charged capacitors pack a nasty jolt so be careful, hope this was helpful, GL!
P.S. If it is the cond. fan motor and you replace it be sure you get a sealed outdoor rated cond. fan motor and the appropriate rain guards are installed.
Jun 12, 2008 | Heating & Cooling
Cooling fan and heatsink.
use t6 star bit take it all apart add new greese to it also to cool it down
Jan 25, 2008 | HP Pavilion Ze4805us Notebook
Oster 12-Bottle Wine Cellar - Black Logo
144 people viewed this question
Top Oster Furniture Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
jasbo
jasbo
Charles T Nevin
Charles T Nevin
Are you an Oster Furniture Expert? Answer questions, earn points and help others
