Question about AEG U3100-4 Electric Double Oven
Service manual for AEG D8800-5-M oven
Programmed PSU PCB assembly, AEG part No 3306722103, 3W wire-wound resistor R12 has gone open circuit. Resistor had overheated and value marking is not visible. I need to know the resistance value so that I can replace it. Thanks, kind regards, Brian.
2 Suggested Answers
  • 183 Answers
SOURCE: Oven Light Assembly wires
does not matter.
Posted on Jan 23, 2012
Aeg manual
In order to help you turn on the oven you will need the oven manual. But as you have not provided the model number it is hard to advise which manual applies. You may want to visit this website and type the model number after you check it from the plate on the oven door. (side). AEG Service Support User Manuals
OR
if in Australia
Aug 21, 2014 | AEG Ovens
New World(Stoves) Twinline Gas Oven About 9-10 yrs old
The control board should probably be replaced
Apr 01, 2008 | Ovens
My AEG oven needs a PC board, but I cannot find where I can buy one. Can anyone help pleases?
PCB for D5701-4-M is obsolete. I certainly could not find one. Alternative is repair. I used QER Ltd via ebay. Involves removing and identifying part number of board and ordering repair via ebay listing. The trick is to find the correct listing for your board number as it will not be listed under AEG D5701-4-M. For instance, my D5701-4-M, part no. 944171390 (found on plate in bottom right hand corner of main oven) uses board NPPUGN104. It was listed in ebay under Repair pcb / module Zanussi Z0B1060X. Took two attempts to fix, but so far so good.
Nov 19, 2012 | AEG D5701-4 Electric Double Oven
does not matter.
Jan 22, 2012 | AEG Ovens
Aeg b5741-14 oven has code f5 -what does this mean?
Here is a list of oven error codes for your model Kenmore oven.
  1. F0 indicates a Stuck key pad.
  2. F1 and F7 may mean relay is turned on.
  3. F2 indicates that the oven is over temperature in one of the following modes within either cooking or cleaning mode of operation. The control is sensing over 615 degrees with the door lock circuit in the unlock mode. Control senses oven temperature above 915 degrees with the door in the locked mode.
  4. F3 and F4 indicates an open or shorted oven sensor or sensor circuit.
  5. F5 indicates a loss of relay drive circuit.
  6. FF indicates a loss of door motor safety switch.
  7. FC indicates a door lock circuit problem.
If the display of your control is flashing "F" followed by a number or letter its a range malfunction. Press the clear/off pad. Let the range cool for 1 hour and place the range back into operation.
If the problem repeats, call for service.
Jul 16, 2011 | AEG B5741-4 Electric Single Oven
My Stoves 720EF oven blows the trip when cooling fan stops
The fan timer printed circuit board controls the cooling fan and there is also a resistor on the terminal block of the cooling fan. One or both of these could be suspect. If the fan still runs, then the resistor hasn't gone open circuit and is still providing continuity. The only way to prove out the circuit board would be to change it, but that could be expensive especially if it doesn't cure the problem.
Aug 23, 2010 | Stoves 720EF Electric Double Oven
Oven tripped fuse and will not turn on
Hi!
If the oven is not working, you need to check the fuse on the main PCB - If the fuse is good check for continuity between the fuse and L3 (drive motor terminal) - If this circuit is open the PCB is bad and must be replaced. When re-assembling please be sure all the wiring is correct.
For your reference, you can check the following link---
Dacor Epicure Electric Oven Technical Manual
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 31, 2009 | Dacor ECD230 Epicure Electric Double Oven
I have an AEG B6139 electric oven and the interior light and fan comes on but the oven will not heat up despite putting the setting on high. Next to the dial for the interior light and fan a small red...
Hi I am Vortash it sounds to me as if the oven element has blown you need to have it tested by an engineer .. he will check for continuity .. if it is open circuit then you will need to replace it .
I would hev thought that if the fuse had gone the oven would have no light or functions of any kind as the power would be off .. unless this model has an extra fuse fopr the element alone doubtful however it does have a heat sensor cut off above the oven that cuts off the element from the supply .. If you have no manual for this unit you will find one free to download from http://www.safemanuals.com .. regards Vortash
Apr 29, 2009 | AEG B3101-4 Electric Single Oven
Maytag65300ddS My burners wont turn on,. Clock
Sounds like an open connection between the supply circuit and the burners. Could be corroded, burned, broken, or just loose. Also could be a bad/cracked resistor in the same circuit.
I suggest a service call.
Apr 21, 2009 | Maytag MEW6530D Electric Single Oven
AEG U3100-4 Electric Double Oven Logo
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
