Question about Whirlpool ED2FHEXN Side by Side Refrigerator
5 cube icemaker not working.
Whirlpool Model#ED2FHAXSB00  with the 5 cube in door ice dispenser.
I have already replaced the module and the optics. Still no ice ! ! !
                                        HELP ! ! ! !
                                              Thanks, John
  • dnommah Oct 20, 2007
    Thanks for the help, but i found the problem ! ! !  I forgot to use "Basics 101" ! ! !   The white (nuetral) wire that plugs into the module wire connector at the module had slipped out of the connector. It looked correct, but was not fully seated into the connector, so it was not contacting the module.  When I fully seated the white wire into the connector at the module, everything started working ! ! !
                  Always check the obvious "Basics" first ! ! !
                                          Thanks Again ! ! !
  • 447 Answers
Hey fridgetech saw your comment here on the Modules.
This is the first ive heard of the tstat being why the module breaks. Im very interested ive recently had a recall on one where i replaced the module one month ago and the cust said recently it didnt make ice for days. Also I convert the standard service ice maker to fit the IDIMs. this means swapping out the stripper which requires splitting the housing from the mold, i did notice recently that the tstat was changed to a different style. I also dont put any more alumilastic on it it still has plenty on from the factory and i put put it back together. Do you see a problem with doing this?? Thanks for the help
Posted on Oct 19, 2007
  • 473 Answers
First make sure the icemaker fill tube isn't frozen.  Was the module broken?  If so then you need to replace the icemaker thermostat (bi metal) also.  A bad thermostat is usually what causes the module to break.  The part # is 627986 and will need alumlastic to put between thermostat and mold.  Alumilastic part # is 542369.  You can get this at http://www3.sears.com/.  You can also use silicone grease in place of alumilastic.  You need this to make a good contact between the thermostat and mold for temp. sensing.  Let me know if you have any other questions.
Posted on Oct 18, 2007
  • Craig Shelton
    Craig Shelton Oct 20, 2007
    To the dr,
    What happens is the thermostat isn't opening and closing at the right times and turning the heater off too soon in the cycle.  This puts a lot of stress on the ejector bar and breaks the module.  Actually I don't use alumilastic either, I use some food grade silicone grease.  This must be used to make a good contact with the mold so the tstat can sense the proper temp and not lead to the module breaking.
Whirlpool model # ed5vhexvq1 side by side ...ice maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
Icemaker is not making ice cubes. fridge is 3 months old.
Well if your ice cube bucket is on the freezer door it self then it could be anything from the optics system to a bad icemaker to a water valve issue...if its located on the side freezer wall. the water valve could be bad or the i/m module/icemaker
Jan 22, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Whirlpool ice maker ,no harvest?
Hi, The optics almost never go in those unit's, the problem is in the icemaker module itself. If you can jump it thru a fill and then no advancing thru to harvest afterward ( provided your freezer is below freezing ) it's the module. You can either replace just the head/module or the entire icemaker. For the difference of only about $50 I always replace the complete assembly. The most common one being about $150 complete, # 2198597 and this should be the one for your fridge since you mentioned the optic component's. Hope that help's. Thanks for choosing "fixya" for your fridge inquiry. Please take a moment and rate this solution if indeed it solves your problem. Thanks again and good luck. Macmarkus :)
Mar 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
No ice being made
Pour about 1/2 cup of water into icemaker . If it dumps the cubes but does not fill with water , replace the water valve ( the part that the line from the wall connects to on the fridge ) . If the icemaker does not dump the cubes , replace the icemaker . Be sure the coils are clean of dust , lint , etc... as this will not let the freezer get cold enough for the icemaker to dump .
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker stopped working
you likely need a new icemaker (part # 2198597) i would visit the following website to help determine this fact.  http://fixitnow.com/sbrvrs/icemakers.htm
Feb 05, 2009 | Whirlpool GD5SHAX Side by Side...
Whirlpool icemaker
Your unit has infered sensors on the frezzer left and right walls. There is a diagnostic test sheet brown in color in your kick plate.All you have to do is open frezzer door look on the right sensor it should blink twice followed by a 1-2 sec delay,if that is good press in flapper door on right sensor do not block path of infered beam you will not see a beam its invisable.Once you hold in flapper on right sensor the led should be solid.If solid optics are good if not solid led replace optic sensors
Jan 25, 2009 | Whirlpool ED5SHAXM Side by Side...
Icemaker doesn't make ice
If there are ice cubes in the icemaker sitting there waiting to be dumped then the icemaker is bad. If the icemaker is dry then it could be the water valve is bad.
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
The icemaker stop working on my Whirlpool side by side frig
If there are ice cubes setting in the icemake waiting to be dumped then the icemaker is bad. If the icemake is dry then the water valve is bad. You have one water valve with two solenoids. One works water in the door and the other sends water to the icemaker.
Dec 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
When you open the freezer door the light should be blinking. When you hold the flipper door shut (on the left hand side) without blocking the beam, the light should stay on solid. If all of this happens then the optics are o.k. If optics are ok then you most likely have a broken motor module on the icemaker and should replace the icemaker thermostat along with it. A bad icemaker thermostat will lead to the module breaking. If you not sure how to replace these parts then I would just replace the whole icemaker. That would be easiest and usually not much more expensive.
Nov 07, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
493 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
