Question about Sony Xplod CD Player w/MP3 Playback CDX-GT50W
No power to front panel but have power to main unit.
I have a cd player brand new for my new car which has no unit. I have plugged it all in and get power to the unit. when I put the front panel on there is no power to the front panel to display anything. the ignition is on and it will eject a cd but nothing on the front panel. I thought it may be a problem with the actual unit so tried an old unit I had and get the same from that one. any help would be much appreciated.
    Problem Solver:
  • 11 Answers
You Have constant power (yellow wire) but your Acc wire or switched power wire (RED WIRE) does not have power. Check the connection of this wire. You most likely have a blown fuse in your vehicles fuse panel.
Posted on May 20, 2009
My American Audio MCD-510 CD Player has a buzzing sound with and without audio plugs installed. Do I need to replace the power unit. If so where can I buy this in the Glasgow area
It will be best to contact any service technician at your area. This is an advanced unit, having sophisticated circuit and fittings. The buzzer sounds indicates something wrong with its main system control circuit. Even an experienced service technician too might take some time to locate the faulty section, and damaged components. Never plug the instrument to AC mains, till this fault is rectified. It might make things more worse. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
I do recall that I've seen something about this brand by the above linked site. Please try by type in the brand name of your device at its search box.
Oct 21, 2014 | American Audio MCD-510 Dual MP3 - CD...
I have a RX-S70, G model & there is no light, no indications on the front panel unit !!!
Check and replace damaged component/s at it main power regulator section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
Jun 02, 2014 | Yamaha CDC-697 - CD changer 5-Disc CD...
Sony DVP-S7000 DVD player does not respond to front panel buttons or the remote control
The only possible solution and it is a long shot, unplug unit from wall receptical, now press and hold power for 60 seconds, this will drain any residual voltage and reset the microprocessor in hopes it will work. If this fails I recommend the sony technician.
Jul 17, 2012 | Sony DVP-S7000 DVD Player
Brand new Dell Vostro 220S won't power up
Depending where you are check that the voltage is correct , it should show 110 for US and 220 for EU and other countries
Ensure that the processor power cable is securely connected to the system
board power connector (see your Service Manual at support.dell.com).
•Ensure that the main power cable and the front panel cable are securely
connected to the system board connector (see your Service Manual at
support.dell.com).
Jan 07, 2010 | Dell Vostro 220S PC Desktop
Cd will not eject
Try un-pluging the main power or the reset button if there is one behind the face plate. If niether one works return for a replacement.
Jun 02, 2009 | Car Audio & Video
JVC KD-G801 - Buttons not perform correct function
disconnecting the main harness will reset the microprosessor it is possible that it just locked up and resetting the unit by unplugging it may help. or you might have a bad switch in the face of your unit
if unplugging your jvc doesn't help you can e-mail me at merle@aol.com
Oct 01, 2008 | JVC KD-G801 CD Player
No sound from MP3 player
Is there an IPOD or AUX function on your system?
Feb 12, 2008 | Kenwood KDC-135 CD Player
Pioneer deh425 plug discription
I have one right in front of me and can tell you what color each wire is, from top left of plastic wiring port.
Black/ green ?
Grey/black ?
Blue Power Antennae
Black Ground
Black/white ?
Green/black ?
Red/green ? Left Lower row
Gray/red ?
Red Accessory/Ppwer
Orange Battery Memory power
Green ?
Dec 25, 2007 | Pioneer DEH-425 CD Changer
Sony cdxgt50w car cd player
if you are sure power is going to unit,There is a strong possiblity you have a burnt trace , main harness solder joints bad or shorted reverse polarity protect diode on main board .Also make sure you have power to both MAIN power (RED) and STANDBY POWER ( YELLOW) AND of course a good ground on radio chassis..
Nov 22, 2007 | Sony Xplod CD Player w/MP3 Playback...
Swapped out players and new one doesnt power up
Ok. recheck your harness. WIth some brands yes the harness will plug into the radio from a different manufacturer but recheck the wire colors. They usually change pins out. For example whats power on a particular pin may be a speaker wire on another brand unit with the same style plug... so get the harness that came with this radio. Check the pin location and wire color on that pin to the other harness. I almost guarantee that there is a difference. Hopefully you didnt damage your new cd player... let me know how it goes...
Sep 03, 2007 | Kenwood Sirius KDC-MP522 CD Player
Sony Xplod CD Player w/MP3 Playback CDX-GT50W Logo
397 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
