Question about Hampton Bay 24002 Ceiling Fan
Remote Code The ceiling fan we have is controlled by a remote and inside the remote there is a red box w/ numbers from 1 to 4 to be used like a combination code. I was told the numbers on the remote should match w/ ones on the fan, but i cannot locate any numbers on the fan. Can i please get some assistance with operating this fan ? At this time the light is stuck on dim.
  • Steve46 Dec 31, 2007
    I have the same problem and have tried similar solutions, but none work. Can I tell what the codes are on the fixture without actually seeing the receiver?
  • GDOG212 May 11, 2010
    MY REMOTE DOSE NOT TURN MY LIGHTS OFF
Our remote suddenly quit working. My husband took the fan all apart and was looking at receiver part in fan. Then I read above question and he checked and sure enough, the switch in remote had been moved. Apparently, dropping it had done it. Thanks.
Posted on May 08, 2008
I had the same problem. In my case it was easy to spot. Thehe battery cover of the remote was removed by my little    girls and she was able to tinker with the dip switch inside the remote. So  i played with them. I gues the dafault is all switches up and it worked. Hope it it helps
Posted on Oct 28, 2007
Ceiling fan lights & fan come on without using remote
on some you set a code in the remote control ..then you teach that code to the control unit ..on others you have to set dip switches on the remote control and on the fan to match .. some of the units have dip switches on the top of the fan motor housing ..some have code setting switches on the control unit located inside the fan .. at any rate the fan and remote have to have matching codes ..
here is some information on some units
http://www.ceiling-fans-n-more.com/ceiling-fan-remote-controls.php
sometimes the switches are set correctly but the contacts get dirty .. so on the remote, behind the batteries is the code switches .. you can operate each one a few times to clean them ... remember where they are set ... set them back that way unless you are going to change the switches on the module in the fan ... you can check your neighbors remote to see if its on the same setting .. if so one of you has to change dip switch settings on both the fan and remote.. on some older units the code is fixed on the receiver in the fan .. the code is marked on its box .. that code has to be set into the remote unit and is not adjustable ..
this might be the mfg for the hampton bay fans ..it might be a little help
http://www.kingoffans.com/#/products/FAQ
Jun 05, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Wiring instructions are terrible. Ceiling wires = Red, Black, White, Copper. Fan wires = Black, White, Copper. Remote wires = Neutral in(Black), Live In(Black), Light out(White), Fan out(White),...
That is dificult to follow .. here is the usual wiring plan for ceiling fans .. green to green or bare and mounting bracket ... ceiling black and red are live from the switches, fan and light.with a remote you really only need one of these , so cap off the red and use the black as your input to the remote .. the neutral to the remote should be the white .. there are only 3 wires from the fan so I am assuming that there is no light , or the light will be activated from the remote .. the black for the fan and the black for the lights connect to marked wires on the remote. .. lights out, fan out
or looking at your description .. ((Remote wires = Neutral in(Black) white ceiling wire, Live In(Black) blaxck ceiling wire, Light out(White) blue Fan/Light wire, Fan out(White) black fan/light wire, Common(White) white ceiling and white fan/light wires.
May 21, 2010 | Hunter 27148 Remote Control
Nee to know how to wire a ceiling fan remote to the ceiling box please. Wires coming from box are: black-hot, bare-ground, and white-?. Wires coming from fan remote unit are: black labeled wire to black in...
Try this, connect green wire to bare wire. Connect both black (power) wires to black wire in the box. Connect the blue wire to the button for the lights, and the red wire with the strip to the button for the fan, and the common for the buttons to the white wire.
Oct 03, 2009 | Hunter 52" Ceiling Fan With Light And...
I have 21 ceiling fans in my house.
Three suggestions (maybe not viable solutions):
1. Consider creating ceiling fan "groups". A group is a set of fans that is controlled by one remote.
Group: All (or some) in all vaulted ceilings.
Group: All hallways
Group: Outdoor celing fans
2.
Power OFF ceiling fans at the wall switch that are not used often. Those can have duplicate codes.
3.
If the remote controls are iR (infrared) rather than RF (Radio frequency), then the ceiling fans that are farthest apart or have more solid walls in between, can have the same codes and not be affected by the "wrong" remote.
Oct 01, 2009 | Sea Gull Lighting 1555-734 Three-Light...
My ceiling fan has no reverse switch, how do i change the direction
My fan does not have a reverse switch for sure so I scoured the net and got no real answer. I did come accross a comment that said that it worked internally at the remote box in ceiling. Here is how I finally figured it out after about 6 months of searching. Put the fan on high, Turn wall switch OFF, Hold the HI button on remote, Turn switch back on. IT WORKS!!!!!!!!!!!!! Sparq
Jul 18, 2009 | Hampton Bay 24002 Ceiling Fan
I have 2 fans 1 stopped working 1 remote
Look at the remote code on the remote which is broken, then copy the code on the fixed remote, then you can control anoher fan.
Jul 12, 2009 | Universal Remote Control Hampton Bay...
Wall switches do not control fan
Some fans will not operate without the remote, however, I'm not sure if the Hampton Bay brand is one of these or not. Below is how you will bypass the remote if the fan will operate without the remote.
You can try disconnecting the receiver in the canopy of the van (the cover that fits snug to the ceiling) once you have shut off the power source remove the canopy and find the remote receiver.
Most likely it will be a rectangular box with white, black, and blue or red wires attached. Disconnect all wires from the receiver and lay it to the side.
Now reconnect the wires directly to the fan, white to white, black to black, if you have a red wire (or a second black wire) in the ceiling box connect it to the blue wire from the fan.
If you do not have a red wire (or second black wire) in the ceiling box, connect the black and blue wire from the fan to the single black wire in the ceiling box. This method will require you to pull the chain to operate the fan separately.
Dec 12, 2008 | Hampton Bay 52 In. White Redington...
Remote control replacement.
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
You can also try ebay for OEM replacement fan remotes for the various brands including Hampton Bay...
Dec 10, 2008 | Hampton Bay 24750 Huntington III Ceiling...
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Hampton Bay 24002 Ceiling Fan Logo
310 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
