Question about Whirlpool 18.2 cu. ft. Top Freezer Refrigerator ET18PKXG
Underneath the crispers is full of water sometimes even freezes Underneath the crispers water collects, but it does not freeze.
  • Whirlpool Master
  • 4,654 Answers
Here is a link to help you resolve the problem I also have an even better link but on-line is moving slow at moment. Anyway you will need to take the part out from back and clean the blockage., Let me know if this helps, Sea breeze
http://appliancejunk.com/forums/index.php?topic=1309.0#top
http://servicepartstec.blogspot.com/
Posted on May 20, 2009
Water is pooling under the crisper drawers the little hole looks clogged with rust and also water leaks down from the freezer into this area??
Posted on Jun 21, 2009
Why is everything in the crisper drawers freezing?
Crisper draws are at bottom of fridge, cold air collects at the bottom and warmer air rises. Turn thermostat dial down, mine is set on 2 out of 6 and every thing stays fresh and doesn't freeze. In very hot weather I do sometimes turn it up to 3.
Dec 03, 2016 | Refrigerators
Water through door stopped working. Now water is puddling under crisper drawers, sometimes freezing. Also seems to be leaking underneath left front side.
It sounds as though the hole allowing water generated by the auto defrost to drain away is blocked.
I suggest locating the hole and using something like flexible curtain wire to rod it through, preferably from underneath.
The water collects in a tray mounted on the motor where the heat generated by the motor will evaporate it.
Jun 26, 2015 | Samsung RF26XAEWP
My Whirlpool refrigerator, model GT22DMXGW00, leaks. Water is accumulating in the bottom-underneath the right hand side crisper. It then drains out onto the kitchen floor. Some is freezing too. It is...
check the ice door flap where ice drops into a glass.sometimes the flap doesn't close completely and allows heat to enter threw the flap.this causes frost to build and melt thus you have water you can't explain. hope this helps.
Dec 11, 2014 | Whirlpool Refrigerators
Water collects at the bottom of the unit underneath the crispers and needs to sponged out every week or so.
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
heatman101
Aug 24, 2010 | Frigidaire GLRT216TA Top Freezer...
I have an LG fridge (LG LRBC22544) that collects water underneath the crispers. It freezes (almost 1 inch thick) and then melts. Once it melts, then it leaks out the door. This reforms every 3 weeks or...
I have had the same problem. In my case, its the little water tank behind the left crisper. The tank has cracked (twice now) which means replacement (again). The water leakage gets so bad that it leaks into the freezer causing ice up problems in the rear.
Apr 27, 2010 | LG LRBC22544 Bottom Freezer Refrigerator
Water not working, ice is. fridge is set at 2.stuff freezing
i have this exact same problem. Started about 3 months ago with the crisper and now the water. when I turn the fridge off after a few hours the water works again. I'm calling the repair person tomorrow
Jan 30, 2010 | GE Profile Arctica 25.4 Cubic Feet...
For some time, water was accumulating on the floor
before you call check the bottom of your freezer, if it is full of ice, yuou more than likely have a clogged defrost drain
remove the back panel of the freezer and ensure the drain is free and clear,
check the fill tube of the ice machine to be properly installed
Oct 13, 2009 | Refrigerators
Whirlpook ET21NK--Water collecting in crispers
Self-defrosting refrigerators turn themselves off to defrost once in each 24-hour cycle. There is a 'drip pan' under the refrigerator that catches water from this automatic defrost cycle. The pan is not very deep, so if the unit is leaning very much, water will run over the top of the pan. For this and other reasons, you should try to keep the unit as level as possible.
Aug 21, 2009 | Refrigerators
Roper Refrigerator - manufactured 12/99 - RT18DKXH W00
tata75,
Happy to assist you,
you said,
For the past three days, water has been leaking/freezing at an alarming rate. The freezer had about 2 inches of ice built up and the bottom of the refrigerator is holding water, too. Both crisper s were FULL of water. I don't know if the ice maker connection is broken or what. Looks like I have to cut off the cold water completely to the sink to get it to stop.
Sounds like the ice maker or its line is leaking the water to me. And obviously it will freeze in the freezer.
You need hands on service.
Our site provides service companies in your area.
bless you,
Please give me a good rating before you sign off
Thank You
Sep 08, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Refrigerators Logo
723 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
