Question about Philips Tablets & eReaders
Philips 0168 - Philips Tablets & eReaders
Need Instruction Manual for SM-T530NYKAXAC - Samsung Tablet CE 0168
This might work.... Hold the power button and the volume down button down a the same time until "Samsung" appears on ther screen and it should eventually boot up.
Dec 13, 2014 | Samsung Tablets & eReaders
How do i connect wireless keyboard to my philips smart tv
If you have bluetooth on the tv then there should be an option to search for the device you wish to pair with in the settings on the tv. If you don't have that option then you would most likely need to purchase a bluetooth adapter to plug into your tv in order to connect your keyboard
Oct 19, 2014 | Logitech Keyboard. K400 Wireless Touch...
How do i connect a wireless keyboard to my philips smart tv
Plug the wireless dongle into a USB port on the TV. If it is compatible, you should see it work.
My samsung galaxy ce 0168 screen is not working anymore after 2 minutes turned on
Check that the charging port pins are not bent or damaged or corroded use a small needle to clean each individual groove. Replace the charger, suggest Staples or Walmart for the source.
Dec 05, 2013 | Samsung Galaxy Tab Tablet PC
My cameras don't stream video only stills
Apparently this is a big with their app and ios6. Look out for a fix, god knows when.
Sep 29, 2012 | Philips In.Sight Wireless Home Monitor...
Philips gogear connect 3 shows only a white screen and its not working
Try resetting your tablet. Google search your make, model and reset. Follow the instructions from one of the results provided.
May 12, 2012 | Philips SA3CNT08K 8 GB GoGear Connect 3...
White screen
May 04, 2012 | Philips SA3CNT16K 16 GB GoGear Connect 3...
Tablets & eReaders Logo
Top Philips Tablets & eReaders Experts
Are you a Philips Tablet and eReader Expert? Answer questions, earn points and help others
