Question about Philips Audio Players & Recorders
Cant eject cd, no sound
Micro theatre MD288 Can't eject cd also no sound playing on mp3, tuner just white noise which increases in volume as volume control turned up
  • 6,784 Answers
HI, you have a damaged IC chip on the main board that is not allowing proper sound distribution at this time and, the load motor on the CD assembly is also damaged. this is the reason for the trapped CD that wont eject.
Unfortunately, Micro dose all of its repairs in house and you will have to send this unit to the Micro techs for this repair.
Posted on May 21, 2009
The volume is noticeably lower when listening to the radio. It sounds normal on CD, Aux and MP3. I know it has a built in amp. Could this be the issue. Thanks.
You have not mentioned what type of radio you have, what car it's installed in, and what other audio equipment you have. I will assume it's an aftermarket radio, and it's common that the tuner's signal strength is not going to be as powerful as the other sources. If the built in amp is used, then it's used all the time, with all sources, including the tuner. Some brands will have a loudness offset function wherein you can lower the power output of the CD/Aux/MP3 inputs to volume match the radio, but there's no fun in that. There's not a way to make the tuner play louder, unfortunately, aside from adjusting the volume when using the tuner section. Technology has brought many advances, including a much higher signal to noise ratio, which is why digital trumps analog in this instance. This is what you are experiencing, which is not necessarily a technical issue, but a technology issue.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Jul 02, 2017 | Car Audio & Video
Will a ipod player play in my sony TA-AX301 AMPLIFIER-No sound
You need a 3.5mm to stereo phono/RCA cable
Plug the red and white ends in to any of the following sockets that are free - Tuner, Tape In, CD, Aux, Video In. They all do the same job. The names are just suggestions, they're not mandatory.
Plug the headphone jack plug in to the MP3 player's headphone socket. Turn the volume up on the MP3 player to about half way. Then select the source input on the amp that matches where you plugged the cable.
That's it. Hope this helps..
Sep 16, 2014 | Audio Players & Recorders
Cda 9885, When in tuner mode sub does not play
Does you car volume get lower when you stop. If not sounds like an internal issue. No sound at all my brother hooked his up and when he switched to tuner everything would go through the subs but you would not know it sounded like his 6x9s no bass. was a wiring issue. I dont know if this helped or not.
Feb 28, 2014 | Alpine CDA-9885 CD Player
I have a sony explode cd player. It is an older one and has been sitting in a garage for about 3 years. We hooked it up today and my subs will not play when a cd is playing but the subs will play in...
It sounds like you are using the blue wire (power antenna remote turn on) instead of the blue/white wire ( amplifier remote turn on) to turn your amp on. The power antenna remote turns off when leaving tuner mode.
May 02, 2011 | Sony XPlod CD Player w/MP3 Playback...
Sony DAV-DZ660 Theatre system. How can I change the output volume and tone for each speaker please?
there should be a speaker set up button on your remote, it will play "white noise" through each speaker in your system, one spearker at a time, as each speaker plays you can adjust its volume, the idea being to balance the system to sound good from your sitting position. try to get each speaker to be appriximately the same volume level. If you have the manual for this system, this setup should be listed in the index or somewhere.
Mar 19, 2011 | Sony DAV-DZ660 Theater System
Clarion vrx 485 vd.tuner works with amp but cant get dvd or cd to play with amp.screen works cd an dvd are playing but no sound.an with key off tuners playing till i open door?what have i hooked up wrong?
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
it sounds like you have hooked the power wires up wrong try trace back your wires with this diagram
Mar 29, 2009 | Clarion VRX485VD Car DVD Player
Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Jun 09, 2008 | Kenwood KDC -X815
Sound
When I have this problem, I go to the menu, highlight fm radio and the sound comes bac. Then I go back to 'play music mode' . It's worked every tme.
Jul 22, 2007 | SanDisk Sansa m240 MP3 Player
155 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
