Question about Whirlpool ED5GHGXMQ Side by Side Refrigerator
Fridge not staying cold
I have a whirlpool model # ed5ghgxmq## side by side fridge the fridge is not getting cold and the freezer is getting a whole bunch of frost on it and i keep finding a "lake of ice" under the bottom drawer in the freezer. what could be causing this and how do i fix it.
  • Whirlpool Master
  • 4,654 Answers
Inside the fresh food compartment there is a defrost timer hidden behind the temp control panel. Sometimes there is a plastic plug over the hole that you need to put a flathead screwdriver in and slowly turn it clockwise. When compressor stops I want you to wait about 25 minutes to see if the refrigerator comes back on by itself without help. If it does I need you to listen inside the freezer compartment for sa sound of crackling or sizzling noise indicating defrost is taking place. Let me know, Sea Breeze
Posted on May 20, 2009
Loud humming noise
Have you had the noise before or did it just start?
Try to isolate where the noise is coming from. From under the fridge? On the back wall of the freezer side? If those two, could possibly be one of the fans.
Dec 03, 2013 | Whirlpool ED5GHGXMQ Side by Side...
Water is leaking on the floor under the freezer side of the refrigerator.
This can be due to overflow from the defrosted water tank. You need to move the fridge forward and remove the tank which is at the rear bottom of the fridge.
Now drain off the water and put back the tank into the slot.
Set the thermostat to NORMAL , check if there is leak on the gaskets or the drain pipe from the evaporator when the defrost timer works.
If the tubing is damaged then replace.
Aug 11, 2011 | Whirlpool ED5GHGXMQ Side by Side...
Whirpool side by side freezer working but fridge not
Hi emmaubiera86,
The issue with the freezer working but the fridge is not is usually the result of a defrost problem. The first thing to check in this case is the freezer area. Look at the back panel inside the freezer. If you notice frost covering the back panel, you have defrost problem. One of the things that happens during this defrost problem is Air cannot circulate from the freezer(where the cold happens basically) to the fresh food section. The coils inside the freezer are the only part inside the whole refrigerator that "get cold". They need to stay free from excess frost build up so that air can pass through the coils and reach the fridge section of your machine.
Hope it helps.
Thank you for using FixYa.
May 07, 2011 | Whirlpool Refrigerators
Whirlpool 6th sense side by side fridge/freezer 25rid4 model,freezer working fine but fridge part does not cool
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
User manual whirlpoolfridge freezer 20rid3 sf i have lost user manual
Call Whirlpool. The number should be on model tag inside freshfood. Either upper right or upper left.
Sep 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer not freezing
Possible defrost timer failure
Oct 15, 2017 | Whirlpool ED5GHGXMQ Side by Side...
Compressor runs for 5sec.
your relay and overload on side of compressor is bad.you can replace with original parts or a 3-n-1 hard to start.
Mar 09, 2009 | Whirlpool ED5GHGXMQ Side by Side...
The Fridge stays too cold at -6.
Yes it is the thermostat. Replace it or have it replaced.
Jun 13, 2008 | Freezers
Cold fridge but not freezer
try DEFROSTING the fridge and restart it after COMPLETELY defrosting it.
May 05, 2008 | Fisher and Paykel Active Smart E522B...
Whirlpool ED5GHGXMQ Side by Side Refrigerator Logo
260 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
