Question about Sears Roebuck and Co. Pedal Tractor
Gas empties into oil when the engine is turned off
When the lawnmower is turned off, the gasoline empties into the oil. If you put a clamp on the hose from the gas tank to the solenoid, it stops it. Does anybody know how to fix this?
  • 351 Answers
The needle and seat in the carbi may not be sealing properly and allowing the carbi to flood and run into the motor
Hope this helps
Posted on May 19, 2009
Bourght petrol 471sp lawnmower with no manual it will not? put in oil and petrol.
probably the gasoline gummed up at bottom and needs to be cleaned. if the gas is not emptied when stored it can do this and will not start
Apr 08, 2015 | Garden
Does 2stroke go in gas
If you are referrig to 2 stroke oil, the answer would be no. Generally speaking 2 stroke oil is mixed with gasoline at the appropriate ratio and is used in gas powered weed eaters and chain saws. A lawnmower for the most part is considered a 4 stroke motor. You only need to use gasoline in the tank. Make sure that at the end of the season the gas tank is pretty low or even allow it to run dry. This is simply to avoid the harmful deposits that old fuel can cause to gaskets. If emptying of the gas tank is not easy, you can add fuel stabilizer to ensure that the fuel is usable for the next season.
Jun 30, 2014 | Poulan Pro 22inch 625 Series Briggs ...
How do you remove the gas tank?
empty gasoline from tank remove clamps from fill hose pry hose off tank locate clamps that hold tank in place drop tank down reverse steps to install.
Aug 05, 2011 | 2002 Chevrolet Tahoe
My Lawn mower seems to be produced by ALKO, but has the Briggs and Stratton emblem also. It is the 40b model and having just inherited it, I am trying to find out if I put just petrol in or whether I need...
Hi scottcoles5...
The easy way to find out if the motor is 2 or 4 cycle is to check to see if the engine has oil in the crankcase...if it does it is a 4 cycle and you will NOT have to mix oil with your gas. 2 cycle engines do NOT have an oil in the crancase and depend on the oil you mix with your gasoline.
You can also check the color of the gasoline in the tank, most 2 cycle oils contain a colorant to color the gas to let you know there is oil in the gas...
Free Answer...Please take time to rate me
May 31, 2011 | Briggs & Stratton Briggs Stratton...
Bought unit new last summer. Used it once last summer and once this year. It started fine both times. Today, it will not crank. I have replaced the spark plug, checked the air filter (it is clean), gas...
Unable to crank? Do you mean unable to start?
If you leave gasoline inside tank over long period of time, that will 'gum-up' and ruin carburetor.
To prevent problem, put additive in gasoline or empty gas from tank:: under gas tank should be a hex bolt that holds up gas filter > loosen bolt and drain gas.
Starting the engine:
Take off air filter and spray WD-40 directly into carburetor.
Start engine, engine should fire on the WD-40 accelerant.
If engine fires but does not keep running, try spraying WD-40 into carburetor continuously to see if you can keep engine going.
If engine stops each time after it no longer gets WD-40, then carburetor is bad or gasoline not getting to carburetor or gasoline is bad.
Try fresh gasoline.
Do not turn small engine on side or upside down or oil will get into carburetor.
Check gas supply: Go to gas filter under gas tank. Pull loose rubber hose that connects to carburetor and see if gas comes out rubber hose.
If gas is flowing to carburetor, then carburetor is gummed up.
Small engine repair might suggest 'gum out' or have other suggestions ... but you may need a new carburetor
If engine will not fire on WD-40
If engine will not fire on WD-40 at all, then spark coil may be bad or exhaust port is clogged
Check screen that covers exhaust >> is it covered with carbon and dirt or can air pass through it easily?
Check spark
Remove spark plug
Put spark wire back on spark plug
Hold spark plug by rubber spark cap so hands don't touch metal part of spark plug
Touch spark plug threads against hole where spark plug was removed >>> metal to metal so it conducts electricity
Pull start cord and look for sparking between spark plug threads and metal of engine (don't look at the spark gap ... look where metal meets metal
If you have no spark, the spark coil is bad >> time for estimate from small engine repair shop or get your part number and order replacement
Oct 13, 2010 | Craftsman Garden
2001 Heritage softail, carburated. Gas in oil.
If you had gasoline in your oil, there's only two ways for it to get there. It either came through the carb or someone poured it in there.
I've been messing with Harley's since 1966, back before they created these cute little names for the engines like Panheads, Shovelheads, Evolution, Blockhead, Fathead. We only had two engines, Sportster 61 cu. in, and the 74 cu. in. in the big bikes.
Now, the way the fuel got into your gasoline was through the carb. If you've ever watched an old timer get off his bike, he'll reach under the tank and turn the fuel off. This was keep what happened to you from happening. It worked every time. The problem these days is in their infinite wisdom, Harley has adopted the misguided conception that the Japs started, the vacuum operated petcock. The absolute worst invention man has ever designed and put on a motor vehicle.
Now, in both the petcock and the float bowl of the carb you have a "needle and seat" all it takes is one very small bit of trash to cause the gasoline to seep past the needle. Keep in mind now that gasoline has a lower viscositiy than water. It will go where water won't go. It's thinner. A lot of gasoline can seep past a needle and seat in a 12 hour period. I've seen fuel tanks empty themselves in that time.
I've fixed many bikes that had the vacuum operated petcocks on them. They started putting them on the bike in 1996. I've seen people stranded beside the road with full tanks of fuel but not a drop getting to the carb. I've seen gasoline pouring out the small vacuum line (probably what happened to you) after the engine had been flooded out due to a ruptured diaphragm. And, I've even seen a couple of cases where the engine was sucking air through the petcock and would not idle or even run very well.
Now, when you change the oil on a harley engine, you don't get all the oil out of it like you do on car engine or a Japper engine. There will be a certain amount of oil left in the top of the heads and the camchest. Also, the gasoline fills up the crankcases that are supposed to be empty of oil. If you have a quart of gasoline that has run down past the rings into the crankcase, you now have one extra quart of fluid in your oil system. Whenever I suspect something like what happened to you, I always take the spark plugs out and spin the engine over a few times to get any excess fluid out of the crankcase. It will blow it out of the crankcase vents which in your case is in the heads. Those big bolts that hold the air filter backing plate on are hollow and are actually crankcase vents.
So, in short, my suggestion is to take that vacuum operated petcock off your bike, plug up the vacuum hose, and purchase a high quality manually operated petcock like a Pingle. They're expensive but if you get into the habit of turning it off whenever you get off your bike, this problem will NEVER happen to you again.
BTW:, you need to check your primary oil to see if it's been diluted as well. The gasoline will go past the sprocket shaft seal and contaminate that oil as well. You're pretty safe on the transmission lube though.
Good Luck
Steve (old biker)\\\\\
Jul 11, 2010 | 2000 Harley Davidson FLSTC Heritage...
I can't start my honda lawnmower, checked the oil, put new gas use choke,it gives litle sound but not enough to start
Try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season. Spark can be tested by sight, remove the plug and use a clip-on ground wire from spark plug body to metal on the engine with the plug wire connected.
Jun 10, 2010 | Honda Gxv160 55hp 55 Hp 25mm Dia Lawn...
WHAT TYPE OF FUEL, STRAIGHT OR OIL/FUEL MIX & WHAT PROPORTIONS ?
Determine if your engine is a two-stroke or a four-stroke. Check the gas tank on your lawnmower or the owner's manual to determine what type of engine you have.
Read the label of your two-stroke oil. Follow the directions on the package to ensure the right mix.
Measure and pour the gasoline in to the empty gas can.
Add four ounces of two-stroke oil per each gallon of gas.
Replace the cap on the gas can and shake the oil and gas to mix. Add fuel to your engine.
Take care.
Jun 01, 2010 | Garden
Does anyone know whether these Yard Machines lawnmowers take straight gasoline or mix? I cant find an onwers manual online to clarify it. To be clear I seem to have a bit of an oddball machine;...
Straight gas. Look around, and you will see where to fill the engine with regular sae 30 oil, and on lawnmowers, if you have a place to fill it with oil, you don't mix oil with the gas.
May 18, 2010 | Yard Machines 11A08MB006 22Inch 139cc MTD...
2 stroke gas mixture in 4 stroke lawnmower
Your carburetor jet is probably clogged with oil. Try an additive in the gasoline -- something for cleaning injectors -- it will only require a small amount -- use the same ratio as described on the label.
You'll have to keep starting the engine to get the cleaner into the carburetor. After you've done this several dozen times, let it sit for a day.
If this doesn't clean it out, you'll need to take the carburetor apart and clean it.
May 05, 2009 | Garden
Sears Roebuck and Co. Pedal Tractor Logo
172 people viewed this question
Top Sears Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Sears Toy Expert? Answer questions, earn points and help others
