Question about Jenn-Air JJW8230D Electric Double Oven
Double Jenn-Air wall oven both overheat overcook
Both ovens overcook on temps that always cooked perfectly before; decreasing cook time and temp still burn and undercook in middle...I use it constantly and it just started burning everything. It's 3 years old so some parts are still under warranty. what to do?
  • garysbabe1 May 19, 2009
    Jenn-Air double wall oven overcooks everything and didn't used to. Is it just the panel that needs to be fixed since it's not heating to correct temp, if I turn temp down and cook shorter time it still burns food & undercooks middle then. What to do?
    Is the temp probe listed under another name such as thermostate hi limit for upper/& lower or is it an oven sensor? Is timer control just the control panel(this was actually replaced when we first moved in since it was dysfunctional from the start); or is it listed under another name also in the parts?
  • 15,935 Answers
Yes - your "temperature probe" is a thermostat.
It no longer gives the element controller the proper temp feedback.
Posted on May 20, 2009
  • Jenn-Air Master
  • 19,396 Answers
The problem is either a faulty temp probe or a faulty timer control board. Check also if you have an heating element that is staying always on because of a contact to ground.
Replace first the temp probe that is less expensive .
If that does not fix the problem , then replace the timer control.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Please, do not forget to leave feedback.
Many thanks.
G
Posted on May 19, 2009
    Genius:
  • 1,847 Answers
I think this oven has a self-cleaning mode.
It heats the oven up to an unbelievably high temperature and pretty much just turns any ickiness in there into charcoal, which you can then just scrape out. It puts quite a dent in your gas/electric bill, though, but that should fix you problem.
Let me know
Thanks
Kevin
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
I have recently purchased a Neff double oven UI722 and am experienncing difficulty with the heat control. Most things I cook seem to burn either at the sides or bottom or both . Can you help in any way...
It can be difficult to 'acclimatise' to a new oven particularly if it is a fan oven as cooking times are usually shorter.
Temperature distribution is also different so if you are following your normal cooking temp and time you may need to adjust these so as not to overcook.
Try a few set recipes from the hand book using the set times and temperatures to see if that makes any difference.
Good Luck
Dec 19, 2010 | Neff Ovens
F4 error message
HI. This is a failed oven temperature sensor error code. Simply replace the temp sensor, asap. This will clear the code. The temp sensors are generally located inside the oven, mounted on the back wall, in the top left or right corner.
It will look like a 4 inch slim probe.
F4 failed temp sensor.
Dec 29, 2009 | Jenn-Air JJW8230D Electric Double Oven
I have a Jenn Air ww2711w0 double oven. The Lower
Your t-stat or control board could be out on this unit. Can you check your t-stat and see if it's working alright? If it is, it's probably your board. Hope this helps~!
Aug 20, 2009 | Ovens
Hello, My Jenn Air oven overheats. When I set
The temp probe resistance should read between 1050 and 1150 ohms. If not. Replace it.It causes the overheating situation you describe.
Jul 16, 2009 | Jenn-Air Ovens
My jenn air dual oven timer, temp lights are going out
Sounds like another control board failure, common on this type oven. It appears that a capacitor (#C3 on board) overheats and goes bad. Replacement of cap is a simple soldering job but the caps can be hard to find, try electronics parts houses and explain you need a high temp replacement. Should cost you about a buck. See post by Briangem back in may of 2008, who turned me on to the target cap. Its a 35Volt 86mF.
Apr 29, 2009 | Jenn-Air JJW9830D Electric Double Oven
Time and Temp. display on my JennAir Expressions is not working.
99% likelihood of a bad clock, part # 71001799. This is unfortunately very common with this model. Hope this helps!
Dec 31, 2008 | Jenn-Air W30400P Stainless Steel Electric...
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air JJW8230D Electric Double Oven Logo
81 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
