Question about Music
Buzzing noise on Marshall MG100FX
Immediately upon powering on and with or without an instrument connected, Marshall MG100FX makes constant, buzzing noise. Previously worked fine before friend turned off connected instrument and then turned off amp. Nothing has changed in setup of amp or power connections, etc. Master dial use makes sound louder. Connecting a guitar results in very faded guitar sound behind constant buzzing sound.
5 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: loud buzzing when amp connects to guitar
The buzzing noise could be caused by a grould feedback loop. This occures when the amp is plugged into one power socket and the guitar's amp is plugged into a drifferent power socket.
Try to use a power board, plug in all your devices into this power board and plug the power board into a power socket.
Posted on Jan 03, 2009
  • 1137 Answers
SOURCE: Constant buzzing in my 15 W amplifier
Make sure you have a ground prong on your power cord. Most input jacks nowadays are closed circuit. They have a switch built in that won't allow any sound without the cord plugged in. You may have a damaged jack that will give you a loud hiss, a loud hum or crackling depending on what volume your controls are set at.
Posted on Aug 28, 2009
freetek
  • 5568 Answers
SOURCE: it constantly has a buzzing
Start by unplugging anything attached to the amp to eliminate simple things such as a broken shield on an input cable.
If you still have the pronounced hum with nothing connected, then the amp's power supply may have a failed filter capacitor or diode bridge. Either of those would have to be sought by a tech with the right gear.
Posted on Jul 04, 2011
cardenderek
  • 783 Answers
SOURCE: hello! i have aproblem. i'll
FixYa Subscribers have access to unlimited tech support, articles, and Experts!
Posted on Aug 16, 2011
[23:05:39] Sharon Levit: hello! i have aproblem. iwll be glad if you can help me! so here is my problem: i bought a marshell 15 MG amp few days ago and this annoing buzzing problems. every time when i...
Make sure you are using this on a three wire grounded receptacle. If you are on an old two wirepower system, have a ground installed in the receptaclel you are using. If you are on a grounded circuit, then exercise your warranty for repair/replacement.
Aug 16, 2011 | Marshall Amplification Marshall MG15 15...
Constant buzz. even with no guitar plugged in
This usually indicates that your neutral and live are backwards. Try plugging the unit into a different outlet elsewhere (different room)
If it still is buzzing, look for a GOUND LIFT switch in the back, it may have inadvertantly gotten flipped to the wrong position.
Feb 27, 2011 | Marshall Amplification Marshall MG50FX 50...
When turning my Marshal MG250 DFX on, there is a terrible buzzing sound. I have tried it on different speakers and the buzzing still occurs. It does not change in volume when i adjust the volume. Whats the...
This is likely a filter capacitor issue. The right tool to troubleshoot is an oscilloscope. This could also be a failed power amp that is driving high DC current with ripple into your speaker. This can permanently damage the speaker. Repair this before using it.
Jan 13, 2011 | Marshall Amplification Marshall MG250DFX...
GM100HDFX head. Fuse blows immediately upon power up when output module on fan-cooled heat sink is plugged in. Increase the fuse and loud buzz comes out through the speaker. No volume control then. Unplug...
NEVER increase or replace the fuse without repairing the unit. Further damage is likely if you do so.
Put a light bulb, say 150 watts in series with the power to the unit to act as a fuse that won't damage things while troubleshooting. The light will light and limit the current.
There are three 47mfd/63V electrolytics on the output module. I suspect one of those is shorted. Observe the correct polarity when replacing. C2 and C3 are most likely. Use my above suggestion with the light bulb and check the voltage across each of these. It should likely be in the 35 to 45 volt range though schematic doesn't show the value..
Aug 04, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
I have a buzzing noise coming from my Marshall AVT100. It is present on all the channels. Is it likely to be caused by the valve? The valve inside is made by Electro Harmonix and it was made in Russia....
okay so buzzing noise. i have seen this once before. the extension cord feeding a power strip with two amps plugged in and powered on off of a low amp electrical outlet with fluorescent lights overhead.......try running only one power unit off of the electrical outlet you are using, just one straight into the wall with the lights out. if you still hear it i wonder if the output transformer is starting to go south. if you listen close sometimes you can hear the buzz of a transformer powered on, example: you can hear the buzz of a power transformer on a power pole in peak hours. tubes usually make hisssing, crackling type noises. next would be to tap on the tubes while in play with an orange stick or pencil eraser to listen for microphics or the tapping itself thru the speakers. if you hear with out a doubt change them.
Apr 05, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Our Yamaha clavinova CLP-115 is buzzing, even with
Without power to the unit no sound should be generated. Make sure there are no other connections.
MAYBE you have a wall transformer behind it that is buzzing. MANY wall transformers develop buzz.
Another source is flourescent lights and even some of the low voltage halogens have noisy transformers in the base.
Nov 17, 2009 | Yamaha Music
Aug 27, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Music Logo
27 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
