Question about Philco 841205 Turntable
Philco turntable will not work because spring on tune arm unhooked
3 Suggested Answers
ttech
  • 139 Answers
SOURCE: turntable won't turn
In the middle of the TT youll Find a C-Clip It needs to be Removed before the Platter can be removed,You either have a Broken Belt,Or the Grease in the Guide is Old and must be Cleaned out and Relubed
Posted on Jul 19, 2007
SOURCE: Philco 841.205 TurnTable spring and plastic armature pulled off HELP
I have the answer to your problem but after typing it for 15 minutes I could not get it sent because the send code wasn't right and I lost everything. Email me at lberzan@sbcglobal.net and I will try again. I have pictures
Larry
Posted on Feb 08, 2009
My philco turntable CD with cassette player arms messed up
Need more information and a detailed description of what the problem is.
Dec 28, 2016 | Philco Audio Players & Recorders
Is there a seperate mtr for player arm
Looking at the picture I think it highly unlikely there is another motor. Arms are generally linked to a mechanical cog systems. Of course any of these can loose teeth, fracture, especially if the are abs plastic. That will cause all sorts of problems for the arm movement.
Dec 10, 2015 | Philco 841.169 Turntable
The turntable on my philco cd cassette and turntable unit does not turn. how to i access the belt, etc. to see whats wrong?
I had a similar issue with my Crosley turntable that I recently picked up... and after digging up the manual online all I had to do was lift up on the tone arm and move it to the right (past the holding mechanism) until it clicked, and voila, the turntable started spinning again.
I hope this helps!
Sep 18, 2010 | Philco (R) Classic Turntable CD Shelf...
Philco 841.205 Turntable Issues
I take it that it doesn't turn? OK two choices for you. Faulty motor, or a on/off switch that doesn't work. If you have to move the arm to start the turntable then some kind of leaver switch is either bent or broken.
I should imagine this model uses no more than a 12 volt motor. If you have no look with the switch, find the motor and take it out. Then stick a 9 volt battery on it, or lower voltage if it's only 6 volt motor. If it don't go it's bust!
Jun 01, 2010 | Philco 841205 Turntable
How do you get the turntable to start turning? We just got a Philco turntable and can't find a switch to get the turntable to turn. We got it used so don't have the instruction manual.
A lot of turntables start moving when the arm is moved to the record start. The turntable should move when you move the arm to the edge of the platter, even with no record. If it doesn't, listen to see if the motor spins. Then lift up the platter matt to see if the belt has slipped off.
May 06, 2010 | Philco (R) 841.205 CD Shelf System
I have a Philco Classic ... the turntable did not work. I pulled the arm back, as suggested, and it worked! But it really drags when I try to play an LP. What now?
what do you mean it drags? I noticed if you don't pull the arm back far enough,it will turn on,but the arm will drag foward scratching your record. Try pulling it bacl ALL the way and then it should give you no problems.
Sep 29, 2009 | Philco (R) Classic Turntable CD Shelf...
Turntable motor is not working
hi, before you buy a new motor first check the selector switch if it work in proper...some times the connection even though you range it into desired position inside of the selector not in connection ..( solution: move the selector switch ON and OFF 5 0r 10 times or more as long as you can.. or try to take some Multi tester to know if there a continuity of the selector swich..u
May 03, 2009 | Philco 841205 Turntable
How to turn on turntable on Philco Turntable CD Player
Just pull the arm back a little bit, the turntable should then start.
Apr 20, 2009 | Philco (R) Classic Turntable CD Shelf...
Well it turned out that that 45 degree plastic piece DID or WAS attached to the main post. It snapped off. I super glued it back on and to each side of that very flimzy broken plastic I cut two very small pieces of wood (using popsicle sticks) and super glued THOSE to either side of the broken armature piece. Once dried I re-attached the spring and it worksd like a charm.
Oct 10, 2007 | Philco 841205 Turntable
Philco 841205 Turntable Logo
148 people viewed this question
Top Philco Audio Players & Recorders Experts
 Grubhead
Grubhead
jason
Steven Wander
Steven Wander
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
