Question about Philco 841205 Turntable
Tone arm when moved to the right will not start turntable
How do I access tone arm belt and motor on a Pioneer PL-L30 turntable?
Try lifting up the turntable mat. You should see a hole. Note how it fits before removing the belt.
Oct 10, 2014 | Audio Players & Recorders
JVC turntable AL-E300 turntable slowing down when tone arm moves iacross
Even if the belt looks fine it's almost certainly the problem. You mentioned "cleaning" - if you got any kind of fluid on the belt it might act as a lubricant and reduce the friction between the belt and the drive wheel, causing the turntable to slow when the tone arm puts a drag on it. The problem may go away when the belt dries out.
Nov 23, 2013 | Audio Players & Recorders
How do you shift to play records. When I turn to phono on dial it turns the unit off. I have a radio cd player with CR24 turntable
Move the tone arm off the rest on to the record and it will start to spin. There is a switch that turns the player off when the tone arm is on the rest.
Feb 25, 2011 | Crosley CR248 Turntable
The turntable is not moving at all!!!..
not really enough info at all. to start a record you take the tone arm(the thing with the needle...) and slightly move it to the right until it clicks and then the record will start. make sure youve taken off all the tape on the turntable and make sure its set to phono
Jan 15, 2011 | Crosley 4-in-1 Entertainer CD Shelf System
Need to know what settings the anti-skate and the counterwieght on the back of the tone arm should be set to. Also when pressing start tonearm will not move at all. Can still cue it manually...
The counterwieght should be set the tracking force for the cartridge/stylus fitted. These are expressed in grams. Typical about 2 to 3 grams. If the weight has numbers on it these will match the grams. There's no right setting for the skate. Should the stylus start to skate accross the record increase the force. Start low!
On the arm movement, has the arm moved before after pushing start taking it to a record? As many turntables just don't.
Jan 01, 2011 | Technics SL-1200MK2 Turntable
Tone arm will not move over on self-start unless
Hi, they are not an auto start model turntable. To start lift tone arm off rest and move into position at start of record. It will automatically lift and return to rest as well as shut off at end of record. cheers john ,, Styluscity.com
Feb 21, 2010 | Thorens TD-190 Turntable
Tone arm moves to the middle rather than the beginning
There is 33and 45. that's the size of the record.There should be a level to change from one to the other.
Aug 07, 2009 | Sony PS-LX250H Turntable
Turntable start switch does not engage
Actually, you start the turntable by moving the tone arm AWAY from the center.
Oct 30, 2008 | GPX HMTU3234 Shelf System
Technics turn table
under the tone arm next to the lever ther is a sort of plastic bar which lifts the tone arm when lever is up right, look along that bar and there is a screw which you turn as you would to tighten anything.you will see the bar move down,try again and if you still have the same problem repeat the process till done......
Jul 03, 2008 | Technics SL-1210 Turntable
Philco 841205 Turntable Logo
114 people viewed this question
Top Philco Audio Players & Recorders Experts
 Grubhead
Grubhead
Steven Wander
Steven Wander
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
