Question about ZTE Optik / V55 CDMA Tablet
Factory reset my tablet wont turn off and I don't know the password to get into it
When I turn on the tablet and swipe screen it asks for password,I dont know what it wants
Someone installed a password, so until you either perform a factory reset of the tablet to clear the password or remember the password you are kinda sunk. A reset will erase all stored data except what was loaded by the factory.
Jan 17, 2017 | Tablets & eReaders
How do I reset password?
Use another tablet, phone or pc and go to amazon and make sure your password is correct. Remember passwords are case sensitive.
Oct 16, 2016 | Tablets & eReaders
How to unlock
Deb, You may have to do a factory reset if you can not remember the password. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Forgot your tablets password
Forgotten Pattern PIN or Password on an Android device
What do do if forgot my password to unlock to my tablet
How to Factory Reset Your Android Phone or Tablet When It Wont Boot
May 20, 2016 | Tablets & eReaders
Lost password Nobis 1022C what do I do.
I already answered you. You need to do a Factory Reset.
  • How to reset 9" nobis tablet to factory setting? - How do ... www.askmefast.com > Consumer Electronics > TVs > Reset Nobis internet table recovery mode. You can perform a factory restore on the phone to get back in. power off phone, then boot into recovery mode by holding volume up ...
  • Nobis 9" Tablet 8GB Memory Dual Core - Walmart.com www.walmart.com > ... > Nobis 9" Tablet 8GB Memory Dual Core Nobis 9" Tablet 8GB Memory Dual Core. ... I have called customer support twice and performed a simple reset and a factory ... I went on the Nobis site to look ...
  • How to I factory reset my nobis 7" tablet? - Ask Me Fast www.askmefast.com > ... > Reset Factory reset nobis pad. The volume keys wont navigate when trying to factory reset my tablet? ... How to i factory reset my nobis 7 tablet?
  • Apr 03, 2016 | Tablets & eReaders
    Won't let me reset password its like it is hung up. turning it off won't help. what do I do?
    If you do not remember the password, or is you cannot enter a password, it is likely that you will need to do a reset. Unfortunately this will reset the device to its factory defaults, so any data you have stored locally, will be deleted in the process. If you moved anything to an external SD card, just remove it prior to the reset,
    Unlock forgottten password pattern lock of Android Tablet
    How to Reset an Android Tablet
    I post on behalf of HP.
    Jul 27, 2015 | Tablets & eReaders
    Locked outmy tablet forgot my info to get on
    If you cannot get past the password, then take a look through these pages which may help. If all else fails you can use the method for a factory reset, but be aware that you will lose any data stored.
    How to unlock android tablet after forgetting pattern lock
    I hope this helps.
    Jul 18, 2015 | Tablets & eReaders
    Hi I got a Ultimate 7 inch tablet. I reset it and now its asking to type password to decrypt storage. I don't know what password it wants. What do I do.
    A user of the device has deliberately turned on data encryption to protect the contents of the device in case of loss or theft. I say deliberately, because you have to enter, then verify, the password, and then agree to the encryption. If you don't have that password then you are going to have to perform a factory reset of the device.
    First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the + and -, and select with the power button.
    Go to the option for Factory Data Reset and select it. Scroll down to Yes, and then the tablet will erase its memory back to factory settings. Once it has completed, select Reboot Tablet Normally.
    Feb 02, 2015 | Tablets & eReaders
    How do I unlock my trio tablet! The code is a pattern and the tablet doesnt give me an option to retrieve the pattern or even reset it. Please help! Thx Kat
    Some tablets will prompt you to reset after you have tried and failed entering the correct password a certain number of times. You can try this, it could work too.
    Jun 26, 2014 | Tablets & eReaders
    ZTE Optik / V55 CDMA Tablet Logo
    48 people viewed this question
    Top ZTE Tablets & eReaders Experts
    Computer Repairing
    Computer Repairing
    Matthew MacWilliams
    Are you a ZTE Tablet and eReader Expert? Answer questions, earn points and help others
