Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
How to clean the "wet spots" off my TV.
I cleaned the screen to my tv, thinking some kind of drink may have gotten splashed onto the screen. But when I turn on the tv, I see what looks like "wet spots" on the screen. The spots are clear in color and seem to be centered on the screen from left to right, but are visible from the top to the bottom. Is this on the mirror, or is there a screen protector on my tv that may have something on it? I need assistance in any teardown or equipment removal associated with remedying this problem.
Thanks,
Jason
  • Big Jay Oct 19, 2007
    I am clueless as to what the lenticular and fresnel are. Please explain to me what I need to do to replace any faulty components.
    Thanks,
    Jason
    Champion:
  • 317 Answers
The liquid is between the lenticular and fresnel
they are most likley damaged and will have to be replaced...
Posted on Oct 19, 2007
How should we clean our TV screen from finger prints?
To clean your TV correctly, follow these steps:
  1. Turn the LED TV off, let it cool for a few minutes, and then unplug the TV.
  2. Clean the frame of your LED TV with a microfiber cleaning cloth.
  3. To clean the screen, first try wiping gently with the microfiber cleaning cloth. If that does not work, spray luke-warm water directly onto the microfiber cleaning cloth. Never spray anything directly onto your TV screen.
  4. Wipe the screen with the microfiber cleaning cloth as gently as possible. LED TV screens are fragile and can be damaged if you press too hard.
  5. Let the screen dry completely before you plug the TV back in.
Jan 11, 2018 | Televison & Video
I have several large water spots on the lower right corner of the tv from overspray with windex. Can this be fixed?
Not a good idea to clean tv with windex. Try wet towel dipped in mild soap solution. Make sure all water has been removed and towel is only wet. When tv off, try removing the spots. Turn tv on only after tv dry.
Dec 22, 2013 | Apex Digital LD4088 LCD TV
Hello, I have a 40" Samsung LCD flatscreen. My television has a 2.5" diameter black spot on the far left side about 4" from the bottom of the screen, Also we have a dark transparent band across the bottom...
Sorry Sir but your LCD TV got wet... it can be splash with too much water, an animal urinate on the panel, etc....
this kind of black spot is caused when the LCD Panel Terminals got wet, this terminals are located at the lower side of the LCD Panel.
Sep 15, 2010 | Televison & Video
My tv screen got wet and now there are black
try a hair dryer first back and forth on hot (don't melt it), DLP screens cost about $200-$400 to buy I work for a service center and have replaced them before. alot of screws around the cabinet, if you take it apart to clean it try using a damp rag (with water) or monitor cleaning kit.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 02, 2009 | Samsung DLP HL-P5663W 56" TV
50 in philips projection tv
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly.
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products GA_googleFillSlot("TL-IMU-Article"); b3342371.3;abr=!ie4;abr=!ie5;sz=300x250;ord=[timestamp]? can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
  • Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press hard on the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
Jan 29, 2009 | RCA P52926 52" Rear Projection Television
JVC HD-56G886 56INCH REAR PROJECTION TV
I fixed it!!!! If you can open one of the sides (on the JVC there is a little door with a screw), then you can clean the projector lense in the middle on the bottom. It kind of looks like a big light bulb. It seems there is just dust on the glass that is projected onto the screen. We had a big gray spot and cleaned it with a damp glass cloth and Ouila! It disappeared. I scored MAJOR brownie points with my husband for this one! He wanted to replace the TV!
Sep 25, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Front screen
HOW TO CLEAN TV SCREEN;
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press ******* the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
Hope this may help;
DON'T FORGET TO RATE:
Sep 06, 2008 | Toshiba 55H70 55" Rear Projection...
Cleaning screen on my 1080i hd panasonic????
GA_googleFillSlot("TL-Leader-Article"); Hope this may help; DON'T FORGET TO RATE;
Aug 31, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Dark Blotches
This is probably caused by dust, either on the mirror, lens, or possibly inside the light engine. There is a 5" dia hole on the side of the back of the tv where you can take out one screw and take the door off. this is just big enough for you to put your hand through to clean the mirror and lens. Hope this helps.
Mar 30, 2008 | JVC HD-61FN97 61" Television
Mitsubishi WD57 57" HDTV
I would talk to the service manager at circuit city and call Mitsubishi... if all else fails call better business beaura
Jan 04, 2008 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
236 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
