Question about Acer n30 Pocket PC
Install android on acer n30 - Acer n30 Pocket PC
I need an n30 handheld manual. also how do i
You can download the n30's manual from this direct link. If it doesn't work for you, please, let me know. I'll try my best to download it and upload it to some other file server for you.
Cheers! Carlos
Apr 13, 2010 | Acer n30 Pocket PC
Acer N30 PDA charging problem
My PDA n30 is not a year old yet - when I put it to sync and charge everything looks fine but when I unplug it does not stay charged - it blacks out straightaway.
Please help
Jun 09, 2009 | Acer n30 Pocket PC
Acer n30 Screen Tap Freeze
Sounds as if the touch screen membrane is defective, which is a darned nuisance, but not impossible to fix .... if you are confident of dismantling the n30, you can buy a new touch screen membrane from Ebay for about 4 pounds/6 dollars.
It is a very skilful job to remove the old touch membrane from the actual display screen below it, not really for a novice, and all internal components are very delicate, so i suggest you find a tame technician before you buy the new membrane. The touch membrane connects to the motherboard via a tiny flexible 4 or 5 pin membrane ribbon cable, it's a miracle of miniature engineering inside the n30, so do ve very careful if you decide to do it yourself, best of luck!
Nov 22, 2008 | Acer n30 Pocket PC
Acer n30 wlan card
If your router has wireless broadcasting. Check all the settings in your router. Add the MAC address of the WIFI Card to your routers Wireless settings and also maybe in your firewall settings in the networking of your router. Be sure to add the WEP key when you connect to your router. Check your security settings.
Aug 26, 2008 | Acer n30 Pocket PC
Need new charger and battery and new pen
ebay is your best bet...
Try www.ebay.com and on the search space, copy and paste on the following ebay Auction IDs (just paste the number I give you):
Battery:
eBay Auction ID: 270215466248
Description:
1.5A Battery for Acer N30 N-30&Yakumo 1038006/PS1020#1
Approx. 7GBP = 13USD
Stylus (pack of 3):
eBay Auction ID: 280204418443
M509 3 pcs stylus touch pen for acer N30 N 30 PDA
Approx 1.5GBP = 3USD
Universal Travel Charger:
eBay Auction ID: 270216695513
Travel Charger for Acer N30 (UK/EU/US/OZ Charger)
Approx 7GBP = 13USD
These prices do not include shipping which may vary depending on your location... (these items usually ship from Hong Kong).
PS: these are auctions so the designated items may only be available for a limited number of days...
Hope this helps
Mar 03, 2008 | Acer n30 Pocket PC
Would u plz tel me wat to do
I looking for Charge Cable for Pc Pocket Acer n30-B
Dec 30, 2007 | Acer n30 Pocket PC
Acer N30 battery problem (even new battery does not last enough)
try checking your power saving options, you can drop down the backlight a little lower to extend battery life. Also you can lower down the volume of the system sound and check if the bluetooth is on, then turn it off. Recharge it and then check if the battery life extends. You also need to occasionally soft-reset the n30
Oct 21, 2007 | Acer n30 Pocket PC
Acer n 30 doesn't make phone calls
do you want to use the N30 over WAP/GPRS, dial-up land land line or a GSM modem. The N30 does not have any kind of modem or cellular capability built-in, only 'blue tooth' so depending on your requirements you will have to obtain a sutable external device. You are not compelled to use a mobilephone hand set though.
Jul 09, 2007 | Acer n30 Pocket PC
Acer n30 Pocket PC Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
