Question about Mitsubishi WT-46809 46" Rear Projection Television
Wavey line and double image
There is a red wavey linv over the top 1/3 of the screen. There are double images in red in the bottom half of the screen. What causes this and how much to fix?
  • Mitsubishi Master
  • 3,459 Answers
Your TV most likely has a problem in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a Wavey line and double image - 0667c5f.pnglem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on May 22, 2009
I have a Mitsubishi WS-65869 65 in. Rear Projection Television and it has created a wavey line and has distorted the image. i have a picture of it i can send. Any help. i can send pictures of screen.
If you see separation of colors (red, green) in this wavey line most likely you have problem with convergence circuit. Two convergence amps have to be replaced. They located in a middle of the TV boards attached to big aluminum radiator and they part number starts with letters "STK".
I would recommend to let professional with this repair. Should cost you about $250-$300.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi WS-65869 65" Rear Projection...
I SEE DOUBLE THE PICTURE AT THE TOP LEFT IS WAVEY
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 28, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Phillips 60" projection screen tv. Wavey lines at top and bottom of screen center is very blury and wavey almost looks like 3d. Audio is fine. How do i fix this
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
Jul 19, 2010 | Philips 60P8341 60" Rear Projection...
Pictureis blurry and bottom of screen is wavey
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Televison & Video
Component 1 has wavey lines all other conections
For component 1 on the tv I just changed from 1080i to 480i on the Verizon Fios set top box and that corrected the problem...
Aug 29, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Blue outline on the top half of the picture on my Hitachi 51F500
your convergence ic is going bad. usually worth the repairl.
Jun 04, 2009 | Hitachi 51F500 51" Rear Projection...
Watching TV and top 1/3 screen ghosted by colors
on this type of tv each gun is controled by hor.and ver. chip together. it is on the board that controls the convergence of the tv. some manufactors have recalls on problems like this. i dont know if this one does but it may. you can check with mitsub. i do know that this part is about 250.00
Jan 02, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Red wavey lines at bottom fo screen
Red wavy lines across my screen...model HCL4715W Samsung
Jul 11, 2008 | Televison & Video
Mitsubishi WT-46809 46" Rear Projection Television Logo
245 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
