Question about ViewSonic VFD820-50 - digital photo frame
Won't turn photos the correct way - ViewSonic VFD820-50 - digital photo frame
Engine won't start distributor won't turn
no your timming belt broke!!! now if you have a interference engine you will need a new car!!!
the only way to know is if you search your year make and engine size of your car..
you better hope its a non interference engine .. than just change the belt.. good luck. this is a basic timming belt photo . engine-start-distributor-turn-rbr12kxjqsqvwnu2khrshnjz-4-0.jpg
Jun 12, 2013 | Cars & Trucks
JUKI BOBBIN THREAD WILL NOT FEED
Most machines require that the bobbin in the case unspool in a certain direction its considered common knowledge I guess because it doesn't seem to be written in the text of manuals... but is indicated in the photos. make sure it's unspooling correctly.
Secondly. Please make sure you have the correct needle for your machine. Some machines do not use a 15x1 (most common needle) Let me show you. (see photo below) Clearly the 241x1 won't fit into your machine. BUT the 15x1 will go into the machine that requires the 20x1.... and the result is it won't pick up the bobbin thread.
Start there. Then check your timing.
Sep 05, 2012 | Sewing Machines
Camera won't turn on when plugged into Mac to download photos.
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Feb 22, 2012 | Cameras
Outdoor cfl lights come on and won't turn off. i just installed two brand new intermatic 4121c photo controls on 2 lights and the lights stay on all the time.
I don't have repair for defective product.
Two cfl lights will not exceed load rating of photo-eye
1) Put black tape over photo eye and see if lights turn off. Do not expose photo eye to direct sunlight. Turn photo eye away from possible source of light at night.
2) Wiring is suspect.
Open following link:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#photo-eye
3) Reversed polarity is next suspect.
Cable from breaker box has black, white and ground wires.
Separate wires, turn power ON, stand on dry boards and never on dirt or ground, do not lean or touch anything: test each wire to bare ground wire. Tester lights up on Hot wire. Tester should light up one-and-only one wire as Hot. Hot wire connects to photo-eye black wire.
Next, test Hot wire to other wire and tester will light up on neutral. Photo-eye white wire connects to Neutral.
4) Short to ground. Disconnect ground wire and see if there is a short running back to busbar that is completing circuit.
5) K4100 series is rated for ballast. Replace CFLs with regular light bulb and see if there is difference.
This should not be the factor, so add a comment if you discover this photo eye cannot handle CFLs.
6) Contact Intermatic.
http://www.intermatic.com/customer%20service.aspx
Aug 10, 2011 | Intermatic K4121C Photo Cell Control 120 V...
Ixus 430 will take photos when flash is turned off, but will not take photos when flash or redeye is selected
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try. (Hint, make sure that all the screws around the perimeter of the case are present and firmly seated.)
Jun 01, 2011 | Canon PowerShot S410 / IXUS 430 Digital...
My camera does not respond when i try switching it on. The battery is charged and cannot still turn on. Could it be the battery?. Please help me.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
May 30, 2011 | Agfa Photo Optima 100 100 Megapixel...
My Canon pixma ip 4000 won´t print. The light at the turn on button blinks five times orange and then comes one green blink. I have tried to clean the print head but that didn´t change anything....
this indicates a the print head is not installed correctly or is faulty.
if the green and orange is alternating 5 times then it is caused by the sheet feeder.
Dec 08, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Printer won t turn on
Try pushing the on/off button after the lights go off and it should turn on. If not, you have a hardware problem and have to call Kodak tech support.
Feb 27, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
ViewSonic VFD820-50 - digital photo frame Logo
26 people viewed this question
Top ViewSonic Photography Experts
Tony
Are you a ViewSonic Photography Expert? Answer questions, earn points and help others
