Question about Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung 204b backlight
Bulb replace
4 Suggested Answers
  • 732 Answers
SOURCE: How to replace backlight in Samsung 204B
asachs493, First go to YOUTUBE and view the longer and more informative video clips of "lcd monitor disassembly" and "lcd monitor repair" to see if you really want to do that!!! Also visit all of these sites:-- www.ccl-la.com/badcaps.htm and www.badcaps.net , www.lcdparts.net Remember tihs!! Replacing "cold-cathode-fluorescent-lamps" may not be the problem!! Your problem may be in the circuit that generates the high voltage that starts and sustains running voltage for the lamps!!! It's called an "electronic ballast circuit" and because it is in a lcd CCFL monitor, it is refered to as the "inverter circuit" (dc to hi ac voltage) The new "curlieQ CFL energy efficient, screw-in light bulbs have "converter" electronic ballasts!! (ac line to hi ac voltage) Just FYI. 12fixlouie
Posted on Feb 02, 2010
  • 1684 Answers
SOURCE: Backlight going bad?
This is not the backlight its the power supply board. We have a repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ The repair consists of replacing 5 capacitors on the power supply board. If you can solder then you can do this repair. If you don't want to do the repair we do offer a repair service, you can get this information here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Apr 28, 2010
Testimonial: "I know this has been quite some time ago, lol. I did since replace the capacitors and still had an issue. There was another component that went bad (can't remember what) which was too expensive to replace given the price reductions on newer bigger monitors. Thanks for your help!"
  • 732 Answers
SOURCE: can i get a copy of the power supply diagram for
jose54tony, Schematics would only be available from Samsung. Rarely do they let them out of there tight grip!! You may need to look at the smps board and inverter board to find bad transistors that may have also died (muerto) when the electrolytic filter capacitors failed. 12fixlouie
Posted on May 20, 2010
204b backlight getting dim
change the inverter if it does not work ,you will have to change the backlight bulbs or you change the screen
Jun 22, 2013 | Samsung SyncMaster 204B 20.1" LCD Monitor
SyncMaster 204B screen appears in 5 min after turning monitor on. First 7-10min screen is dark and slowly increases brightness. The picture becomes normal in 15-20 min and all is OK until the monitor is...
How long have you had the monitor. It sounds like a defective backlight. Usually when the circuit driver for the backlight starts to go bad, the monitor will blink. If this is the case, eventually the monitor will not turn on at all.
Jan 12, 2011 | Samsung SyncMaster 204B 20.1" LCD Monitor
I am looking for the pdf file Samsung 204B fix
A full repair guide with dis-assembly and repair instructions is available at:
I hope this helps, if so please rate my solution.
BuddyMc
Aug 03, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Can i get a copy of the power supply diagram for samsung 204B syncmaster ,i replaced the capacitors that were inflated in the power supply and in the inverter but the backlight not turn on. i want to know...
May 20, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 28, 2010 | Samsung SyncMaster 216BW Monitor
Backlight failing
It can be due to failure in the backlight inverter circuits, failed caps in the power supply (which is more likely to be), bad lamps. See example of faile Samsung monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 16, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
No backlight on Samsung 710N LCD Monitor
No, it is not easy to change the backlight on an LCD panel. The backlight is an integrated part of the LCD panel itself. The backlight for LCD monitors is also model and manufacturer specific, so there's no easy place to order a backlight to do it yourself. The good news is that your Samsung monitor should come standard with a 3 year warranty, so if it's less than 3 years old, you can call Samsung and they'll repair/replace it for free. If it's over 3 years old, then you may need to repalce the monitor... or pay to have it repaired.
Mar 07, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
How to replace backlight in Samsung 204B. Monitor (3.1 yrs old) takes 10 min to warm up.
Feb 02, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung 204b my screen flickers and is dim on wakeup
Your backlight power supply is about to die. Check out our web page at: www.ccl-la.com/badcaps.htm We have a full repair guide and parts list to do the repair.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Sep 27, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
Jul 24, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
16 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
