Question about Philips Magnavox 32PS55S 32" TV
Philips Magnavox TV turns itself off and on
Model # HD2528C122
Last night the TV turned itself off and on repeatedly. Each time we turned the TV back on it would immediately shut off. Using the buttons on the TV itself we found that the power button is doing nothing but bring up the channel display. The 'Volume Up' & 'Channel Down' buttons turn the set off but it will instantly turn back on. The other buttons work fine. The sound is gone. Remote control doesn't want to work for it (it's a Direct TV remote which still controls the satellite box perfectly fine).
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
Posted on Nov 03, 2013
4 Suggested Answers
  • 121 Answers
SOURCE: Power button changes channels and volume does not work
bad solder connections. front control panel.
Posted on Dec 02, 2008
SOURCE: Controls not working on Philips 28" TV
We had this problem with a 28PW6515. The control would work for 30 seconds after switching on, then nothing. It was diagnosed as the "glue chip" which handles all the control functions. About £200 to fix it as it's a surface mount chip.
Posted on Jun 22, 2007
tvtek
  • 1284 Answers
SOURCE: TV Volume turns down by itself - Philips 29PT8319 Matchline 27"
Most likely the volume down button on the front of the TV or the switch that it activates is sticking. Should be an easy fix otherwise.
Posted on Feb 05, 2007
Samsung TV model LN32A450C1DXZA, after turning the TV on it will turn itself off shortly after and then turn itself back on shortly thereafter. Then it repeats that several times before staying on.
If the tv is still under warranty, this can be repaired at no charge.
However, if not under warranty, you will need to have the CAPACITORS on the main power supply circuit board tested (or replaced).
The capacitors responsible for the power supply can sometimes fail - open the back panel. If the capacitors on the main power supply board look too fat, or signs of burning near the solder joints, then you've found the problem.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Samsung LE Televison & Video
Magnavox 19" TV shuts itself off.....won't stay on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jun 04, 2009 | Philips Magnavox 27MS343S 27" TV
Phillips magnavox
Could be an open internal fuse or power supply failure
Mar 18, 2017 | Philips Televison & Video
50' plasma, does not turn on,
still nothing, tried twice last night and second time tv worked, this morning nothing
Feb 14, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
No picture???
Hi
You have defective Vertical output IC, Replaced the Vertical IC that is defective.
Thanks!
Dec 04, 2008 | Philips Magnavox TS3260C 32" TV
TV turns itself off
I currently work in teir 2 support for magnavox philips and this is a service issue i see alot on random sets hope this helps sorry fotr the bad news.. David
feel free to e-mail me with any other questions at davidsylvia411@hotmail.com thanks.
Nov 19, 2008 | Philips Magnavox 27MS343S 27" TV
36 magnavox tv shuts off by itself
MAGNAVOX TV ONLY. 5-10 SECONDS AFTER TURN ON AUTO TURNS OFF-NO LIGHT STAYS ON-I AM FRUSTRATED BUT IT SEEMS LIKE THE OFF ON SWITCH JUST CLICKS BACK TO OFF-ALSO DOES SAME THING BY REMOTE
Jan 16, 2008 | Philips Magnavox MS3652S 36" TV
TV turns on at odd hours by itself
GO to Magnavox Owners Manual---on the www.
Oct 04, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 32PS55S 32" TV Logo
553 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
