Question about Kenmore Elite HE5t Washer
Kenmore elite 110.47781701 - main drum bearing gone
Main bearing for drum has a squeak that started of slow and over 2-3 months has grown to be load and likely a huge problem. It is no longer a squeak but we stopped using it because the bearing is obviously totally wiped out. We want the repair and place parts ourselves
jsrock516
  • 5911 Answers
SOURCE: Calypso kenmore elite - problems trying to wash a load
This is usually a symptom of a bad motor control board which located under the console. I had the same problem. You can open the console by removing the three screws in the back and lifting from the rear first. The console will pop off. In addition, if you look along washer top front edge in the seam there is a retaining clip about 2 inches in from each side. Using a putty knife, push in on each clip while lifting and the top should pop up. There will be a tech sheet affixed to the front wall of the washer between the wash tub and case. This tech sheet will give you all the guidance necessary on how to perform tests to prove whether or not the motor controller is at fault, or if the pump is at fault. I believe you may have a motor controller problem, though. Another possibility is getting something caught in the drain pump reservoir. This could binding the pump. Let me know if any of this is helpful to you.
Posted on Aug 16, 2007
  • 3 Answers
SOURCE: Kenmore Sedona Elite 3.8 Cubic Foot HE4t Washer (Front-Loading) 45089
open lower front with a starshaped bit(screwdriver) three small screws, to get to white plastic cleanout (easy to turn by hand)may have someting stuck in it. about a gallon of water is there so have two big towels ready to soak it up.
Posted on Dec 29, 2007
aborcass
  • 2651 Answers
SOURCE: Kenmore Elite Quiet Pak 1 Model No.110.26942503
yea if valve is leaking into machine when not on youll need to replace the valve. part number for the inlet valve 3979346 . you can find a diagram as well as a part list at sears.com.
http://www.searspartsdirect.com/partsdirect/retrieveModelActionHome!retrieve.action;jsessionid=UFaeD4IGtGIcYFtrZmj97w**.shcapp3205?modelNumber=110.26942503&pop=flush
Posted on Mar 26, 2008
  • 1028 Answers
SOURCE: Kenmore Elite HE3T door seal tear
tear may be from pulling something across it with sharp edges..to replace seall not major job front part of seal held in place with spring ..remove and pull boot away from front edge inlet tub slides out of boot opening rear held in place with LARGE screw clamp a little patience is usually all that's needed ..did 2 today
Posted on Jul 31, 2008
SOURCE: Squeak in Kenmore HE 2plus front load washer when drum spins
We opened the top of the washing machine and there are some suspension springs.
All it needed was some lubrification. Prior to putting the top back on we put a load in
and watched it and there was no more noise.
Posted on Jan 21, 2009
Dryer slow to start squeaks
The drum is belt driven, there is a belt tensioner on it too. You need to replace the belt.
Feb 25, 2015 | Kenmore Elite HE4 Electric Dryer
Kenmore elite front load dryer squeaking and burning smell
you have a bearing in the drum support that has frozen and now the rubber wheel is burning up. The bearing needs to be replaced ASAP. You could damage the dryer if you continue to use it.
Feb 16, 2014 | Dryers
How to remove objects stuck in the drum making noise during spin cycle
You have to pull the back off or how ever to get into the main body and see if there is an object jammed up, or your bearings could be going out
Jul 27, 2012 | Kenmore Elite 45986 Front Load Washer
Kenmore elite heavy duty king-size capacity model 110.2302: tub spins, but makes a loud banging noise as if the load is off-balance, even when there is no load
I'm sorry to say, this almost certainly means that the main bearings on the drum have failed. This is NOT a job for the uninitiated DIY enthusiast as it will mean stripping the machine and removing the drum from the chassis, splitting it, removing pressed in bearings and then sourcing and re-fitting new bearings.
To be frank, the cost of a bearing set (if they are replaceable , and most are) will be about £20 (($30) or so. But its a long and horrible job if you haven't done it before. I know professionals who claim they can do a bearing change in under an hour, I've done a few and it takes me about 2 hours by the time I
Jul 05, 2011 | Washing Machines
My Kenmore elite front load washer leaves tan stains/marks on many of our clothing. Is this mildew/ fungus problem. I wash with hot water and vinegar approx. 1 a month.
this sounds like the bearings are wearing out,this can cause the grease between the bearrings to come into the washer,to check the bearrings open the door and you will see the silver drum inside place your hand at the top of this and gently lift it up if you feel a knocking noise then thats a sign that the bearrings have gone,hope this helps you.rgrds,paul
Jul 07, 2009 | Kenmore Elite 45986 Front Load Washer
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Drum Noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
hjdj
Feb 22, 2009 | Kenmore Elite HE4 Electric Dryer
Squeaking noises are hard to find unless u open it and pin point where its coming from.. you can open the back cover if you are comfortable doing so.. let it run to see if you can heard... sometimes the bolt holding the pulley to the drum is loose and need to be tighten. Other possible is the shocks came loose or when install new.. the shipping materials were not remove..
Dec 13, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE5t Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
