Question about LG Washing Machines
Need Directions on how to use machine
We need instructions on how to use the LG Tromm.
  • 34 Answers
Hello maemaez4,
I will put a link below which will take you to a web page with a downloadable PDF owners manual for the Tromm. You will have 4 different options,( WM2487HRM, WM2487HRMA, WM2487HWM, WM2487HWMA ) just click on the model of the one you have and it will give you the correct manual. Hope this is what you were looking for.
http://us.lge.com/support/download/search/1000000376_EN_OM_WM2487.jhtml
Thanks,
edgin96
Posted on May 19, 2009
2 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: Need Instruction Manual for LG Tromm WM2233HS Washer Machine
and it's all yours now..click here
Posted on Mar 02, 2008
Lg tromm wd 85485 error code cl mean ?
Possible that the drain valve is clogged if the inlet line is working and so you need to remove the drain and back flush.Also check after the power plug is removed for few hours and see if the fault resets to start the machine only to show the error a few minutes later. if so clean the drain lines, check the inlet flow and the door switch.
Dec 15, 2011 | LG Washing Machines
LG Tromm WM2277HW will not spin both directions, LE error.
clean filter check that its drained all the water out any blockage and the machine will not spin
Nov 28, 2011 | Washing Machines
My lg tromm front load washer was recently reinstalled after being in storage. After plugging it in it makes no effort to start up. This happened once before when I unplugged it but it eventually...
Check plug fuse , next if machine not starting assuming elect supply ok you need to fit a new door interlock switch or reset Childlock if it has been put on .......Happy new year from Scotland....
Dec 31, 2010 | LG Washing Machines
How do you take the top off of a LG Tromm front load washer?
theres three screws in the back that need to be removed. then you push the panel towards the back wall, it slides back then you can remove it. Good luck. _MJ_
Apr 22, 2010 | LG WM2688HWM TROMM SteamWasher
My lg tromm washer is reading LE. why
le is code 4 faulty motor or motor sensor. if u r confident, change sensor first. 95% of the time it is sensor. if u need more help please reply back
Apr 06, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washer isn't drying anything very well. getting a oe message lg tromm wm2277hm
the OE message means that the machine has not fully drained out all the water. you can try to re set on drain or you may need a service call. hope this helps.
Oct 15, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What is the stain cycle do?
http://us.lgservice.com/index_b2c.jsp click service click owners manual and put in that it is an appliance, dryer and your model # click on the pdf owners manual you can copy this if you like or just read it and save it to the computer
Feb 16, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
394 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
