Question about Mamiya K/L 65mm f/4 RB Lens
Mamiya-sekor C 65mm lense
I have mildew in the first part of the lense looking from the front.
How do I get access to the first lens glass to clean it...
Tried undoing the the outer ring, next to the focusing ring, now the lens seems loose...
Can anybody help... camera needed for tomorrows shoot...
Dave Boulter
  • 216 Answers
Any luck with the lens?
Need help?
Posted on Dec 23, 2007
How does one dismantle a mamiya 120mm mf macro f4 lens
Do you have a lens collimator and other equipment necessary to ensure proper alignment when reassembling the lens? If not, then take the lens to a good camera shop and have a properly trained and equipped professional do the job.
Dec 19, 2013 | Mamiya Cameras
Manual pdf
Try Retrevo
Nov 21, 2013 | Mamiya RZ67 50mm F4.5W Lens
How to fix the lens, how to open it, need to fix the shooter speed, please someone i will try to explain better if someone knows something
The problem with this Sekor shutter units is that they become stuck by dirt, rust or grease and sometimes is impossible to fix it. In this model the lens unit can be seriouslly damaged if you try to charge it even it is so hard to move.
Oct 21, 2013 | Mamiya Vintage Auto-lux 35 Camera W/ Sekor...
To repair the obturator the lens its a fixed lense how to open and fix it?
To open the mechanism you need firts to take out the front group lens (sometimes loosing 3 screws placed around the front ring).
After you take the front gropu out there is a nut that holds all the shutter unit attached to the camera. Turn it to the left to placed it out and then take the mechanism off. Be sure the are no other parts connected between shutter and camera before pull it out.
Oct 13, 2013 | Mamiya Vintage Auto-lux 35 Camera W/ Sekor...
My camera shutter is stuck and all I see through the lens is black?
Need servicing from the service center. They disassemble the camera & unlock the shutter from internal side.
Aug 09, 2012 | Mamiya/sekor 500 Dtl 35mm Slr Film Camera...
Hi I wonder if you could help me ? I have inherited two lenses. One is a mamiya/sekor SX 1:28 f=135mm. This is a no 41974. It also has a detachable screw lense on bottom APS Auto Teleplus 2X which I am not...
The Tessar lens has a secondhand value of about £25GBP. The other lens may be slightly harder to value as i am not familiar with it. One way to find a value is to use ebay and search the completed listings.
Jan 16, 2010 | Cameras
Fungus in the lens
These lenses arn't designed to be taken apart.
A camera specialist may help but they should alwys be kept dry and at room temp never warm and humid. Silicate gel in your storage bag also prevents this from happening.
Good luck
Apr 16, 2009 | Mamiya RB67 Pro SD Medium Format Camera
Fauly aperture ring on mamiya/sekor 135mm f2.8 m42 lens
Does the aperture work when you turn the ring and push the aperture pin on the mount in? The lens should close down to the set aperture when you do this. If it does, then atleast the lens is useable.
What is missing is the detent for the click stops. This is a spring loaded ball bearing that 'clicks' into notches inside the ring. If this is broken or missing, finding a spring the right size might be a challenge, the ball bearing less so. To remove the ring and base, unscrew 3 screws coinciding with the 3 notches in the back plate, visible when you set the ring to f8. the back should lift off easily. don't lose the screws. The ball bearing, if it is still there, should protrude from a small hole in the lens barrel in line with the f stop index mark on the lens. Good luck.
P.S. The above is based on how my 200mm is designed so I'm making some assumptions that the 135mm is put together much the same.
Mar 27, 2009 | Cameras
Manuel lens dos not turn any more
most likely some of the gears are offline or collapsed. when that happens it gets difficult to turn. you could send it to mamiya for an estimate or to
Dec 31, 2008 | Mamiya 35mm f/3.5 Lens 645
Mamiya K/L 65mm f/4 RB Lens Logo
457 people viewed this question
Top Mamiya Cameras Experts
Tony Parsons
Tony Parsons
Are you a Mamiya Camera Expert? Answer questions, earn points and help others
