Dell inspiron n4030 - Computers & Internet
    Top Expert:
  • Computers & ... Master
  • 22,114 Answers
What is the problem?
Posted on Dec 31, 2013
  • 236 Answers
SOURCE: I have a dell inspiron
If you have a separate numeric keypad, then use that with the Alt key to type ñ. Otherwise, you can try using NumLk which activates a part of your existing keyboard to input numbers (NumLk is active when the little padlock icon with the number 1 in its middle is lit up). You may need to press the Fn key along with the key marked NumLk to toggle NumLk. Once NumLk is on, then you should be able to use the numeric keypad portion of the keyboard to input alt + 164 to type ñ. Hope this has helped you.
Posted on Apr 24, 2011
javeedcare
  • 316 Answers
SOURCE: there is graphics card in
DOWNLOAD THE DRIVERS FOR THE CARD OR USE THE CD THAT CAME ALONG THE PC.
DOUBLE CLICK ON THE ICON AND IT WILL START THE INSTALLATION. BE SURE TO HAVE THE RIGHT DRIVERS FOR YOUR WINDOWS VERSION.
THE BELOW LINK WILL BE OF HELP.
http://support.ap.dell.com/support/downloads/index.aspx?c=in&cs=indhs1&l=en&s=dhs
REGARDS.
PLZ. DON'T FORGET TO RATE THIS COMMENT
Posted on Jul 07, 2011
  • 998 Answers
SOURCE: Downgrade bios A07 to A02 of dell N4030 for
Never a good idea to downgrade BIOS revision. Could cause you to have to replace the system board if it doesn't install properly.
Posted on Aug 05, 2011
Geekman
  • 32281 Answers
SOURCE: my laptop is dell inspiron N4030 and battery does not last long
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Posted on Apr 02, 2012
bronk50
  • 27725 Answers
SOURCE: any time i switched ON my dell inspiron N4030 laptop, it comes ON as if it want to boot and would go OFF almost immediately, how do i solve the problem?
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery.
For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter.
In most situations it's a bad battery.
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
if it does not start in safe mode it could well be a hardware problem
Check all power and data leads from motherboard to hard drive and all of your cd/dvd drives make sure connections are secure dust free and not faulty
computers need all power and data to travel through every working device and to finish its cycle
so any faulty lead will end in computer error or shutdown / fail to boot or to reboot on a cycle
make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets
some motherboards cmos batteries are soldered in
might be getting hot check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
or it might even be a virus until you have your laptop up and runing you wont be able to run your antivirus software.
another possible reason could be a memory dump running to many programs at the on time placing to much strain on the CPU central processing unit installing more ram will overcome this or uninstalling unecessary programs the other option.
If you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible
Hope this helps
Posted on Nov 01, 2012
Dell inspiron n4030 keyboard not working
Shapsog,
You may need to turn off the Filter Keys option. Follow the steps below to turn them off.
Go to
1. Control Panel
2. Ease Of Access Center
3. Make the keyboard easier to use
4. Uncheck the "Turn on Filter Keys" option
You also may need to Check to be sure you don't have Sticky Keys enabled.
BY PRESSING THE SHIFT KEY FIVE TIMES
Without pressing other keys, press the SHIFT key five times to enable Sticky Keys. A window will be displayed asking you if you wish to turn on Sticky Keys Clicking Yes will enable Sticky Keys or click No.
If none of these steps work you may need to replace the keyboard or plug in an external USB keyboard.
Thank You,
Dell-Jesse L
Dell Social Media and Coimmunities
Oct 19, 2015 | Dell Inspiron N4030 14 Inch Notebook...
Forget my dell Inspiron N4030 Bios Password Service tag= H4Q4QP1
See this... http://www.tech-faq.com/reset-dell-bios-password.html
Jun 29, 2014 | Dell Inspiron N4030 2.13GHz 4GB 320GB...
Dell graphics card
srinivas mantha,
Unfortunately, you cannot upgrade the internal video card on this system. It is soldered to the motherboard.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Sep 03, 2013 | Dell Computers & Internet
Dell Inspiron N4030 asking me for BIOS password, i dont even rember making one.....I cant Boot to install a new version of Windows and I'm getting P-Offed!! Help please
You may have to find the reset disk or may have to do a clean instal in which case is not fun however
If there was no passowrd created by you always remember to go the easies route >>> My advice look @ the operation manual if no luck then at that point you will have to >>>>> ; )
Dell XP = Ctrl+F11Dell Vista = F8
EEEPC = Esc
Compaq = F11
HP Desktop Vista = F11
Emachine = F10
Acer = Alt+F10
Every manufacture has or uses different Function Key combinations to do a Factory Default Recovery. Also if it didn't come with disks there is normally a program in the menus to create your own set of recovery CDs. This must be done before you ever put anything on the recovery partition d: , if you used d: for anything you need to remove what you put there or the recovery will not function.
Nov 28, 2012 | Dell Inspiron N4030 2.13GHz 4GB 320GB...
Forgot Dell inspiron n4030 administrator password
You can read this 2 helpful posts:
How to Hack a Dell Laptop Password?
How to Reset Dell Password?
I have used Windows Password Key 8.0 to reset dell password, and found it really helpful. You can have a try.
Mar 12, 2012 | Dell Inspiron Computers & Internet
Driver DALL PC INSPIRON N4030
Drivers and Downloads for Dell Inspiron N4030 Notebook PC, from Dell Support,
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&SystemID=INSPIRON_N4030&catid=-1&impid=-1
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 30, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
Computers & Internet Logo
David Payne
David Payne
