Question about AudioBahn A18001DQ Car Audio Amplifier
Audiobahn 1800 watt amp has an error of LO and isn't working righ
The amp has worked fine for over a year. It just starts a rythmic cycle of bass sounds even when no music is playing. It sounds like background noise, not very loud. I have blown my right side door speakers although they are not hooked up to amp, they do go through the head unit. I get a code onmy readout that says LO. Any help would be appreciated. Thanks
    Problem Solver:
  • 7 Answers
You are not getting your amp enough volts try checking your ground or power cable
Posted on Apr 20, 2010
  • 221 Answers
Disconnect the sub, and try a different sub or speaker. It sounds like the sub is blown or shorted, which is causing the amp to go into load-protection mode. This happens when the speaker load is lower than the amp can sustain (usually 2-4ohms). If you disconnect the sub or speakers, does the error reset and clear itself?
Posted on May 19, 2009
Need more bass
Bridge it. Should be marked on amp. According to specs should get u the power u need. Amp max 1500 watts. at 2 ohms. Speaker max is 2200 watts at 4 ohms. Turn amp down and adjust to your own taste. trust your ear man.
Jul 12, 2009 | Car Audio & Video
Remote bass control short
It Could be Eiher Problem Make Sure The Remote our using is thew same brand as the amp its plugged in to
May 27, 2009 | AudioBahn A4002T Car Audio Amplifier
ABR100T Audiobahn Bass remote not working correctly?
i had the same thing happen to me on my 2300hct audiobahn. it turned out to be the remote. but soon after my amp went dead. i than switched to JL no problems since.
but i still use audiobahn immortal 12's.
Apr 11, 2009 | AudioBahn ABR100T Remote Bass Control For...
Help me with my system
More information is required to start solving your problem. (ie. your make and model of "1500W amp", the voicecoil configuration of the kicker and Audiobahn 15's, and why you want to encorprate 2 crossovers in your system)
Seems as If you have a system without a plan.
Head unit?
More info necessary to give you the best use of your components.
Jan 14, 2009 | KEF Audio PSW 2150 Speaker
Wired remote bass control knobs
I'm wanting to know the same thing... But be careful on the pin out of the control you get.
I have an audiobahn 2300HCQ amp... Before I had the 1800. The 1800 came with a remote with 6pin remote cord. I got the 2300 used and did not get a control for it. The plug on the 2300 is a 4 pin plug... I can't figure out how to cross it over correctly to get the 1800 remote to work on the 2300.
I have tools to crimp an end... Just can't figure out the color pin out.
Apr 16, 2008 | Car Audio & Video
Amp a2801q
Audiobahn A2801Q
Product Description:
Class A/B MOSFET Circuitry
200 watts x 2 @ 4 ohms stereo
280 watts x 2 @ 2 ohms stereo
560 watts x 1 @ 4 ohms mono
Volt Meter With Blue Illumination
PWM MOSFET Power Supply
Double Sided Glass Epoxy Circuit Board
THD: 0.02%
S/N Ratio: >100dB
Frequency Response: 10Hz - 40KHz (+/- 1dB)
Variable 18dB Hi-pass Crossover: 90Hz - 750Hz
Variable 18dB Low-pass Crossover: 30Hz To 120Hz
Bass boost @ 45Hz: 0/18dB
Subsonic Filter: 20Hz to 50Hz
RCA Throughput Connections
3-way Protection Circuitry: Thermal, Short Circuit and Overload
Cooling Fan
Cobalt Blue Illumination
High gloss Chrome Plated Finish
Nickel Plated Block Terminals
Dimensions: 2"(H) x 12.75"(W) x 15.5(D)
1-year warranty
Jan 02, 2008 | AudioBahn A2801Q Car Audio Amplifier
LIGHTS ON BUT NO BASS
Is the master/slave switch set to master? Have you tried feeding the signal into a different amp to make sure that there is signal reaching the amp?
Sep 18, 2007 | Car Audio & Video
Power & protect
my amp says Lo on the digital circle on top of the amp i have a mtx 9500 bridged to the amp and it cuts out at high volumes and suddenly please help
Dec 21, 2006 | AudioBahn A8000V 400W x 1 Car Amplifier...
Legaxy LA2098 2400 watt 2 channel amp
Humm.. Have you check your remote wire? If you know the amp is getting power for sure, diconnect your subs from the amp leave only the + - and remote hooked up. Check again if still same thing nothing, try taking a jumper wire to the batt terminal over to the remote terminal. This should let your amp kick on, IF SO your remote wire has a short some where. IF NO i would check your ground wire again and make sure its good and along with all your fuses. IF NO still might have internal damage. BUT if it did work dont leave it hooked up like that, it WILL stay on untill u remove the jumper wire. I just use this lil trick to help save time with trouble shooting. Hope this was helpful i had the same prob with my amp remote wire was bad
Nov 17, 2006 | Legacy LA2098 Car Audio Amplifier
AudioBahn A18001DQ Car Audio Amplifier Logo
174 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
