Question about Acer Computers & Internet
No sound through acer lcd monitor
The sound no longer works through monitor. it says; (digital audio s/pdif) is at 100% but still no sound.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 94 Answers
Make sure HDMI cable is connected.
Posted on Jun 04, 2014
2 Suggested Answers
  • 6 Answers
SOURCE: Inbuild audio speakers of acer LCD 193HQ monitor
There is no one good answer. This will require troubleshooting. Try connecting another source of audio into your monitor. For example, a mini-jack cable going from a portable CD player directly into your monitor would allow you to determine if the problem is on the monitor's end or the PCs.
Posted on Sep 04, 2009
I replaced my previous MIRO monitor today with an Acer S271HL. My PC has Windows 8.1. I can no longer get any sound.
Were the speakers part of the monitor or plugged into the side of the monitor.?..If so there may have been an amplifier in the monitor.. By replacing the monitor with one with no amplifier you have no sound.. The line output is not enough to drive the speakers ...you will need speakers with built in amplifiers that plug into a transformer plug and other green pin plug into the output on the computer.
Jul 06, 2015 | Acer 27" S271HL bid Full HD LED-LCD...
I cannot get any sound through my tv from my acer ao531 notebook i have a picture but no sound
Try these options
1. Click on sound icon in Taskbar and make sure sound is up on HDMI volume. If this doesn't exist-
2. Start => Control Panel => Hardware and Sound. Under Sound tab click on Manage Audio Devices, right click on HDMI tab and enable. Or this: Computers have two seperate systems - one for video and one for sound.
The only computer (or laptop) connection that carries both video and sound is HDMI. If you do not have a HDMI/DVI connector on the back of your computer, then you will have to use the VGA-composite or s-video connectors to display your PC's output on an external monitor like an LCD TV.
On both my HP and Dell laptops the display settings (Start/Control Panel/Personalize/Display Settings) allow two modes - single or dual monitor mode. Single monitor mode allows me to switch between any one of three possible video outputs - VGA-composite, S-Video or laptop screen, or a split-desktop (display spread over two seperate monitors). Dual monitor mode allows the same display on any two of three possible video outputs.
Switching is performed using the fn keys on the keyboard (fn key plus the F2, F8, etc. function key with the display marking). You guys use single monitor mode until you figure out what your are doing. Select VGA-composite or S-Video.
Non-HDMI sound to your TV monitor or sound system must be obtained from your laptop's Headphone or S/PDIF jacks. Headphone is stereo and S/PDIF is 5.1 surround sound. Headphone is electrical, but S/PDIF may be electrical or optical (laser light). You must set the sound jack that you intend to use as the default on the PC control panel (Start/Control Panel/Sound).
None of these connectors is two-way in the context of an LCD monitor - your PC cannot record a TV picture or sound from the external monitor. To accomplish this you must purchase a video converter box that converts cable TV or video+sound inputs to USB format usable by your laptop. Do this and you can turn your laptop into a Tivo recorder/DVD burner using Beyond TV, Sage TV or a variety of other software packages.
Mar 10, 2011 | Computers & Internet
How do I hook up my tascam fw1082 to a mixing board?
Hi, There are two ways you can connect it up. You have a TRS (Tip Ring Sleeve) monitor output that could be patched into the inputs of any analog mixer, balanced high level inputs.
You also have a S/PDIF stereo out. If a digital mixer doesn't accept S/PDIF you can get a converter to change S/PDIF to an AES, which any pro digital mixer will work with. I think HOSA has one for about $60.00, you might find something on Ebay as well.
Here is a Link to the TASCAM Spec page for you FW-1082
http://tascam.com/product/fw-1082/specifications/
I hope this helps,
Best Regards,
Mark
Jan 26, 2011 | Tascam Audio Players & Recorders
Connecting audio from pc to receiver.
What does your sound card have for audio outputs? Mine (M7250N Media Center) has all the expected 7.1 analog audio outputs AND a digital S/PDIF audio output that I run to my receiver's coaxial digital input.
Even if you have just 2-channel audio on your PC the headphone output can be used with an adapter that makes it conenct to a standard RCA audio cable. Run it to any available Linme Level input on the Denon. Get into your sound controls on the PC and make sure your Master Volume is unmuted and adjust whatever else applies to your machine that may affect the audio.
Your monitor is not really a player in this scenario.
Apr 29, 2010 | Denon AVR2310CI 71 Channels Receiver
How do I get sound from the Acer LCD monitor?
connect stereo audio cable from monitor to pc audio output
Mar 27, 2010 | Acer 22" X223w LCD Monitor
Acer AL1916 LCD monitor is getting darker!!
sounds like backlight is failing,contact acer and see if its under warranty.
Mar 04, 2009 | Acer AL1916B 19" LCD Monitor
I have acer al1917w A monitor but no sound
There is no sound driver, they are speakers, they work off of the audio output jack on the back of your PC, on the motherboard. If you have the sound drivers installed for the motherboard, and no sound, then you have plugged the monitor audio cable into the wrong jack on the PC, or you have the settings wrong just as MIKE said above.
Jan 09, 2009 | Acer AL1917W LCD Monitor
S/PDIF not working
Hey hoof
My only experience with faint sounds is when ground wires in the particular circuitry are not property connected. That means tracking the wires from the one end to the other if you can get to them. If they are not embended in a casing or housing I would change them.
Also, try changing the RCA plugs; even their connection can cause the sound shorting if there is a short.
Well....hoof... well,,,,good luck buddy.
Dec 31, 2007 | M-Audio Delta 1010 Sound Card
No audio sound
Run the software that came witht he monitor, then check if you are sending the signal to the monitor and not your old soundcard.There should be
open "Open volume control" on the speaker icon in lower right corner of your screen.
click options/Properties
the "mixer device combo box" will give you all the options you can send the sound signal to, in my case realtek audio, webcam.
the acer LCD should be there, if not try to figure out why.
I dont have an acer monitor, but this should get you going in the right direction.
Mike
Oct 24, 2007 | Acer AL1715 17" LCD Monitor
Computers & Internet Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
