Question about Breezaire Refrigerators
Error code AL - Breezaire Refrigerators
Error code H 4 Sharp model AL 1540CS
This is a critical issue which needs constant monitoring of the device and continuous chat / email exchange.
Thus it is advised to please avail paid fixya services for better support and quick solution.
Thanks
Oct 24, 2011 | Sharp AL-1540CS All-In-One Laser Printer
Model FDW80 error code AL-10 what does this mean?.
error code AL-10 == Failed heating element
You will need to have the element replaced, call a professional, or obtain a service manual and do a DIY?
May 12, 2011 | Hotpoint Dishwashers
Meaning H 4 appear alternative Sharp Al-1641 CS
H4 is nothing but an error code that appears due to power fluctation(in absence of a stabilizer). You please enter # interrupt-C interrupt -14-start to clear to clear the error
Jan 12, 2011 | Sharp AL-1641CS Laser Digital Copier
H 4 code flashing
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit. To reset press the following buttons:
  1. Press this sequence: CLR-Exposure-CLR-Exposure
  2. The display will go blank
  3. enter "14", press "PRNT"
  4. Press "CLR" several times to exit.
Give that a try and good luck.
Feb 18, 2010 | Sharp AL 1631 Copier
Error code CH on sharp sf-2027
Hi olixrules
CH light blinking - The DV tank is not installed.
CH light steady - Door switch is not turned on (interlock switch is ON).
Source here.
Hope this gives you some idea, unfortunately I'm not sure how to resolve these error on this particular copier.
Scott
Feb 01, 2010 | Sharp AL-1642CS Copier
H3 ERROR CODE SHARP AL 1631
H3:
00:TEMPERATURE OF FUSER UNIT HIGH,THERMISTOR CONTROL BOARD FAILING
Did you replace the thermistor? check the thermofuse also for continuity
Oct 20, 2008 | Sharp AL 1631 Copier
Error Code "L" 0n Sharp AL 1540CS
The scanner does not move - I get an "L" code flashing on the readout - please help???
Jeri
Oct 04, 2008 | Sharp AL 1631 Copier
MESSAGE: SYSTEM ERROR (H4-00) REFER TU USER GUIDE
We had this problem when the power was fluctuating in our building. I called Sharp and they told me to clear this condition with the following code: #*C* and when the screen shows 00-00 enter 14 and press the green copy buton. This worked on the AL-1655CS. On the AL-1631 we had to do a similar thing: C<auto>C<auto> 14 <copy>
Jun 06, 2008 | Sharp AL-1655CS Laser Printer
Error code L 1
probally little switch on "ceiling of where paper exits has been bumped locking lens, please rate as fixya or reply
Dec 27, 2007 | Sharp AL-1642CS Copier
Refrigerators Logo
Top Breezaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Breezaire Refrigerator Expert? Answer questions, earn points and help others
