The netcut application is not able to choose the net-card of the internet connection
When I run the netcut application.exe the application is unable to select a network adapter
  • 21 Answers
SOURCE: Connected on Wireless but unable to connect on Internet
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = 192.168.1.1 Subnet Mask = 255.255.255.0 IP Adress = 192.168.1.10(choose alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
Posted on May 17, 2007
CompuGuy44
  • 432 Answers
SOURCE: Wireless card will not connect to internet
Hey Chet, What is the model number for the device? I'll see if I have one for you.
Posted on Oct 02, 2007
chargeo1
  • 9 Answers
SOURCE: General Networking question
lets see here, your NVIDIA thing is for your ethernet port in your computer.
the wireless PCI adapter, is well, a wireless adapter, its used to connect your wireless, and a 1394 Net Adaptor Connection is basically Win2k/XP's way of telling you that you have a Firewire interface installed in your system.
so, if your going wireless, you dont need NVIDIA, and as your device manager shows that it has a red x on it, it shows that its disabled. as for everything else, i wouldent worry about it.
Posted on May 09, 2008
toolman3
  • 39 Answers
SOURCE: Just installed a D-Link DFE 530TX network adadpter
Sounds like an IP address problem. Your IP address on both the NIC card (DFE 530) and the router have to be in the same address range. You can do this 2 ways. 1... Have your router hand out addresses automatically. Make sure DHCP is enabled and that you have at least one address available for it to give out. ie. 192.168.0.2 through 192.168.0.3. The first three number must be the same as the router. The other option is to manually set your IP address on your nic card to match the router. If the router is lets say 192.168.0.1 then you can assign 192.23.34.2 to your computer NIC. If you haven't been able to access your router then check your router manual to find out the default IP address and use the same number for your NIC changing only the last number. The largest number you can use is 255. Hope this helps.
Posted on Jul 12, 2009
anandg27
  • 1272 Answers
SOURCE: Hi I am having problem with netgear adapter. I am
Please follow the below steps to configure settings:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight thee SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button.
9. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jan 06, 2010
Disconnectivity within 1 minute I install a fresh
ftp://ftp.hp.com/pub/softpaq/sp47501-48000/sp47845.exe
A lot of Windows Update Issues are linked to this Intel Storage Technology Driver being out of date. Hope this helps!
Aug 16, 2013 | Computers & Internet
I am develop one .net application and run to localhost i am get unable to connect visual stdio localhost...
Make sure that you have configured IIS properly. Many times even the asp.net gets corrupted and hence you'll be facing this issues.
1) Check whether IIS is configured or not. (Type "inetmgr" in the run and see whether the window comes or not)
2)UnRegister and then Re-register the asp.net
Jul 28, 2011 | Google Computers & Internet
I want to install some programs on my Samsung S8000 Jet mobile phone, like adobe reader, calculator, etc. but when I download them they're .jar and I am unable to install any .jad or .jar application...
Note: Toinstall a program to your Samsung s8000 jet, you should have both .Jar and .Jadfile. Tomake .JAD file from .JAR, you need a JAD Maker.exe file (Google it from net)then run it. Tomake the .Jad file, drag the .Jar to the JADMAker Screen. You have .Jar in thesame folder as .Jar file. TIP: to installsoftware on SAMSUNG JET S8000 follow these steps: 1) Google for TkFileExplorer v2.2 and install iton your computer. 2) Close Samsung new PC Studio (yes close it! ydon't it for this) 3) Connect jet to PC and choose PC STUDIO usb mode 4) Run TkFileExplorer 5) Choose right com port from "Setting" and then clickconnect from "File" (NOTE: you must NOT be connected in pcstudio. Now click on FILE and CONNECT) 6) On the bottom half ofTKFileExplorer, browse through these folders "User/Mass/Java/Games" 7) Create a new folder for your new software, Name it afterwhat you are going to install (for example, Google Maps, Gmail, Opera Minietc). 8) On the top half of TKFileExplorer,browse through to where you saved the application files (.jar/.jad) and selectthem both. Now right click and choose "Download". 9) Close TKFileExplorerand open keypad on your jet 10) Openup your dial pad and enter the following, *#5239870*#. Choose INTERNALS andenter the following, *#7092463*# 11) Nowscroll down and choose Storage Settings. 12) Thenupdate Java DB, followed by update apps database. Now you are finished. Go to Menu> Applications > Apps & Games.The new program must be listed there. Have Fun!!!
Feb 06, 2011 | Samsung Jet S8000 Cell Phone
UNABLE TO DOWNLOAD ITUNES TO MY unable to download itunes this is tghe messg I get: : C:\Documentsand Settings\DELL\Local Settings\Temporary Internet Files\Content.IE5\XMB6JTLP\iTUNES SETUP[1].EXE IS NOT...
It is required to clear the temporary folder before downloading the Software. For this click 'Start' button then select 'Run' (you can open 'Run' by press and hold Windows button on the keyboard and then pressing alphabet key 'R'). Type '%temp%' inside the Run window, and you will get a folder opened. Delete all the files in the folder and close it. Now try to download the Software, it will work.
All the best.
Sep 21, 2010 | Dell Computers & Internet
Error 102 (net::ERR_CONNECTION_REFUSED): Unknown error.
Try this,
Go in control panel>internet properties->connections->lan settings->proxy server and uncheck use proxy server for your 'lan setting'
Hope it helps.
Aug 12, 2010 | Google Chrome
I have intex cmi8738-4ch sound card and i am unable to get its drivers so help me to get one.
For Intex Products like Intex Sound Cards you can visit their website here: www.intextechnologies.com
Procedure: 1 - 14
1. Open this site for your Intex Sound Card
http://www.intextechnologies.com/webpages/download-driver.aspx
2. At the product list click and select Sound Card
3. Choose 6-CH CMI8738 (IT-591)
4. Then choose the operating system for your Sound Card
5. Then a download window will pop-up
6. Choose Save File
( for Mozilla browser the download folder is located at ....My Documents\Downloads )
( for Internet Explorer browser select the location for your download folder )
7. After downloading the file, right click the downloaded file then choose extract all
8. Click Next, then Next
9. Click Finish.
10 Open the folder extracted then look for the Setup.exe file, then press Enter or double click the Setup.exe file
11. Choose Run
12. Click Install
13. Then wait for the installaton process then click Finish
14. Restart your Computer
Apr 13, 2010 | Computers & Internet
Unable to watch youtube videos. It seems the
Try clearing the browser history (From Internet options) and check are you running any parallel application like an windows download or any other update download in the taskbar on the computer.
Let me know if this will help
Regards
Nov 30, 2009 | YouTube Videos
Problem signature Problem Event Name: APPCRASH Application Name: YahooMessenger.exe Application Version: 10.0.0.525 Application Timestamp: 4a8b5447 Fault Module Name: StackHash_b245 Fault Module...
download and install the following software updates:
1. Java Runtime Environment:
http://java.sun.com/getjava/
2. DirectX Runtime Web Installer:
http://go.microsoft.com/?linkid=9635483
3. Internet Explorer 8:
http://www.microsoft.com/windows/internet-explorer/
Next, you need to reinstall the Microsoft .NET Framework. Here's how:
1. Download and run the .NET Framework Cleanup Tool:
http://blogs.msdn.com/astebner/attachment/8904493.ashx
2. Download and install Microsoft .NET Framework 4:
http://go.microsoft.com/fwlink/?LinkId=147415
Reinstall Yahoo! Messenger using this link:
http://download.yahoo.com/dl/msgr10/us/ymsgr10us.exe
Sep 23, 2009 | Yahoo Messenger
Computers & Internet Logo
475 people viewed this question
David Payne
David Payne
