Question about Logitech LX 710 Keyboard/Mouse
My colon/ semicolon key is not responding. I've remove the cap and use air can to clean. It's still not responding.
My colon / semicolon key is not responding
Logitech keyboard had been working fine. Now the keys for symbols on the number keys, and for colon, semicolon, etc. and what gets typed is different. I can not access most symbols.
Replace it. Keyboards use timing signals to perform operations. If your keyboard looses a sectional functionality, they have to be replaced.
Feb 17, 2017 | Logitech Computers & Internet
My laptop semicolon key not working when i use document ,but when i start my windows its clicks continuously............
It sounds as though the colon key is stuck down, try removing the top and try cleaning the key.
Jan 11, 2015 | Computers & Internet
Can someone help instead for my computer to output slash out it do something else. that where to find @ i find " and vise visa
http://www.ebay.com/itm/NEW-IBM-LENOVO-Ideapad-G575-G575A-G575AC-G570-series-KEYBOARD-US-black-frame-/110931720756?pt=PCA_Mice_Trackballs&hash=item19d40bba34
A) Forward Slash: -> /
Combined with ? key. To the LEFT of the Shift key
(Above CTRL key on Right side)
Also in number pad area at Top.
To the Right of the Num lock key.
(Number pad area is right side of keyboard)
B) Back Slash: -> \
Combined with Colon key ( : )
To the LEFT of number 7/Home key, in number pad area on Right.
C) 1, 2, 3, 4, 5, 6, 7, 8, 9, 0; then Hash ( - ) key.
Combined with Underscore ( _ )
.....and slash out it's batten are not there...........
Believe Forward Slash is your slash out.
Explained where it is above.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 01, 2013 | Lenovo G570
How to insert apostorphe on p-touch 1750
Press the key next to the colon : and semicolon ; to get the apostrophe. You don't need to press the shift key or anything just press the ' key. On most keyboards it has the double quotes " above it.
May 25, 2012 | Computers & Internet
Hi! Today when I restarted my netbook from sleep, it decided that it would type semicolons when I hit the shift button and colons when I hit the delete button. Typing letters also gave intermitant...
There is probably a foreign object beneath the key cap and the keyboard membrane. Use a flashlight to see if there is something visible between the keys. If not, the key cap ( the part you actually type on ) can be removed CAREFULLY to see if there is a problem, but I would recommend a trained professional do this part, as the components involved in keyboards can be small and easy to break or lose.
Mar 05, 2011 | Acer Computers & Internet
The bottom row of keys there is a key with four symbols ? / colon and semicolon. We cannot get the ? or / to print.
You are probably in KBII or a language mode. Go to brotherinternational.con\m, click on support, poke around there you will find a manual.
DickyO
Dec 22, 2010 | Brother EM-530 Typewriter
Field plus key
Use the function Fn key and the + key (which is the colon semicolon key )
Mar 26, 2009 | IBM ThinkPad T42 Notebook
Toshiba PXC1100U cable modem article id=en&p id=F5D2230-4&a id=123& scid=0
You have the format wrong if you chane the semicolon after http back to a colon and remove the spaces the site pops right up heres the corected link:
http://www.fixya.com/support/t717308-toshiba_pxc1100u_cable_modem_article
Jun 28, 2008 | Computers & Internet
Ibm think pad keyboard problem
sounds like something is under the keyboard in that area. anything spill down there? you should be able to open the unit, and remove keyboard,and blow it out with compressed air(DO NOT do that while it's still installed in computer)
Feb 17, 2008 | Computers & Internet
Printing issues
There are a few things that can cause this. Try code Q if this helps you may have a gummy print soleniod, if it dosen't the cap on the solinoid plunger may be cracked or the platen might not be fully seated ib the frames.
Hope this is helpful
DickyO
Dec 28, 2007 | Lexmark Wheelwriter 1000 Typewriter
Logitech LX 710 Keyboard/Mouse Logo
449 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
