Question about Kodak EasyShare C180 Digital Camera
My flash is not working on kodak c180. Even if i put the flash button . What do i do
3 Suggested Answers
  • 141 Answers
SOURCE: Is the kodak easy share c180 digital camera webcam?
I won't say the camera is usable as a webcam because you will definitely severly shorten the life of the camera by using it as such. Firstly the camera is designed to take photos and short videos, NOT being left on continuously for use as a webcam. The heat generated by doing so could damage the delicate CCD (the part which collects light from the lens and converts it into electrical signals) Secondly most cameras are deigned to switch themselves off after a certain period of non use. Not handy for webcams.
Next there's the power issue. Unless you are using an external power supply for the camera you will be forever replacing batteries and for what an external power supply costs you could buy a proper made for the job USB powered WebCam complete with focus and sometimes zoom.
Next there's the mounting issue. Where will you mount the camera to give a well lit and steady picture of your face. Definitely not on top of the monitor due to extra heat generated by the monitor itself. Mix that with camera's heat and hello, and too soon, goodbye camera.
Webcams cost $20 if ou shop around maybe cheaper. OK your cmera will give a better picture but at the distance you're talking it won't matter. Plus you will need software to generate the webcam picture. MSN is a good webcam program. Plus depending on the output of the camera, usually only video. You may need a video capture card for your computer. The camera will give you a full screen image of what it's pointed at but you need a box to put a smaller picture in on the screen otherwise all you will see is one big face, yours.
So do you really want to wear your camera out prematurely simply because you can't afford a $20 webcam. The made for the job unit is cheap, will stay on all day and the power comes from the USB port. Everything you need and cheap. I think you know which way to go.
Good luck
Posted on Apr 22, 2010
  • 275 Answers
SOURCE: my kodak c180 camera flash won't work, why?
It could be that it isn't set correctly. Check the manual to see if it is in automatic mode, could also be the camera needs repairs.
Posted on Aug 01, 2010
Kodak C180 stopped working
Only solution there is: Needs to go to camera shop !! No user fix on these Kodaks, nothing but troubles.
Sep 19, 2012 | Kodak EasyShare C180 Digital Camera
Need software downloade for c180 kodak camera
http://support.en.kodak.com/app/answers/detail/a_id/36670/kw/c180/selected/true
This is Kodak's Easyshare software, which is the same thing that give you on the disk that comes with your camera.
Oct 26, 2011 | Kodak EasyShare C180 Digital Camera
How to set language,date and time
Press the MENU button. Use cursor-left/right to select the Setup tab. Use cursor-up/down to select the fourth item from the bottom of the menu. This will let you change the language. Date & Time is the eighth item on the same setup menu.
From the Kodak C180 extended user guide:
http://resources.kodak.com/support/shtml/en/manuals/urg00964/urg00964c4s2.shtml
Apr 20, 2011 | Kodak EasyShare C180 Digital Camera
My kodac easy share c180 wont turn on
This kind of issue might happen. Remove the battery from the came and then press&hold the power button of the camera for 30 seconds.... Put the battery back and then try to turn it back on.......Hope u are sure that the battery has enough charge. If the step does not work try some other alkaline or lithium batteries if possible.
Feb 17, 2011 | Kodak EasyShare C180 Digital Camera
My kodak c180 camera flash won't work, why?
Aug 01, 2010 | Kodak EasyShare C180 Digital Camera
My husband gave this camera for xmas, but the screen is busted. How do i go about getting it fixed?
Sorry, but you don't. You either live with the fault or replace the camera. The C180 is a fine camera for the money, but it is so cheap that even the most minor repair is not cost effective. If it was a fault covered by the warranty (it won't be, unless "it just cracked") then Kodak wouldn't even bother to attempt a repair, they'd just throw the camera away and supply a replacement.
Replacing the screen will definitely cost more than buying another camera, given that the EasyShare C180 sells for around £60 (currently US$97).
Jan 22, 2010 | Kodak EasyShare C180 Digital Camera
My Kodak EasyShare C180 Digital camera, came with "Kodak" batteries after those died, I inserted new batteries, and now everytime I try to turn the camera on, it doesn't respond. I have tried Lithium...
hi i just to have silimar problem with old panasonic, kodak and polaroid cameras.
try to use Duracel alkalines, not the cheap ones with out alkaline those are for remotes and clocks. flashlights.
if you are using rechargables make sure they are 2700mha AA NiMH or higher. lower won't work(there is another kind of rechargeables batteries those don't work on it).
for the lithium i never used them. they were kind of expensive compare to alkalines.
If i help. please rate me :)
Oct 08, 2009 | Kodak EasyShare C180 Digital Camera
Kodak EasyShare C180 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
