Question about Go Software Inc. PCCharge Pro (100PROL0000) for PC
Getting error # 3022
I have an old version of PC charge pro version 4.04 does anyone know how to delete old transactions to help clear up the database. This version does not have a transaction Archive/purge feature under the utilities menu as the newer versions have. Is there a manual way this can be done?
    Problem Solver:
  • 19 Answers
Hi Julie,
You shouldn't really be using that version anymore for several reasons. However, since I don't work there anymore, and I'm sure you have your reasons for sticking with it ...
There is a way to purge the transactions, although Tech support will tell you that it is not recommended (not to mention, there's nobody there anymore that was around when 4.x was out.). If you're just wanting to clear out the old files and start new so that your database is smaller, there is a rather simple solution. If you still have your original pccharge setup cd, there is a blank database on the cd. Make sure all current batches are settled. Rename the current database to something that will make sense (perhaps with a date of the last transactions in the database). After that database has been renamed, you can copy the blank PCCW.MDB from the cd to your PCCharge directory. Once the database has been copied, right-click on the database to make sure that it didn't get marked as read-only during the copy & paste. This will start your transactions from a fresh database. Your history will no longer be available from the software however. (If you really need that history you can temporarily rename the old database back long enough to pull the history and then switch back to the new one). After this, start up pccharge and go to setup numbers and synchronize numbers with troutd. You should be good to go after this.
Posted on Sep 27, 2009
Having problems clearing a database
How long has this system been in use? Just trying to gauge if it's the amount of records that is really your problem.
Perform a scandisk on the HDD. Perhaps the hangs are due to corrupt hard-drive issues. It's easy to cause corrupt areas - rebooting or powering off while the hard drive is in use is enough to cause issues. That alone will fix 80% of the problems out there.
To check the hard disk drive integrity in Windows:
  1. Double-click My Computer, and then right-click the hard disk drive you want to check.
  2. Click Properties, and then click Tools.
  3. In Error-checking, click Check Now.
In many cases, it will ask to be scheduled - go ahead and schedule the scandisk and then reboot. This process can take 20 minutes to finish - let it finish and see if your performance improves.
Jan 14, 2014 | Pc America Restaurant Pro Express
Issue archiving data during upgrade to QB Pro 2007
Don't worry about the sales receipts. You have a bigger problem at hand. The reason it is bringing up pieces of old data is because you are nearing your limits in the program. There is a a limit in lists in QBooks (Customer names, vendor names, employee names, other names add them all up together) that when you get close to exceeding it the program starts to randomly purge data. It does things like deletes some things on an old deposit, or deletes some of the invoices already paid for by a payment posted and sometimes it deletes the customers main information (address ect.). When it randomly purges transactions that are linked with others then the records begin to error out. This will continue until the program stops loading and locks up completely. There are many ways to solve the problem. Some people keep one year of accounting records in each company file and begin a new file with the new year. You can consolidate names (go through your inactive entries on all lists and see if there are duplicates you can merge). I would try and clean up as many as possible by consolidating and merging and then use the verify data feature under file and then utiltiies and follow the instructions to very the integrity of your file. If it passes then you can try and archive previous periods again.
Jul 22, 2010 | Intuit QuickBooks Pro 2007 Full Version...
I have entered a credit instead of a bill in supplier centre and cannot find out where to delete it
1) Go to "Vendor Center" or "Vendor List".
2) Locate Vendor then "Transactions" should appear on right
3) Select "All Transactions" and credit should appear
Jan 04, 2010 | Intuit QuickBooks Pro Edition 2009 Full...
Received an error message at close out RB00546E... Tech support tells me that my comuter operating system is too old to contract. Tell me to upgrade. Have a new computer coming Windows7. In the meantime,...
Would probably need the the entire error. The RB simply stands for Rejected Batch when you are trying to settle (I'm guessing with Vital/TSYS). the 00546 is the transaction number. This looks like a rather large batch. The transaction in question is the 544th transaction (the first two records to go over in the batch contain account information and your company information. So always subtract 2 from the number shown).
Without seeing the rest of the error, I can't say exactly what is wrong with the transaction. There should be a 3-4 digit number after the E in your response from the processor.
At any rate, depending on your version of PCCharge,there is a Batch Editor is included. It will be in (C:\Program Files\Active-Charge) for Payment Server or (C:\Program Files\PCCW) for Pro, and is named BatchUtility.exe. This will allow you to quickly view the batches and edit the transactions you need.
If Vital/TSYS is your only merchant account, then your batch will be named Visa1.xxx.Since it is now a rejected batch, it will be called Visa1.PCS (A regular batch should be Visa1.ENC for encrypted. Unless you are on a really old version). You should be able to open the Batch Utility, Open the bad batch by clicking find "Indeterminate" button, find the 544th transaction (if it's corrupt, you'll be able to find it rather quickly), and void it out. Keep in mind that this is not the same as voiding through the inteface, it is merely taking the transaction out of this particular batch, not voiding the transaction authorization. If it's a sale, you're authorization code will still be good (assuming it hasn't been over 30 days since you last settled). If it's a credit or void, there will not be an authorization number to worry about, and you can just dump the transaction altogether.
Make sure to take notes on the transaction so that you can run it as a post-auth (if it is a sale) after your batch is accepted. Once the offender is removed, you should be able to go back into PCC and settle as normal. You will get the message about "all indeterminate batches need to be closed first, blah blah blah", click "ok", check your totals and then attempt to process the settlement.
Good Luck and hope this helps.
Oct 16, 2009 | Go Software Inc. PCCharge Pro...
Pccharge invalid trout id number
It sounds like your TroutD has somehow gotten out of synch with the last processed transactions. Usually, you can go to setup -> numbers and synchronize the TroutD to the last number used. This will usually correct the issue.
Jul 03, 2009 | VeriFone PCCharge Pro Full Version for PC
Kodak easyshare software error 1624x17x4252799284x
You need to run the clear utility before installing the software www.kodak.com/go/clear, then download the latest version at www.kodak.com/go/edl
Jun 10, 2009 | Kodak EasyShare One Digital Camera
Error message Library not registered
I got the message "Line 25: Library not registered" after uninstalling QuickBooks Pro 2009 and trying to run my old version of QB Pro 2006.
(I had installed 2009 version to upgrade my QB2006 Pro version but got into problems with multicurrency support not being supported in the Canadian QB Pro 2009.)
Fix is VERY easy and I think it applies to anyone trying to run an older version of QB Pro after uninstalling a newer version.
Fix is to find the file "reboot.bat" located in the program files associated with the older QB version.
In my case it was found in "C:/Program Files\Intuit\QuickBooks Pro" folder.
Just double click on the file to run it. This file tells the system where parts of the QB program are located including the DLL libraries it needs. After running this file you should be able to run your old QB version OK. No rebooting necessary.
May 08, 2009 | Intuit QuickBooks Pro 2007 Full Version...
RB INV DATA 0001 Error PC Charge Pro Version 5.1.0
The best solution is to have tech support remove the offending transaction from the batch, and then settle the batch. Since it is just a pre-auth, you'll need to run a post-auth to complete the transaction anyway, so it's not a big deal in this case. In the case of it being an actual sale transaction, you would have to remove the transaction from the batch, and then re-run it through PCCharge as a post-auth.
If you don't want to deal with VFI's tech support (I wouldn't either), then depending on your version, you may have more options. If it's a later version 5.7.x and up, there is a batch utility that will allow you to remove the transaction by yourself. If you are using an older version that does not include the batch manager utility, you could rename the batch file (in case you need it later) and in the case of 2 transactions, re-run them in directly in PCCharge as post-auths. Verify that the correct transactions are in in the batch, and then settle as normal. (just as an FYI, pcc tech support will not rebuild any batches with less than 50 transactions. So it might not be a bad idea to learn the batch manager and/or renaming files if you are sticking with PCC).
Jan 15, 2009 | Go Software Inc. PCCharge Pro...
Need quickbooks 2005 help need to go back and reconcile cleared transactions but I can't locate when I go to reconcile, I can only find data in register
The most common cause for this is that when you open the reconcile window, the account chosen is not the same account as where the tranasctions are located. Make sure of the account name you are reconciling. Also, look at the trasnactions in the register. If they have an asterisk next to them, they are indicating that they are tentatively cleared. Click on the asterisk until the box is blank. They should show in the reconcile window then. Some versions of the program would allow you clear the transactions directly in the register by placing the cleared checkmark on them. Some older versions would not accept them once this was done, and you had to completely clear the marks in order to reconcile. Also, be sure of the type of account you are trying o reconcile.
If these answers don't resolve the issue, let me know and we will see what we can do.
Oct 11, 2008 | Intuit QuickBooks: Pro 2005 for PC
Kenwood kdc-3022
the only way you can get the code is to ring kenwood with the make and model or try 0123 ,1234,0000,4321
Jul 29, 2008 | Kenwood KDC-3022 CD Player
Open Questions:
Go Software Inc. PCCharge Pro (100PROL0000) for PC Logo
301 people viewed this question
Top Go Software Inc. Computers & Internet Experts
David Payne
David Payne
Are you a Go Software Inc. Computer and Internet Expert? Answer questions, earn points and help others
