Question about Frigidaire ATF6000ES Front Load Washer
How do you remove top of new washer so dryer will sit on top?
My 5 year old frigidare frontload washer stopped working during the final spin cycle after it got wet underneath due to water coming in the house with heavy rains. We bought a new washer to fit under the old dryer. We need to know how to remove the top of the washer.
  • vearriaga May 20, 2009
    Thanks - my husband figured it out and how to place the dryer on top.
  • 90 Answers
There should be 2 screws at the rear of the top section. Remove those screws and pull the top backward and it should come off.
Posted on May 20, 2009
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
Washer model LA5800XK is 28 yrs old; we stopped it during an unbalanced 'spin-cycle', a buring smell followed, now it only fills with water but does not agitate or pump water out - is this a...
May need a belt replacement. Belt could have gotten wet and slipped and burned a spot in it. I had one of these and replace a locked up water pump and belt once. I finally got rid of it when the transmission started growling loud it was 32+ years old lady kenmore. see http://www.appliancepartspros.com/ for a diagram.
Jan 17, 2011 | Whirlpool Washing Machines
My Magic Chef machine is 17 years old, but looks like new, so I hate to part with it. It stops during the SPIN cycle. I fiddle with it, like turning the dial around a couple of times and it will come to...
check the lid switch,it is located in the area where the lid lands on the washer housing when closed it is a safety feature that shuts off the machine if you open the door during the spin cycle,they can get touchy due to vibration from running,also check your balance ring,if you have a severly unbalanced load it will stop the machine
Jan 25, 2010 | Washing Machines
My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washer fills during spin cycle
Replace the timer, you can find the product name model and serial number on two place. Either the back panel or on the lid underneath. Please rate if this helped thank you
Feb 12, 2009 | Whirlpool LTE5243D Top Load Stacked...
Cold water pours in during final spin
No - the timer is the likely suspect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
There is something clogging your pump, dismantle it to clear it. Plug off the wall socket mains first.
Jan 15, 2009 | GE WDSR2080D Top Load Washer
Maytag washer not agitating and not spinning fully
Pr obably a coupling between the motor and gear box, Take motor off and coupling will come out, re place it and it should be fine
Dec 03, 2008 | Maytag MAV4755 Top Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
164 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
