Question about BenQ MP622 DLP Projector
Benq MP622 shutdown immediately - BenQ MP622 DLP Projector
Why do i need when the projector is getting automatically shutdown
Sounds like an auto-shutdown or auto-sleep setting. Go into your System Setup>Basic Menu and check the settings.
Manual can be found here: http://benq.co.in/support/downloads/download.cfm?file=projector/manual/mp515 st/projector_um_user manual_20100524_151409mp515st 525st_en.pdf
Mar 13, 2014 | BenQ MP515 DLP PROJECTOR SVGA Projector
The benq Monitor FP222W automatically shutdown
Check if you dont have a timer shutdown on the menu.
Electronical Problem:
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Feb 14, 2013 | BenQ FP222W LCD Monitor
BenQ Change language after i shutdown the computer ?
Using it since 2011 and the same problem started in few months. send back to claim warranty. they change internal board. was ok for few week until the problem back. never send back for warrranty as it took nearly two months to them to replace the piece. never going to get another benq product after this!
Sep 16, 2012 | BenQ V2420H 24" W Extra Slim LED Backlight...
BenQ Digital Camera service centre hyderabad
I have one problem in my cam; Benq Digital Camera Model No. DC C 750
I On the Camera Immediately off the Camera what the Problem this.. plz clarify any ASAP.
Sep 08, 2011 | BenQ DC C500 Digital Camera
Dots appearing on the display screen
if these are pixel shaped dots then the DMD chip is most likely faulty
Apr 11, 2011 | BenQ MP622 DLP Projector XGA 2000:1...
I havea benq mp622 and some of the pixels are going. i'd like to know if i can buy a replacement lcd screen from somewhere. Or if there is anywhere that does on site servicing in the UK
You may find it is dust that is causing the problem.
Medium,co,uk have a repair department or may be able to advise who is nearer to you.
Hope that helps.
Mar 02, 2011 | BenQ MP622 DLP Projector XGA 2000:1...
Sudden Shutdown of the unit, I Cannot use my FP72E BenQ LCD monitor Properly because at the middle of using it, it suddenly shutdown, open, shutdown again, open again. is this unit is capable for long...
For the monitor that is more than 2 years old, first place to look will be the power supply, look for bad caps with bulging top first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps; http://s807.photobucket.com/home/budm/allalbums
Feb 16, 2010 | BenQ FP72E 17" LCD Monitor
The monitor turns white immediately after being turned on for about two seconds; and then immediately turns off leaving an un-powered screen. Repeating this process to gain access the control buttons does...
the problem is most likely you graphics card, if you have installed more than one graphics card you will most likely not get any picture from this.
remove any newly installed graphics card until you have installed the drivers for the latest one.
Aug 11, 2009 | BenQ FP71G 17" LCD Monitor
Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
Seems either aproblem with Invertor board or Front panel switches are leaky.
Samir
Aug 17, 2008 | BenQ FP71G 17" LCD Monitor
No live picture on Benq digital projector
seems to me like your acer laptop's display is configured " extend my desktop to this monitor", that's why you can only see the desktop background. Go to your display properties and change it to clone display or uncheck the extend display option.
Mar 04, 2008 | Computers & Internet
BenQ MP622 DLP Projector Logo
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
