Question about Maytag Dryers
Accessing burner and installing LP conversion on Maytag Bravo
I have a maytag bravo MGDB200VB0 and need to get into the machine and convert it to LP gas.
  • 1 more comment
  • keneric May 23, 2009
    OK. The hard part is figuring out how to take this a part. So I learned. Take off the two clips on the back of the unit up top. Pop them out after taking out screws. Take off the top. Unscrew the two sheet metal screws on the right and left inside front up top holding the front on. Slide it up and out. You have enough room to move it aside without taking apart the wires. Now unscrew the four screws holding the front of the drum brace. Pull that off. The drum is hanging now, so prop it up. Unscrew the two screws holding the bunrer unit down and slide it out noticing the two metal tabs that slide into the metal bottom. You now have it in your hand and you can insert the new burner orfice and air plug.
    Dont order the LP kit from the instructions. Order the part from the dryer model. The instructions are wrong. Check the model of the part with the label on the bottom of the burner unit. They should match. I had to get the first then, the right one.
    Pretty easy to do. Took abouut an hour all together. PITA!!
    Awesome Dryer.
  • Anonymous Mar 17, 2014
    Accessing the dryer drum in a maytag bravos xl gas dryer
  • Anonymous Mar 22, 2014
    need a new thermostate for my bravos 300
  • Maytag Master
  • 2,005 Answers
You need to obtain a jet (orifice) of the correct size for the gas you wish to use. remove the burner and, replace the existing jet; that is all there is to it.
Posted on May 19, 2009
Maytag Bravo gas dryer gets too hot.
Most likely needs a new thermostat. Go online to find instructions on replacement. Make sure it is unplugged. I don't think it is too difficult to do yourself.
Sep 13, 2014 | Maytag Dryers
Maytag bravo mvwx500xw does nothing lights come lid locks then nothing
check the inlet hoses are connected and tap is set to on.
Aug 25, 2014 | Maytag Washing Machines
Maytag Washing machine; Bravo,not filling up with water.
what is your model number is then we can get started okay
Jan 01, 2013 | Maytag Washing Machines
I have a Maytag Bravo top load glass washer and a f51 code. Top wont open and machine has stopped
Defective hall sensor most likely, The cabrio bravos and Oasis machines are all basically the same.
MORE here
Dec 19, 2010 | Maytag Bravos MTW6600T Top Load Washer
Maytag bravo quiet series 300: Stopped at spin:
We have a Maytag Bravo Quiet Series 300 washing machine, the door latch is broken. I have the replacement part ( the locking mechanism) but I need can not figure out how to get the top of the washer to flip up to give me access to top front of the machine to remove the old part and replace it with the new.
How do I flip back the top (not the door) of this machine?
John
Jan 15, 2010 | Maytag Washing Machines
Can this gas range be converted to lp gas maytag performa
moz-screenshot.pngmoz-screenshot-1.pngTurn off the gas supply.
Locate the gas valve regulator. Unscrew the top cap on the regulator,turn it over and re-install it.It should be marked NAT. LP.When correctly converted you will be able to read LP.
On the Performa all the conversion parts should just be adjustments. Remove the oven racks,remove the oven base pan,remove the oven flame spreader pan to access the safety valve. Take a 1/2 inch open end wrench and tighten the orifice on top of the gas safety valve. Tighten it until it is snug.Remove the top burners and raise the top to access the surface gas valves.Tighten the valve spuds until snug. Re-assemble all parts.Turn the gas back on and lite the burners. Turn them high and low to make sure they stay lit. If any burner is not right tighten or loosen the orifice spud for that burner only. All air shutter adjustments should be full open,
Dec 02, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Installed new gas Maytag Bravo yesterday. It will
is the gas on
sometimes these units get dropped if they fall hard you could have cracked the ignitor
Oct 03, 2009 | Maytag MGDB400VQ Dryer
My maytag bravo top loader washer is displaying a code of LF and
it meant "low flow" check water connecting lines. mine has the same problem.
Dec 02, 2008 | Primera Technology Bravo (Refurbished)...
Dryers Logo
517 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
