Question about Espresso RMI La Cimbali Espresso Machine
How do I set the coffee dose?
For a La Cimbali M2 Barsystem
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Espresso RMI Expert
  • 373 Answers
Too detailed for direct answer. Get operator's manual for dose instructions. Some machines may require programing key (service tech only)
Sorry for this answer as the dosing control is in-bedded with all dosing variances which is considerable. Though with practice it's possible to set it. Have you service tech walk you though the 'operator' or 'customer' programing steps.
Posted on Oct 03, 2017
3 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: The grinds are too course
The ginder udjustment for M2 is behind the coffee bean hopper. It is a small level hundle. You have to pull it up and rotate it step by step clockwise for more fine.
Posted on May 08, 2010
guido817
  • 6 Answers
SOURCE: La Cimbali Espresso Machine: How do you calibrate the dosing for a Cimbali M29 ...
Press and hold any Group stop button until beeping, then all the button will copy what you press. Hit any stop button to leave program.
Posted on Mar 27, 2012
How do I get the M1 coffee machine fram La Cimbali to stop beeping constantly?
* M1 (M2, M50's, M39's) Especially "Super Automatics" and any newer machine with the "round metal button" that doesn't seem to do anything. Will give an audible and visual read out of what needs to be checked or performed.
* The most common with the super automatics (it does everything from grinding, dosing, and sometimes auto frothing.) is the clean cycle warning. Usually there is a requirement to add a cleaning pill (for coffee) and/or cleaning solution (for milk products). Frequent daily cleaning is required to keep these "Robots" in top condition.
* Full dregs (waste coffee) drawer. Remove and clean out. Close cover completely.
* A less frequent alarm is the quarterly or semi-annual maintenance warning. This will continue to warn every morning at start up, but is usually silenced once the machine is put into operation. Though some units may still display a warning. Note: If this warning is ignored, there is a "lock out" if it passes 6 months. (well it did when I was still working. Cimbali may have dropped this option.)
* Any unit will alarm if there is a critical fault in the system; Jam motor, Full dregs drawer, Low or High temperatures, etc. All require a qualified service tech to check, repair, and reset equipment.
* Which brings us back to the "do nothing button". It's the "Key" we use to service these Chimbali machines. The tech needs it to clear alarms and program the equipment. Customers are allowed to make some changes to the dosing and a few other settings. But most settings have limits that will damage the machine if disregarded. (like over grinding too much coffee, trying to compress it into a small puck. can't, will break the drive motor.)
* Still buzzing? Call vendor for service.
Aloha, ukeboy57
Jun 12, 2017 | La Cimbali Coffee Makers & Espresso...
What's carry out maitenance mean its showing on my
M2 supper automatic have a programmable maintenance schedule set up by the technician whom installed the machine (if this is the original location.) Call your vendor as it must be reset and cleared by a certified technician. The machine will lock out if not cleared. Some machine s will continue to be operational but needs to be reset every morning after bypassing error. Naturally continued use of machine will eventually fail from a more serious problem as errors are ignored.
Sep 13, 2014 | Coffee Makers & Espresso Machines
Why hot water is not hot steaming like before from the LaCimbali M2 Barsystem cappuccino machine
If this machine has been in use for over 6 months then it will need servicing. The hot water system has calcified which will need cleaning or replacement.
ukeboy57
Jun 10, 2014 | Espresso RMI La Cimbali Espresso Machine
I need to see a wiring diagram for a la cimbali espresso machine m2
These super automatics really require a service tech. Please contact your vendor or cimbali.com for current contacts
ukeboy57
Nov 17, 2012 | Espresso RMI La Cimbali Espresso Machine
Cimbali M2 wont deliver coffee
Coffee may be to fine. To Check, open pill door and press any blinking button. If water comes out then for sure the coffee is to fine.
Nov 30, 2011 | Espresso RMI La Cimbali Espresso Machine
I am repairing a LaCimbali M2 BarSystem that has a broken gear (Nylon) that transfers Torque from the Motor to the drive shaft on the grinder. Can this gear be purchased separately?
Sorry no, the gear drive assembly comes complete with the motor drive. Broken gear is usually caused by something getting into the dose chamber. I've found may an object stuck in the chamber, Don't leave stuff on top of the machine. Don't use hard cleaning pills (check old coffee 'pucks' for unmelted pills) Gross overfilling of coffee will also break gear. Check for oversized coffee pucks (double dosed?)
ukeboy57
Oct 11, 2010 | Espresso RMI La Cimbali Espresso Machine
What does error66 mean on an m2 and what are tge possible solutions?
No 066 mean Failure to read impulses by volumetric flow meter of turbine during coffee dispensing.
The Possible causes are.
1. No Water - check water mains.
2. Broken water pump- Check water pump if it stuck or completely damage replace.
3. The coffee dose is too much- reduce the coffee dose.
4. Coffee ground is too fine- Adjust grinder to more gross coffee.
5. Clogged filters -Replace filters.
6. Coffee solenoid valve clogged or defective -Clean it o replace it.
7. Broken flow meter- Clean from scale deposits or replace.
Sep 29, 2010 | Espresso RMI La Cimbali Espresso Machine
May 18, 2010 | Espresso RMI La Cimbali Espresso Machine
The grinds are too course on my La Cimbali M2 Barsystem. Where is the lever, and how do you move the lever in order to make the espresso grinds finer?
May 08, 2010 | Espresso RMI La Cimbali Espresso Machine
Espresso RMI La Cimbali Espresso Machine Logo
55 people viewed this question
Top Espresso RMI Coffee Makers & Espresso Machines Experts
Mohamed Ismail
Mohamed Ismail
John
Mark Cheong
Mark Cheong
Are you an Espresso RMI Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
