Question about Dryers
No heat coming in drum
My Kenmore dryer model 110.86878100 is not working correctly. the drum turns and there is air flowing coming out the back. However there is no heat in the dryer. Can someone please help me b4 my husband takes my dryer completely apart. Desperate housewife
  • 148 Answers
Probably a bad heating element (which he will have to take it apart to see).
Sorry!
Posted on May 19, 2009
Dryer will heat up then shut off
Most likely it's getting to hot, check your vent and the outside vent hood make sure you have proper air flow. Turn on the dryer check the vent exit to make sure you feel hot air coming out. Take the vent off and check the back of the dryer for air flow. If you have air flow and the unit is still over heating you may need to replace the operating Thermostat. Could tell you more with a good model number should be inside the door.
Oct 26, 2013 | Kenmore 62602 Electric Dryer
Strong odor coming from dryer
Usually when there is a strong heat (burn) smell from the heat element, it is telling you that there is poor air flow. This has nothing to do with the model. It is a blocked or restricted vent line, or an internal blower wheel malfunction or a lint blockage further in the machine that is restricting the air flow. WHEN AIR MOVES CORRECTLY, THE ELEMENT HEATS NORMALLY AND DOES NOT GIVE ANY OVERHEAT ODER.
Oct 11, 2009 | Kenmore 63942 Dryer
Dryer not heating up
check your air flow coming out of dryer if it is good and stong then you should change the high limit safety thermostat and the cycling thermostat.
Apr 04, 2009 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Kenmore gas dryer heats some of time MD
Is the drum turning and are you getting a flow of air out of the exhaust pipe? These two items may assist you in finding the problem. Look next at the thermostat if these items are working right. Have you checked the area below the lint filter for buildup of lint?
Feb 25, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Kenmore dryer.
chech your exhaust hose from rear of dryer ,,if can disconnect and run and see how long it heats up for ,if you reconnect hose to back of dryer and shuts off quickly pretty obvious ,, bad air flow , clean out exhaust
Dec 31, 2008 | Dryers
Kenmore dryer, electric
forget temp ck..first ck air flow at rear of dryer be sure strong air flow present if not remove back ..remove 4 screws holding blower housing to inside wall remove the 2 screws under lint screen on top ..clean blower housing if housing clear ck vent line all the way to end outside for restrictions ..reinstall line to dryer be sure not to crimp or flatten hose when pushing dryer back to wall ...quick ck dry a load with rear vent hose disconnected if cks ok definite vent restriction
Dec 05, 2008 | Kenmore Dryers
Question about kenmore dryer
Most heat related problems associated with long dry times are contributed to clogged ventilation. A dryer needs proper air flow to dry efficiently. If the external ducting is clogged, this will cause the internal heating circuits to actually overheat to the point of failure. If your dryer is heating, but simply taking a long time to dry, I would recommend a thorough cleaning of all ducting.
An easy way to determine if you have restricted air flow somewhere is to simply remove the vent house from the back of the dryer and attempt to dry a load as you normally would. The air flow coming from the dryer should be forceful and warm (about 140 degrees F on most dryers). If it is, I would begin an inspection of your ducting from the point where it enters the wall, to where it exits your home. Rule of thumb: The SHORTER and STRAIGHTER the vent ducting, the BETTER. If you have ventilation that runs up the wall and into an attic, runs under a crawl space, or has excessive bends or kinks, all of this can contribute to creating chokes points where lint can accumulate and cause more resistance on the blower. In a nutshell: it reduces the dryer's efficiency.
If the air flow coming out of the dryer is weak, you need to inspect the internal ducting where the blower fan is. If the air flow is cold, you more than likely have a blown thermal cut-out (safety thermostat), or heating element. On your model dryer, the heating element and TCO are located behind the drum. If both components are good, you should be able to see the element glowing through the holes in the back of the drum and feel heat.
Read through the advice I've given and let me know what your symptoms are. Hopefully this is just a simple air flow problem. NOTE: DO NOT run the dryer for extended periods (meaning days or weeks) with the vent hose off. This will cause the humidity level in your home to increase, along with the temperature. Which can lead to mildew. I hope this information is helpful. Let me know if I can be of further assistance.
Sep 21, 2008 | Kenmore 62872 Electric Dryer
Kenmore Dryer heat is on high on all three settings
Before assuming you have a component problem with your dryer, ask yourself this question, "When was the last time I inspected and cleaned my dryer ventilation?" If you can't remember, or if it has never been done, you may have a simple case of a dryer exhaust system that is clogged. A dryer requires proper air flow in order to work properly and efficiently. If the dryer is clogged, the heating circuits actually will overheat. The result will be longer dry times, a dryer that is too hot, or eventually a dryer that fails. A simple way to determine if it IS an exhaust problem is to perform the following:
1. Pull the dryer away from the wall and remove the exhaust hose.
2. Start the dryer with a load. The air at the exhaust should be forceful and warm (about 140 degrees F for most dryers).
3. If the air is warm, allow the clothes to dry to see if they dry efficiently like they should.
4. If they do not, or if the air flow is weak, inspect the dryer blower fan housing to make sure it is not clogged and that the fan is moving.
5. If the air flow is normal and the clothes dry just fine, reconnect the exhaust vent and check the air flow at the exhaust where it leaves your home. If the air flow is weak, I recommend cleaning the ventilation, and checking for any kinks that may be obstructing air flow.
6. If the air flow at this point is normal, and your dryer is still not operating correctly, then we may have a problem. A common problem is the wire coming off the auto dry sensor inside the dryer. The auto dry sensor bar is located inside the drum along the front. There is a connector wire that attaches to it behind the lower panel.
Inspect your dryer first and make a determination of what it is or isn't doing correctly. I would hate to recommend parts without you first doing some routine inspections. It could be that you may not need any replacemnt parts and may just be able to save yourself a service call. I hope you find this information helpful. If you need addtional assistance, please let me know.
PS It is recommended that you use the semi-rigid metal type dryer exhaust hose. It is crush resistant, heat resistant and hold up well against rodents.
Sep 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Electric dryer not heating drum
Check your vent line if it is stoped up you have no air flow bent ocrushed check the flap is not stuck
Dec 12, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
116 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
