Question about Rheem Water Heaters
PRO50-45FV1 NEED INSTRUCTION MANUAL TO SET PROPER WATER TEMP.
Can anyone tell me why my ISE GN1100 Hot tap is spitting when the handle is pulled back to release the water?
Usually happens when the temperature is set too high, check your instruction book and set it to the advised temp. Also the filter in the nozzle may need a clean.
Sep 15, 2012 | In-Sink-Erator InSinkErator F-GN1100SN...
Boiler keeps going out
have you checked that you thermostat on wall is set to a reasonably high temp. if not when room eaches temp setting , then the boiler will switch off,. Other than this obvios one , i would suggest you could google your boiler for the manual /instruction.
Parts For Porsche Cayenne
Jun 11, 2012 | Reliance Water Heaters
Looking for manual for st1000 to set the timer
Product is not identified. Timer is not identified.
Question posted under water heaters.
I specialize in water heaters and timers.
Add a comment and describe product and describe timer in detail for possible identification and instruction manual.
Sep 20, 2011 | Water Heaters
Heats up the rapidly decreases within in minutes.
Problem new or old? How long you have unit? Sounds like not enough flow to keep burner on. Tankless need at least .6 gpm to keep hot water flowing or else the burner fires then shuts fires then shuts and you get a sandwich effect...hot cold hot cold. If you have new diverter valve in shower -vs- old two handle type try turning hot water ALL the way ON and see if hot stays hot. If it does stay hot then slowly adjust to cool and see if you maintain a good MIX for proper temp. If it goes cold again try this......LOWER control pad setting to a comfortable 105 degrees (ladies) 100 degrees(men) and turn shower valve all the way to HOT. See if your temp remains consistant now and if it does then problem solved. Tankless mindset...set temp on control pad and stop trying to MIX at shower valve. Thats how these things work. Thats why I install a control pad in each bath and one in the kitchen for adjusting ash temp during dishwasher on time. ditto for wash machine. You should never need to turn on cold water if your unit is set to proper temp at controller. Hope this helps
May 17, 2010 | Rheem Tankless Hot Water Heater...
Water not reaching proper tempreture before cutting out . it is only luke warm
What setting do you have the temp dial set at? The biggest problem I find on RV water heaters because they sit unused for long periods of time, are spider webs in the burner or dirt dauber nests restricting burners and not allowing it to fire properly, causing intermittent flame or flame outage.
May 15, 2010 | RTO Atwood Water Heater - 6 Gal LP
Power vent 50 gal tank flashing code 2-3
1. Turn off power vent blower and set water heater temp to vacation (lowest temp)
2. Turn on power vent blower
3. Turn the water heater temp from vacation (lowest temp) to hot (highest temp) four times.
4. Set the water heater temp to normal
Aug 21, 2009 | Rheem Water Heaters
VERY LITTLE WATER HEAT
What is the inlet temp of the water? If it is cold, your output will suffer. What is the flow into the unit? If it's too fast it doesn't have the proper time to heat the water to full temp. Is this gas or electric? Electric units have more issues than gas. If its electric, one of the elements could be bad. Check your breakers and make sure one of them hasn't tripped (electric). If it is gas, check that you have the correct temp set.
Apr 08, 2009 | Bosch PowerStar AE115 Tankless Water...
I want to increase the boiler temp by using the your aquastat
Warning! Can cause electrical shock! Here is the instruction manual
for L7248c
http://customer.honeywell.com/techlit/pdf/PackedLit/68-0281.pdf
Jan 12, 2009 | Water Heaters
Water Heaters Logo
65 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
