Microwave Ovens Logo
A
Anonymous Posted on Dec 30, 2013
T fal spice grinder - Microwave Ovens
Grinder does not work, makes unusual noise (quieter than usual)
Hello, Sandy -
Your question landed in the Fixya.com category for Microwave Ovens.
I am not aware of any microwave ovens with grinders. What are you REALLY asking about? A coffee grinder? A pepper grinder? What?
Plus, what is the make and model of your grinder?
You can choose Comment and add the missing details about your item so that I or some other volunteer answerer for Fixya can provide you with the proper information.
Best wishes.
Grinder appears to be grinding, but not ground coffee ends up in the basket. Metal door underneath the grinder is closed.
Empty grinder and chek nothing is stucking to the opening plate If not then replace the solenoid that open the shuter from where the coffee go to grinding chamber Thanks Please rate my work
I am trying to locate the user manual for the T-Fal Sensor 3215 pressure cooker. As i saw in a web posting it is old and T-Fal no longer makes pressures cookers. That person contacted T-Fal and request...
Hello boptimystic,
I understand you need the number to contact T-Fal. Here is the number and hours of operation:
Call us at 800-395-8325 or send us a note.
Call center hours are Monday to Friday 8:30am to 5:30pm
HOW DO I GET FILTER OUT WITHOUT YOUR TOOL. HOW SO I USE CLEANING TABLETS? AND GRINDER ONLY WORKS PERIODICALLY. MOSTLY BROWN WATER?
HOW DO I GET FILTER Problem with the Microwave Ovens HOW DO I GET FILTER OUT WITHOUT YOUR TOOL. HOW SO I USE CLEANING TABLETS? AND GRINDER ONLY WORKS PERIODICALLY. MOSTLY BROWN WATER?
I am a little confused as I don't ever remember a microwave oven with brown water a filter and cleaning tablets!
1helpful
Looking for a link to a user manual for a T-FAL 1656 iron.
You can get the manual on the link below. Scroll down to product detail then click on product manual.
http://www.amazon.com/T-Fal-1656-Ultraglide-Iron/dp/B000050AUS
Good Luck please rate 4 thumbs up and please leave a testimonial
Sunbeam 2774 Blender stopped working....Used to work good b4 but after i put some hard spices it stopped working after tht...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
I have lost the grinder knife for my kitchenetics Gourmet champ grinder.Where can I get a replacement
Hi, The company handles these as Blendtec now. The web site is at http://www.blendtec.com/default.aspx Maybe this will help:
Customer service and sales are available from 8:00 am to 5:30 pm (MST) M-F.
Phone
Toll Free: 800-253-6383
Local: 801-222-0888
Fax: 801-805-8585
2helpful
3answers
Jura E8 beans will not pass through grinder resulting in "Fill Beans" error message. Saw reference to Kaffeestudio.com for dissasembly instructions but that link no longer works. I assume that the chute...
It seems withthis model you have a 1 year or 4000 cups warranty with this.
If you are within this, then give them a call - here is the Manual if you don't have it -
MANUAL -
I suggest you start by removing the beans in the hopper and wiping around to remove oils.
Then refill with fresh dry beans.
Plug in and set up as normal
Set to brew a standard large cup - and adjust grinder to coarse setting while grinding.
Do not adjust with grinder quiet - it must be done while rotating.
Make at least 10 cups this way at the coarse setting.
I think what has happened is that damp beans (frozen or cold) have entered the unit and caused the coffee to gum up at the top of the burr.
This will just push fresh beans out of the way instead of starting to grind them.
If you use dry (light loast) beans, it doesn't seem to happen as much.
Just ake sure you refrigerate most of your stocks, but keep a small stock at room temperature in an airtight tin to prevent this kind of thing.
You can actually push down on the bean stack slightly with a wooden object while the grinder is running if nothing moves on the coarse setting to get things moving.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
