Question about Sunfire Audio Players & Recorders
Sunfire hrs-10 has recently started to hum
Hums regardless of setting
2 Suggested Answers
SOURCE: Sunfire MK II Subwoofer hum. I have a Sunfire MK
you have a ground loop issue you could purchase a ground loop isolator, jensen makes them for about 40 bucks.I have discovered that if you have cable tv, unplug the incoming cable in your cable box and see if hum disappears.
Posted on Nov 29, 2010
. You people are holy snap fast! .Concept 2 fridge freezer combo. The refrigerator and freezer cool/ no freezing. football thing in bck hums/hot. unplug it 4 24 hrs.? C brown liquid in back!!! !
if the compress is humming , indicates a problem start/run capacitor or a seized compressor unit
call a technician for a proper diagnosis and quote
Jul 07, 2017 | Refrigerators
My Frigidaire fex831fs4 washer motor hums but wont start.i took belt off.still hums no start even when timer is not set to run.if I close lid motor hums then kicks out then it trys again.thanks 4 help
I appreciate your post, Mike!
Based off what you have described your Frigidaire washer motor will hum and not start. In order to test each component you would need to have the proper electrical equipment. I would recommend contacting a professional technician for proper repairs. They will have the necessary equipment needed to complete your repair. Hopefully this is helpful. -Matt
Aug 31, 2015 | Frigidaire Dryers
Have a whirlpool washer that now hums when I turn the cycle on, no water just a hum
I had a similar problem - had to get a technician out - there was a valve at the back of the machine that allows the machine to fill. It had split (apparently its a common problem? there are separate valves for hot and cold water, so I'm not sure if using a different cycle choice (ie cold only), may let the machine fill?). 10 minute fix job
Jul 14, 2012 | Whirlpool Washing Machines
Sunfire MK II Subwoofer hum. I have a Sunfire MK II subwoofer that hums when it is plugged in (it even hums when no signal is connected). I've tried multiple outlets on different circuits, but hum...
Nov 25, 2010 | Sunfire True Sub MK II Subwoofer
Pump acts like it is froze up. It hums and smells like it is burning when it runs. It hums then shuts off, hums then shuts off?
Either you need a new start/run capacitor or the bearings have seized. If it's been running loudly recently, the bearings have probably seized. If not, the start capacitor is probably bad. This can sometimes happen when the motor windings start to develop a short. If you replace the capacitor and it blows again, you'll probably need a new motor.
Oct 22, 2010 | Waterway Executive 56 Spa Pump 3hp 2" 2spd...
Kenmore 80 series wash machine humming
you have a clogged pump
the pump is hooked directly to the motor if thats cogged the motor cannot move producing a humming sound
Oct 07, 2009 | Washing Machines
GE Dryer DWSR473GV0WW periodically just hums when turning on switch
might have a dead spot on the armuture or lint in the motor and or the centrifcal switch try taking it apart and cleaning the motor if that doesnt work replace the motor
Feb 14, 2008 | Dryers
A23 AMP
If the amp hums with just speakers connected and no inputs. The problem is internal and Parasound should take care of it under their usually prompt warr. service which is still in force. 5 months sound odd. Was your dealer getting it or was it direct? If not them connect one component at a time, add preamp next(nothing connected to it). If it hums them use a 3-2 ground lifter on the AC cord of the amp and do not connect the wire to the outlet screw. If not them connect each component. If you have cable very often this will cause hum even if you are not listening to cable sound. Use a ground isolator in line with the cable RF input.
Aug 11, 2007 | Parasound A 23 Amplifier
if it hums when you start it means switch is ok. problem may be the motor capacitor. to check, take off the top and give the drum a push in the normal direction of rotation. if it goes then motor capacitor is faulty - cheap part
Mar 28, 2007 | GE Profile DPSB619ED Electric Dryer
129 people viewed this question
Top Sunfire Audio Players & Recorders Experts
shaun taylor
woodzowl307
Joseph Hoffmann
Are you a Sunfire Audio Player and Recorder Expert? Answer questions, earn points and help others
