Question about Hussmann Freezer 12 Facing Straight Glass Front Ice Cream Dipping Cabinet - With Rear Storage Doors
Won't freeze after door was left open
I have a GE upright freezer the will not freeze food. It was working but the door was left open and now will not work.
  • 585 Answers
Having the door open has introduced an excess of humidity and therefore condensate/ice into the freezer coils. The coils are therefore iced over. You have choices depending upon your skill level. You might: allow the unit to sit unplugged with the door open until the excess ice thaws out and wets the floor underneath, which may take from 6 to 24 hours. You might: do this, adding some heat source in the freezer to accelerate the process. You might: locate the defrot timer, advancing the timer until a click is heard indicating the unit is in defrost, and repeat after about 15 minutes to defrost the unit with it's own heater. You might: let it recover just as it is but it will take a couple of days to clear itself.
Posted on May 19, 2009
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Freezer door left open will it work again?
yes it must be shut off and completely defrosted.with doors left open it usually takes about 2 days. what happened if you look at the back wall in the freezer from the inside you will see a bunch of ice and there is more behind that panel you are looking at. it froze up the coils so that no air will get through them. good luck rich
Sep 18, 2012 | GE 20.3 cu. ft. / 575 liter Upright...
We accidentally left our upright 20 cf frigidaire freezer door open for 24 hrs, all the food spoiled and now the freezer is not freezing and only cooling. Any ideas of what is wrong? thanks
THE UINT IS FROZE UP, YOU WILL NEED TO DEFROST IT. USE A FAN TO BLOW INTO THE FREEZER PORTION , AND HAVE LOTS OF BIG THIRSTY TOWELS HANDY .. THIS WILL TAKE ABOUT 2 HOURS TO DEFROST, WIPE EVERY THING INSIDE THE UNIT DRY !... JAY THE POOL PUMP MOTOR REPAIR GUY FLORIDA
Jul 28, 2011 | Frigidaire 20 cu. ft. / 566 liter Upright...
My ge upright freezer is getting cold, but it is not freezing the food
check the door is closing tight first,,if it is try turning the thermostat down a bit more,,if that dont work you may need a new thermostat fitted and maybe even a re-gas and a new compressor
how old is the freezer???
Aug 21, 2010 | GE 16.7 cu. ft. / 473 liter Upright...
Left my upright freezer open a crack and now the
With the door left open moisture would get into the unit behind the walls and into the duct work. The only way to fix this right is to unload it and let it unthaw for a day or so open. Once it is all defrosted and restarted it should be fine again.
May 09, 2010 | AEG 10.35 cu. ft. / 293 liter Upright...
Its not freezing!! keeping things cool, but not freezing
I would definitely start by checking if the fan is working. Note that the fan is switched off when you open the door, so you need to press the door switch and then check if it is working. If not, that will be the problem.
Apr 15, 2009 | Electrolux 3.53 cu. ft. / 100 liter...
Freezer defrosted and the motor won't start back up.
From what I can gather, you have a self defrosting freezer and the "motor" you speak of is the fan inside the freezer. If this is correct, do this:
Unplug freezer. Unload all food into coolers or other freezer space. Leave freezer door open for a day to allow it to manually defrost. Plug freezer back in after minimum 24 hours and confirm fan running and cooling before loading back up with food.
Mar 28, 2009 | GE 16.7 cu. ft. Upright Freezer FUF17DTR
GE 16.7 Upright Freezer
HI the heat on the outside of the cabinet is normal. the freezer is now working properly give it 24 hrs thanks.
Jul 17, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
1,546 people viewed this question
Top Hussmann Freezers Experts
Dennis Boxerman
jasbo
jasbo
John Tripp
John Tripp
Are you a Hussmann Freezer Expert? Answer questions, earn points and help others
