Question about EdgeStar BWC120SS (36 cu ft) Wine Cooler Beverage Cooler
Edgestar cwr300sz does not cool more than 50 degrees F
    Master:
  • EdgeStar Master
  • 487 Answers
This cooler's operating range is 40-65 F. If it is still in warranty contact the manufacturer. You could have a faulty thermostat. If so have it replaced.
Posted on Apr 02, 2015
How many BTU
This is rated at 1070 watts cooling. 1070 Watts cooling is 3650.9915473 BTU/Hr.
3650.9915473 BTU/Hr equals 0.30424929561 in Refrigeration tons....Pleazer Appliance...
Mar 08, 2015 | EdgeStar AP420HS Portable Air Conditioner
What is the high temperature range for the coolant
Your question isn't a simple black or white question, it's all relative to how many PSI is your radiator cap and what mixture of anti-freeze your running, and also, how old or new the anti-freeze (coolant) is.
The pressure cap on a cooling system is the key to raising the boiling point of the 50/50 mix of antifreeze and distilled water. For every pound of pressure cap rating the boiling of point of the above mixture raises 3 degrees. If you had plain water in your cooling system with a 15 pound pressure cap the water would boil @ 257 degrees. If you had a 50/50 mix of antifreeze and water the coolant would boil @ 265 degrees with a 15 pound cap. The boiling point would raise to 270 degrees if you had a 60% antifreeze mixture with a 15 pound cap. If you had a 70% mixture the boiling point would raise to 276 degrees.
Mar 11, 2014 | 1989 Cadillac Eldorado
Wine cooler not cool
Take a look at: https://edgestar.zendesk.com/hc/en-us/articles/200604529-My-beverage-cooler-is-not-cooling-below-50-degrees-How-do-I-get-the-temperature-lower-
May 11, 2013 | EdgeStar TWR181ES
Fridge side working but only cooling to 50 degrees
My 14 years old GE profile refrigerator keep cooling above 50 degrees and not going down to below 40 degrees. I did clean condenser coil and fans are running fine. I adjusted temperature control to maximum cold .Do you think it my be short of refrigerant?
Jun 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
EDGESTAR PORTABLE FREEZER IS NOT COOLING. Replaced three components. power to power supply but no power coming out to thermostat control
Usually the power cord connects to a terminal block.Follow the cord to the terminal block and see if it is pulled loose
Sep 15, 2010 | EdgeStar 1.4 cu. ft. Chest Freezer FP430
How far from floor should exhaust hose hole be made edgestar 12000
makes no difference, as long as the ducting is not kinked.
keep in mind heat rises
so obviously if you could dump the heat elsewhere, away from the area you are cooling, then it would not creep back up through the floor. If your flooring is well insulated it will not matter.
Oct 10, 2009 | EdgeStar Portable Air Conditioner Heater
Freezer cools to 10 degrees, refrigerator cools to 50 degrees
check if the fan is working and you are circulating air efficiently. You may check on the coils at the freezer if there are ice formation. I would suggest to have the ice melted by unplugging it and ensuring that all parts are ice free. Clean the unit while at it.
Jul 15, 2009 | Refrigerators
THERE'S NOT A PROBLEM I NEED YOUR OPINION
This EdgeStar 10,000 BTU portable air conditioner heats and cools for year round comfort and is recommended for room sizes up to 350 square feet. This slim and light superstar uses the latest technology to squeeze the most powerful cooling from the smallest possible package this 10,000 BTU portable air conditioner has a footprint of just over a square foot and is under 28andquot high! This portable air conditioner is the most powerful portable air conditioner in its class and size range and can bring down mid size rooms faster than competitor's models.
Dec 27, 2008 | EdgeStar Portable Air Conditioner Heater
Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Dec 24, 2007 | EdgeStar Portable Air Conditioner Heater
Cooling on and off
Behind the filter there should be a small metal tube that senses the temp. entering the unit sometime this is too close to the metal fins and sense the cold from the fins and not the air coming in. Make sure this is away from the fins and try a different temp. setting.And relocating the unit. These units tend to give off more heat that cooling because the hot air is returned to the inside of the room and not vented outside like window units.This is an  EdgeStar 12,000 BTU unit, correct?
Oct 22, 2007 | EdgeStar Portable Air Conditioner Heater
EdgeStar BWC120SS (36 cu ft) Wine Cooler Beverage Cooler Logo
89 people viewed this question
Top EdgeStar Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you an EdgeStar Refrigerator Expert? Answer questions, earn points and help others
