Question about Symbol LS2208-7AZK0100S Handheld
Turn off the beep on LS2208 - Symbol LS2208-7AZK0100S Handheld
My ls2208 scanner is intermittent
If the scanner decodes a barcode one time, but not another the first thing to check is the cable. If the scanner issues the power up beeps when the cable is wiggled, replace the cable. If you know the cable is not the issue send the scanner in to Motorola Solutions (call 800-653-5350) for repair. The LS2208 has a five year warranty. You can roughly estimate your warranty by looking at the date of manufacture on the label of the scanner which is just above the trigger.
Jul 16, 2014 | Symbol Computers & Internet
Scanner 'beeps' etc, but no output on the screen!?
there are a SDK you can try it, confirm that the you had installed the drive.
May 06, 2014 | Symbol LS2208 Handheld
I have LS2208 PS2 and Nothing is send to computer
have you tried swopping out the cable? If that doesnt work I would just buy a new device. These are cponsidered consumable scanners. When they faile they tend to get replaced because they are so cheap
Nov 24, 2011 | Symbol LS2208 Handheld
I cant instal ls2208
If you follow the included link, it will take you to the driver download page for the Symbol LS2208.
LS2208
Sep 28, 2009 | Symbol LS2208 Handheld
LS2208 scanner not returning for multiple scans
It sounds like you need to program a Tab after each scan. You will need to download the manual from www.motorola.com so you can access the setup bar codes.
May 27, 2009 | Symbol LS 2208 Barcode Scanner
4 beep error when scanning barcode
The four beep error is a communications error. Usually it indicates the scanne is not configured properly. If the scanner is connecting with the CBA-K01-S07PAR cable and you are using a PS/2 keyboard you should have scanned the IBM PC/AT barcode from Adobe page 56 of 342 of the LS2208 Product Reference Guide.
If you do not have a PS/2 keyboard attached and are using a USB to PS/2 adapter you should scan the IBM AT Notebook from that same page. If the scanner does not start working immediately you may have to reboot your system. If the scanner still does not work the CBA-U01-S07ZAR USB cable might be a better choice.
If you are not connecting with either of these cables and are still getting the four beep error a call to the Motorola support center may be in order. Their phone number is 800-653-5350.
Apr 14, 2009 | Symbol LS2208-7AZK0100S Handheld
Any way to lower the beep sound ...
this are all barcode to solve u r problem.......
please tell me how to set prefix /suffix values ?
i have already set scan prefix & scan sufix and then scan option ...
but did not get the< prfix ><data>< suffix> only data will retrive...
prfix value is `key, suffix value is Tab !
please help me
Feb 04, 2009 | Symbol LS2208 Handheld
LS2208
Symbol has confirmed that there was a batch of scanners sent out with defective lasers. Call them at 800-653-5350 for a replacement. Have the scanner handy to give them the serial number. They were very helpful.
Oct 06, 2008 | Symbol LS2208 Handheld
LS2208 keyboard Wedge only works with PC keyboard connected
one of the settings in the code book is to emulate keyboard function. turn this on and you do not need to have the keyboard plugged in
Sep 24, 2008 | Symbol LS2208 Handheld
Symbol LS2208-7AZK0100S Handheld Logo
336 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
