Question about Dell OptiPlex GX270 PC Desktop
Proper pin numbers to install inserts in a Dell SATA 34 pin GX270 motherboard
I am in need of a layout to install the Insert connections on the proper pins of a 34 pin Front Panel SATA Dell GX270 motherboard.
  • ibjohn268 May 20, 2009
    This is not about IDE or SATA. What I need is a diagram or layout showing the proper connections for a 34 pin FRONT PANEL.
    What are the pin numbers to connect power switch, HDD, reset, etc? -------------------Thank You
    Genius:
  • 1,605 Answers
Why do you need the IDE cable pin out if you are using SATA?
they are diiferent and not interchangeable. if you want to use IDE pin out for SATA, then you need to get a adapter from IDE to SATA.
Posted on May 19, 2009
  • Frank
    Frank May 20, 2009
    front panel connector from the motherboard is only 15pins.
    which connector are you looking at?
    picture would be helpful?
  • Frank
    Frank May 28, 2009
    what is this??
    I am asking you a question to determine what exactly you want to do, and I get a inappropriate rating???
    what is inappropriate about that?
    you don't give enough information for me to determine what is on your mind and what you want to do.
    Are you so illiterate you can express what is on you rmind??
Need wiring diagram for placement of the internal cables in Compaq Presario SR5410F
Top view photo of the motherboard, of an MSI MS-7525 motherboard made FOR HP by MSI, for a Compaq Presario SR5410F Desktop PC,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01386897&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3686678
Also scroll down the page, and click on the + sign to the left of -
Motherboard Layout.
A) 24-pin ATX main power cable:
In the photo, look to the right of the Blue ram memory slots.
The Yellowish/Whitish connector to the right of them, with two columns of 12 socket holes, is where the 24-pin ATX main power cable plugs in.
In the Motherboard Layout it is marked by - ATX1
This is a general example of a 24-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Note the middle photo, and the Lock on the side of the power cable's connector. The Lock has a hooked end that goes over a Tab, on the motherboard's connector.
The Lock works like a see-saw on a playground. The top is squeezed in, and this brings the hooked end away from the Tab, in order to remove the power cable.
When assured that the power cable is plugged in tightly, and therefore correctly, the hooked end of the Lock will be over the motherboard connector's Tab.
B) 4-pin ATX +12 Volt power cable:
In the center of the motherboard, under the Processor socket, is the Northbridge chip. (Part of the motherboard chipset)
It is under a finned aluminum Heatsink, that resembles a meat tenderizer's head.
Draw an imaginary line up above it, in-between the Processor socket, and the aluminum finned Heatsink, and go straight LEFT.
See the whitish 4-socket hole square connector?
In the Motherboard Layout it is marked by - JPW1
This is where the 4-pin ATX +12 Volt power cable plugs in. It is power for the Processor. Has the same locking setup as the 24-pin ATX main power cable, and it's motherboard connector.
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
C) In the Motherboard Layout to the top left corner of ram memory Slot 1, (DIMM1), is where the Processor fan connects.
CPU_FAN1
D) In the Motherboard Layout just below JPW1 is where the computer case fan plugs into. SYS_FAN1
E) In the Motherboard Layout - SATA1 - is where the SATA Harddrive data cable plugs into. (Below ram memory slots)
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
The SATA power cable from the power supply, plugs into the SATA harddrive. Note that the SATA power cable's connector, is longer in length than the SATA data cable's connector.
[SATA power cable has 15-pin. SATA data cable has 7-pins ]
Note that both cable's connectors, have an L-shape on the inside.
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
NOTE*
This is what a 4-pin standard Peripheral power cable looks like,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
IF, your SATA harddrive has a provision for a SATA power cable, AND a 4-pin standard Peripheral power cable, ONLY use just the SATA power cable!
Otherwise you will burn up the SATA harddrive. May not happen right away, but I assure you it will happen!
[ A note on SATA.
The beauty of SATA, is that you can plug into ANY SATA connector on the motherboard, and BIOS will see it.
If you plug the Harddrive into SATA 1, or SATA 2, or SATA 3, or SATA 4, connector on the motherboard, IT DOES NOT MATTER.
BIOS will find the Harddrive, or optical drive ]
The Front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
In the Motherboard Layout illustration, the Front Panel header is down at the Bottom/Right corner, and is marked - JFP1.
(Right in the very bottom/right corner is JUSB2. JFP1 is right above it)
JFP1. Junction Front Panel 1.
9-pin header. Black rectangle.
5 pins on the Right side, 4 pins on the Left side.
The pins are numbered EVEN on the LEFT side.
Starting on the BOTTOM going UP;
Pins 2, 4, 6, and 8. There is NO Pin 10.
The pins are numbered ODD on the RIGHT side.
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED.
(Light Emitting Diode, so it is a light )
Pin 1 is for the Positive ( + ) wire. If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. 5 Volt power, and reserved for the factory to use.
D) Pins 2 and 4 are for the Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 14, 2012 | HP COMPAQ Presario SR5410F Pentium...
I need to instal - raid driver-
1. put Motherboard Cd (come with p5rd1vm) in cd/dvd rom.
2. BIOS configure as boot from cdrom.
3. restart machine Motherboard CD boot with press enter
4. command line shows 4 option
5. Select 1st option for exact and proper copy ULi sata driver for winxp.
6. Insert floppy press enter
7.you see d copy procedure.
8.then this floppy insert when winxp setup asking F6 for additional driver.
Jun 17, 2011 | ASUS P5RD1-VM Motherboard
Any instructions on how to install the LG(GSA4167B)DVD RW super multi
turn off PC > open left side panel of the PC casing > remove drive slot in front of the case to insert the new one > You find two connectors, the data cable (IDE or SATA) and the power cable (MOLEX or SATA connector), you need to fix the proper data cable one end to the motherboard and the other one to the Drive Connect the proper power cable from the Power Supply Unit then you are good to go :) good luck
Jan 31, 2011 | LG (GSA4167BB) DVD RW Dual Layer Burner
My dell pc's sound system doesn't work, my computer tag number is optiplex GX270
This is a minor problem that can be fixed. Your sound card software or application might have been accidentally deleted so you will need to install a new one. If you still have your motherboard CD or the CD that came when you purchased this PC then insert it and search for the sound drivers. Or else, just download it from here and install.
Jun 26, 2010 | Dell OptiPlex GX270 PC Desktop
Can gx270 use SATA internal hard drive ?
1. You can refer to your device motherboard user manual to find it our if the SATA HDD is supported or not.
2. If you dont have motherboard manual, just remove the screws behind your computer and remove the cabinet side cover and look onto the motherboard inside it. If you find SATA slots, then you can use SATA HDDs in your machine.
3. If there is no SATA slots in your motherboard, you can still use a SATA HDD to your system by getting a PCI to SATA convertor card.
I Hope this is helpful to you
Thanks
Apr 27, 2010 | Dell OptiPlex GX270 PC Desktop
Psu
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
Dell GX270 SATA front panel 34 pin layout
if you are talking about connecting the front chassis connectors to your motherboard then you need to find out the exact model of the MB... im assuming its Intel since its a Dell.
the link below should get you started
http://www.intel.com/support/product.htm
Jun 01, 2009 | Dell OptiPlex GX270 PC Desktop
Hi there.
Get a strong flashlight and a magnifying glass (if you have one). On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW. On some boards there are no colours but the markings are the same, so take a good close look.
Have a look at these pictures for an idea >>>>>>
Please post back with the results and any more advice if needed.
Good luck and thanks for choosing FixYa!!
34 pin FRONT PANEL insert locations.
http://support.dell.com/support/edocs/systems/opgx270/en/ug/specs.htm
This link should open an html document from Dell, providing you with all the information you seek.
good luck
tony
May 20, 2009 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex GX270 PC Desktop Logo
572 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
