Question about Wacom Intuos3 6x11 Tablet PC
There doesn't seem to be any information on unplugging Intuos 3 from my computer usb port. Will I create any issues if I just reach over and unplug it while the computer is running or off?
How can i replace printer scrolling
Posted on Jul 13, 2010
My nextbook ares 10l keyboard stopped working
If your USB Keyboard stopped working, you can try to disconnect it and connect it back on the fly. USB connections are plug and play, so if you are running Windows and your USB keyboard doesn?t work, you can try unplugging and plugging it back to re-establish the communication, or simply try connecting it to another USB port. If this still doesn?t work, check the led lights on the keyboard; are any of them on? If they are, is the computer acting slowly? You may need to restart it at this point to refresh your computer memory and resources to get it back to normal speed, or perhaps it needs maintenance by running disk cleanup and defrag it
Nov 28, 2016 | Nextbook Tablets & eReaders
How do I connect the Irulu keyboard to my tablet, besides by plugging the mini usb into the port on the side? Because my tablet doesn't recognize, that it is even plugged in.
first of all, make sure that your tablet has an On the go USB port or data port if not, it can only be used to charge. If you connect our tablet to a computer usb port, and your computer recognises it, then you have a data port.
If you plug in a usb memory stick, and your computer can not read it, it does not have a USB to go port.
Also, some Cable adapters are On the Go wired, and may not work properly.
It may also be that the USB port is not providing enough power from the tablet to the keyboard. In that case, buy a split power usb cable, and plug the red (power only) into a usb charger or powered usb hub.
Apr 20, 2016 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
Ematic lp2p tablet doesn't recognize usb or pc
1 port is a mini hdmi port to connect to a tv via a hdmi mini to hdmi cable,the other is a mini usb port,with the data cable that you can buy for it,you can connect to a computer,not just any usb cable will work,there is 1 for charging and 1 for data Ematic Edan XL EGS109 9 Inch Tablet 5 ft USB 2 0 Mini Micro Cable
Apr 27, 2015 | Tablets & eReaders
Can i transfer my pictures from the gallery on my tablet to a flash drive
Yes, but it takes several steps to transfer pics from your tablet to a flash drive.
There are two ways of accessing tablet files: 1) wireless access which requires a sync app on your tablet and PC software of the same app type. One such app for sync between Android (any) to/from PC software is Cheetah Sync:
Alternatively, you can use ES File Explorer's Network/LAN/Cloud/FTP functions to share files between your Android phone/tablet and your PC via secure Wifi:
or 2) wired via the USB charging cable, which I will explain in more detail:
Plug your table to your PC using the Samsung charger cable that doubles as a data transfer cable when you remove the USB plug from the wall charger cube and plug it to the USB port on your PC.
Your PC should read your tablet as an external drive: Open "My Computer" and double-click the tablet drive icon>search your subfolders for your pictures. Highlight your picture files and either copy and paste or drag and drop (different way of copy/paste) to your desktop (or desired location), copies will be transferred but not moved from the tablet unless you "cut and paste" from your table to PC to clear out your tablet and make more space. When done, unplug your tablet cable from the PC. Plug in your flash drive to the available USB port: access the flash drive icon on My Computer. Drag and drop or copy and paste picture files to your flash drive.
Sep 24, 2014 | Samsung Tab Tablets & eReaders
Why usb not charging tablet
that could be one of many reasons, anywhere from the charging port in the tablet, to a faulty wire in the usb cable, to a defective power source such as your computer's usb port. provide more information for better assistance please
Jun 06, 2014 | Tablets & eReaders
Why my computer can't detect my galaxy tab
There's several things that could be the cause here. I'm going to assume that you're plugging the tablet into the PCs USB port with the standard charging/data cable that came with your tablet.
Easy Solutions:
  1. You might have a bad cable. Try a different cable, if you have one.
  2. Your USB port might be bad - try plugging into a different USB port. If you're plugged into the front of the PC, try the ones on the back. Also try plugging a different device into the USB port that you were having trouble with - does the other device work in that port? If so, your USB port is OK.
  3. Go into the Settings app on your tablet. Select Storage and tap the menu (three dots in the upper right corner). Select USB Computer Connection from the menu. There will be two choices here: Media Device (MTP) and Camera (PTP). Try unchecking whatever one is checked and checking the other one. Unplug your tablet and plug it back into the PC.
More Challenging Solutions:
  1. You might not have the proper drivers for your PC to recognize your tablet. Samsung makes a software package for your PC to communicate with your PC called Kies. You can download Kies here: Download it and install it. Then plug your tablet into your PC and it should find it.
  2. There are other ways to transfer files between your PC and your tablet, some of them are really easy, some not so much. The easiest is the Dropbox app. Download the app from the Google Play store - it is free. Create a free account and sign in. Then on your PC go to and download their free Windows program. Install it and sign in with the same account info that you used on your tablet. This creates a shared space out on the Internet. Anything that you put in your dropbox folder will automatically get put in your dropbox folder on your PC. On your tablet you can look at what is in the dropbox folder and choose whether or not you want to copy it to your tablet. You can also upload files from your tablet to the dropbox folder (automatically putting them on your PC).
  3. Another way to transfer things between your tablet and your PC is the AirDroid app. You can download it from the Google Play store - it is free. When you use it on your tablet, it will give you a web address on your local WiFi. Go over to your PC and open a browser, go to that address and you can communicate directly with your tablet over WiFi. You can copy files, add and delete thigns, and all sorts of other functions. AirDroid is very useful.
Jan 14, 2014 | Samsung Galaxy Tab Tablet PC
My Archos 101 tablet's full sized USB port doesn't acknowledge my stick drives. It did but now doesn't. I plugged a hub in and it lights up but the tablet still does not recognize the stick drive.
This seems to be a widespread problem with the Archos 101 tablet. There have been 2 firmware updates since the problem was first reported, and neither seems to have fixed the issue for anybody, which strongly suggests that it is a hardware issue, in which case you'll need to do an RMA. I recommend contacting the retailer you purchased through so you can get a replacement unit or a refund.
Feb 22, 2011 | Archos 101 Tablet PC
Scrolling problem?
Unplug usb, reinstall driver ,plug usb back. Or restart computer. I have the same annoying problem. It's the only solution i found.
It's nice having that kind of problem when clients are next to you, and you have to crawl under your desk to unplug the usb, and re-install everything. Makes it totally solvable.!
Hope they fix that problem with new drivers!!
Oct 19, 2007 | Wacom Intuos3 6x11 Tablet PC
Wacom Intuos3 6x11 Tablet PC Logo
Top Wacom Tablets & eReaders Experts
Are you a Wacom Tablet and eReader Expert? Answer questions, earn points and help others
