Question about Itouchless Electronic Pepper Mill and Salt Grinder
Sharper image pepper grinder assembly - Itouchless Electronic Pepper Mill and Salt Grinder
I bought a ssavore electric pepper grinder which arrived today. Unfortunately as soon as I put any pepper corns in it it stops working. It isn't strong enough to grind the pepper. I wish to return it. What...
If return instructions weren't included with the item or in the original advertising you should contact the retailer that supplied the item for return instructions as soon as possible.
Unless the pepper grinder was supplied on approval you will undoubtedly want a refund of the cost and so it should not be returned except to an address provided by the supplier.
Your contract is with the retailer (shop or organistaion) who is bound to provide an item that is fit for the intended purpose. A pepper grinder that isn't powerful enough to grind pepper clearly isn't.
Mar 03, 2015 | Coffee Makers & Espresso Machines
Salt and pepper grinders how to clean
warm soapy water, you can put some soapy water in the grinder, shaker and shake it vigorously to remove any pepper or salt that is stubborn, but hot water will dissolve the salt and loosen the pepper.
Sep 29, 2014 | Cuisinart Salt and Pepper Grinder,...
How do I fill with pepper
On most pepper mills, some part of the upper half usually unscrews, and the 'top' and 'bottom' can be separated. The bottom part will have a 'reservoir' in which the peppercorns should be placed, to eventually be ground.
Apr 05, 2014 | Bodum The Furniture Store Bistro Automatic...
I have an Alessi 9098 stainless steel pepper mill given as a wedding gift. It fell from a table and the blue fin broke. Is it possible to buy the blue fin? If so, how would I go about it?
Yes! you can get the part here:
http://www.connox.com/categories/spare-parts/replacements-alessi/spare-parts-alessi-pepper-grinder.html
Its 6 euro
Feb 06, 2013 | Alessi 9098 Pepper Mill
How to load peppercorns into trudeau 0716840
I found the following webpage on your grinder: www.shoptrudeau.com/v/vspfiles/images/instructions/0716840.pdf
Just in case the link doesn't work, it looks like the top (salt) part just pulls off the bottom, pepper grinder part. With the top off, there's a hole to pour the peppercorns into.
Jan 20, 2013 | Trudeau 0716840 Click Combo Pepper Mill...
How do I take care of my Olivier Roellinger pepper mill?
I found this link to their website and got some tips about cleaning and taking care of my pepper mill http://fantes.com/peugeot-pepper-salt.html
Jul 16, 2012 | Peugeot Olivier Roellinger Pepper Mill, 5...
Sharper image gravity activated pepper mill how to fill
Sharper Image gravity activated pepper mill, the top part of the clear chamber attached to the grinder selector twists off to the left. It is very stiff at first & feels like it is going to break. Just keep twisting it left and right until it loosens. After the first time, it becomes very easy.
Jun 11, 2012 | Air Purifiers
GEtting the pepper corns in?
go to their website,it should be on the box it came in,and go to customer support,there should be a section on the page for manuals and info.
Dec 06, 2008 | William Bounds Rita Stainless-Steel Mill...
Itouchless Electronic Pepper Mill and Salt Grinder Logo
225 people viewed this question
Top Itouchless Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Itouchless Kitchen Appliances - Other Expert? Answer questions, earn points and help others
