Question about Winter Sports
89 yamaha phazer only seems to run on the one cylinder, both plugs are good
2 Suggested Answers
  • 796 Answers
SOURCE: 1989 yamaha phazer
Do you know that the choke is there to be used until the engine has warmed up?, not just to start it?
Posted on Dec 15, 2013
I have a 1988 Yamaha Phazer 500 and it is not running on one cyl. Checked spark and good on both cyl and it has 130# of compression on both cyl
If spark and compression seemed good you may need to check the fuel. I would assume that cylinder has its own carburetor. Make sure it is working by spraying some starting fluid through the intake while the engine is running. If the cylinder starts firing you have a carb issue. The often gum up from storage or poor fuel.
Nov 29, 2015 | Cars & Trucks
Where find The codes for yamaha phazer 2007 ?
http://www.hardcoresledder.com/forums/364-phazer/503962-yamaha-phazer-error-codes.html
Mar 05, 2015 | Yamaha 2007 Phazer GT
Yamaha phazer I have a 1985 Phazer I just put together and am not sure what why the fuel lines go on. It has 4 lines going to it, One from each carb, one from the fuel tank and one from the engine
One should be from tank to fuel pump. Two from fuel pump to carbs. Two chokes, one on each carb at the top. Two wires to the harness. I suggest plugging them into each other at both ends. If the switch does not engage correctly, it cuts the engine. Plugging them into each other with fix that problem.
Jan 27, 2014 | Winter Sports
1989 yamaha phazer
Dec 15, 2013 | Winter Sports
Starts fine when push throttle it bogs down have to turn choke on to keep running but runs great wide open 1989 yamaha phazer
you probley have a weak coil it has enough power to start and run at low speeds but at high speeds the coil does not put out enough spark
I amtrying to hook up a moter from a 1993 yamaha
ditch the oiler on the sled cause they will fail. premix your fuel at 40:1 and never worry about it
Nov 21, 2009 | 1985 Yamaha XJ 700 X Maxim
Not runing
switch plug wires and see if the dead cylinder starts firing --if it does you need new wires
Nov 10, 2008 | 1985 Yamaha FZ 750 FN (Europe)
Winter Sports Logo
27 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
vtrktrmn
Are you a Winter Sport Expert? Answer questions, earn points and help others
