Question about Intermec EasyCoder 3400e Thermal Label Printer
Crinkled ribbon I have two Intermec 3400e's that have problems where they get a crease in the thermal ribbon which produces visible lines in the printed label. While it is possible that this is a problem with the ribbon we have been getting lately, I have a dozen other printers that are running fine. I would like to try realigning the rollers, but cannot find the necessary tools to do so.
  • nsondag May 28, 2009
    These 3400's offer very little adjustment for either.
  • 3 Answers
Try adjusting the head tension or ribbon tension.
Posted on May 19, 2009
  • mkersey May 28, 2009
    Crinkled ribbon can also be caused by heat or darkness settings being set too high. Try reducing the darkness to the lowest setting that still produces desirable output.
    You can see where it's creasing if you open the head mid-print.
    Also try the bias adjustment screw, that will help even out print pressure on the head as well.
ERROR: ribbon fitted (printer: intermec PX4i ) where and what needs to be changed in the settings?
TTR- Thermal transfer- set for using a ribbon. DT- Direct thermal - set when using thermal labels but no ribbon.
Sep 06, 2011 | Intermec EasyCoder® PX4i Label Printer
Yellow light is lit (Empty/Pause) but there is paper in printer.
I've found that if the ribbon core is slipping on the TTR supply hub, it causes the ribbon sensor to think the ribbon is not moving. This, in turn, causes the yellow light to come on. Take off the ribbon and replace hub core locking bracket (p/n: 065375-003). I have also found you can bend the bracket enough to work if you don't have any on hand. I hope this helps with your problem.
May 03, 2011 | Intermec 3400E Thermal Label Printer
Ribbon feeds out with label on the intermec easycoder PM4i
check setings Printer or Driver
(Direct -Thermal - labels without ribbon or Thermal transfer if use ribbon).
2nd solution install segull drivers (www.seagullscientific.com) and you can reset to factory defult if you need.
Oct 15, 2010 | Intermec EasyCoder PM4i Printer
The intermec is show a "ribbon fitted" error on the machines screen
its because the printer is setup Direct Thermal, and the sensor see ribbin present. need change setings.
May 21, 2010 | Intermec EasyCoder® PX4i Label Printer
Intermec 4400 printer fault. Ribbon fault. Looking for a service manual for this printer.
Ribbon fault when using Direct Thermal paper?? This one got me, too. Easy to correct, but issue was with driver & software from Intermec! To reset, go to OFFLINE READY, press MENU, Up/Down to OFFLINE CONFIGURATION, press SELECT, Up/Down to LABEL MEDIA TYPE, then SELECT, Up/Down to MEDIA TYPE DIRECT THERMAL, SELECT, ENTER and MENU out. To be sure, cycle power - and it works again.....
Oct 17, 2009 | Intermec EasyCoder 4400 Thermal Printer
Problem with Intermec 3400 ribbon supply
Just take the head of ink outside and clean it carfully and return it back it will work. use clean solution.
Apr 04, 2008 | Intermec EasyCoder 3400 Thermal Label...
Network Card
INTERMEC TECHNOLOGIES 72884
Internal EasyLAN Ethernet Card (for the 4420e, 4440e and 3400e)
Oct 22, 2007 | Computers & Internet
Intermec EasyCoder 3400e Thermal Label Printer Logo
336 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
