Question about JVC TH-C5 System
Won't come on
Tried to turn on my system this morning and would not come on. Where is the reset button
Fully charged. Why doesn't it turn on?
Ruby, try pressing and holding on button or you will have to reset.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reset Kindle Fire When it Won Turn on or Charge
My kindle won turn on
My kindle won turn on Is it the battery Kindle Fire HD
Amazon Kindle Won Charge Quick Fixes
Mar 12, 2016 | Amazon Kindle Fire HD
Why won;t my irulu 10.1.1 tablet turn on. i push the button and nothing happens, when charger is plugged in it gets warm both tablet and plug
It sounds like you've done most of the things you would reasonably be expected to do to make it function; since it is only 2 months old I would strongly urge you to go back to the retailer and make them replace it or refund you, as your rights in most countries/states allow.
If you're set against doing this, try holding down the power and volume down key for at least ten seconds to see if this boots it into hard reset mode. If this doesn't do anything, try again holding down power with each of the other buttons to see if you can activate any other developer/reset modes.
However, I have read reports that this particular tablet has up to a 40% failure rate in its first six months.
If you can possibly get it refunded, do that and buy something else.
Jan 02, 2015 | Irulu 10.1 inch Android 4.0 Touchscreen...
I can't get my Aztek Gear Shift button to press in. It is stuck in park. I have tried turning the key and it will turn but the button won't budge.
most likely it is ur brake pedal switch, it just behind the brake pedal arm, this switch must be triped by pushing the brake in order to shift into gear, if switch goes bad u cant shift. best of luck
Nov 05, 2012 | 2003 Pontiac Aztek
Dell Inspiron 530 won't start, CMOS
Sounds like the CMOS battery is dead. You will find this battery on the mother board. It is a round watch battery, pull it and take it to a store like Walmart to get a proper replacement. I bet if you check your system time, it is wrong too.
Feb 20, 2012 | Dell Inspiron 530 Desktop Computer
My coby kyros won't turn on, won't charge, no lights are coming on
Mine does that to but all I ever do it just hit the reset button on the back and it turns back on.
May 18, 2011 | Coby Kyros 716829701508 Tablet PC
I bought a Bose V35 2 weeks back. I played my system yesterday and switched off. Since this morning I am unable to switch on the system. Green light keeps blinking and I keep getting the message "iPod...
With this system being so recent from purchase you should return it to the store as it is faulty. DO Not Attempt to do any "Mr Fix It" type repairs as it will invalidate any warranty (standard is 12months from new in UK)
Jan 07, 2011 | Bose V35 Theater System
Light flashing and tv won't turn on
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
I can't turn on the TV.
I had the same problem. Unplugged it, reset it, everything. I went to work the next morning and left the light blinking, came home from work and it was off. I turned it on and so far, so good. Just give it some time to reset internally
Aug 26, 2007 | Mitsubishi WS-65613 65" Rear Projection...
JVC TH-C5 System Logo
37 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
