Question about Samsonite Photography
Torx screw what gauge on samsonite case - Samsonite Photography
4 Suggested Answers
  • 29 Answers
SOURCE: what is the torx size to remove the screws in the
The torx screws are only the first part of a delicate procedure. Once the screws are removed it still requires special tools etc to open the unit without damaging it. Once it is open there are very small and extremely fragile connectors that are easily destroyed if you try to disconnect them the wrong way. If there is a problem with your unit I highly recommend not trying to fix it yourself, it is well worth the $ to have it done by an expert. There are several post-warranty repair companies out there but the only one I recommend is www.sharcnet-usa.com.
Posted on Jan 10, 2010
small6363
  • 18394 Answers
SOURCE: polti 2400
you can buy T15 torx driver with hole in them from link below.
http://www.ebay.co.uk/itm/4-Stanley-T15-T20-With-Hole-Tamper-Proof-Torx-1-4-25mm-Long-Security-Drill-Bits-/220968573723?pt=UK_Hand_Tools_Equipment&hash=item3372c0db1b
Posted on Jul 28, 2012
mr_wizard05
SOURCE: opening a Toshiba MK8010GAH drive case - what size Torx bit?
I've had luck using a T4 Torx precision driver. Sometimes I strip one of the 5 screws out in opening it but you are right that the T5 is too big. I just put a lot of pressure on the screw.
Posted on Nov 26, 2012
How to set the valves on SV 600 KOHLER
Valve Gap IN .005 EX .007
With engine at TDC of compression stroke, insert correct size flat feeler gauge (see below) between appropriate valve stem and rocker arm. Tighten adjustment nut with a wrench until a slight drag is felt
on feeler gauge. Hold nut in position and torque set screw (T15 Torx drive) to 5.5 N·m (50 in. lb.). To prevent damage to nut, torque Torx screw only.
Perform same adjustment procedure on other valve.
May 02, 2015 | Garden
How do I adjust the valves on my courage 21 engine
This might be a little late...but this is from the service manual.
Perform adjustment procedure on other valve.
Clearance Specifications-Valve
Intake Valve 0.127 mm (0.005 in.)
Exhaust Valve 0.178 mm (0.007 in.)
Oct 19, 2014 | Husqvarna Garden
I have a 2002 yard machine by mtd.it has a 21 hp gt ohv year is 2002.dose any onr no the valdes seting??
I'm sorry to hear you spent money on parts that didn't get you started. I think your problem is you are in need of a valve adjustment. You will need a torx screw driver, a feeler gauge, and a 10mm wrench. Remove the valve cover and check the looseness of your rocker arms, you will have some. Place your feeler gauge at .004 thousandths , place torx screw driver into adjustment slot, and place 10mm wrench on nut to loosen hold. Tighten torx screw to were feeler gauge just feels snug between top of valve and rocker arm, tighten 10mm nut. Do his on both valves and your done. this is a common problem on overhead valve heads. GOOD LUCK FRIEND.
Sep 15, 2014 | Cars & Trucks
How to set tps on a 2001 gsxr 1
Step 1: Remove front seat
Step 2: Locate Dealer Mode connector, it resides just behind the battery, it is a white connector with a rubber cover on it, it has 5 or 6 wires going into it.
Step 3: Put bike in dealer mode, take a paper clip or a wire with two stripped ends and connect the two pins
To ensure the bike is in dealer mode, look at the gauges and the temperature should be replaced with "C00" and a little "-" next to the code, the "-" is what you will be observing while adjusting the throttle position sensor. There are three positions of the "-" (top, middle, bottom)
Step 4: Remove the right side fairing
Step 5: Locate the tamper proof torx screw
it's behind the cable bundle you see running along the top of the triangular hole in the frame
You can get the torx head screwdrivers needed for this screw at any auto parts store, just ask them where to find the tamper proof torx screwdrivers. I couldn't find my torx head driver, so I'm unsure of the proper size needed.
Step 6: VERY Slightly loosen the torx screw (the black plastic piece behind the torx screw is your TPS)
Step 7: Reach into the frame and grip the TPS and begin observing the "-" on the gauges. Adjust until the "-" JUST hits the top position. Find the point that it juggles back and forth between middle and top then move it up just far enough that it doesn't juggle anymore. VERY carefully tighten the screw, if you're not careful the TPS will move while you're tightening the screw.
Step 8: Remove paperclip or wire from dealer mode switch, and replace the rubber cap
Step 9: Re-assemble bike and ENJOY
Feb 23, 2013 | 2001 Suzuki GSX-R 1000
Opening a Toshiba MK8010GAH drive case - what size Torx bit?
May 07, 2012 | Apple iPod nano 5th Generation
HELP needed to open combinaiton lock
side latches of my samsonite brei case is open but cant get the combination lock to release
Jan 21, 2010 | Samsonite Case & Tripod Kit for Digital...
I do not know the combination of my samsonite hard case suitcase
I tried working through the series of possible numbers and at the same time gently pressing the lower part of the lock to see if it would open. After a while I used a claw hammer which I gently inserted the claw beneath the lower portion of the lock and again gently prised it and at first go the lock opened and no damage done that I can see. I have not reset the lock yet.
Oct 16, 2009 | Samsonite Tripod
I HAVE THE TSA COMBINATION LOCK ON A SAMSONITE GRAVITON G LUX
I can't answer the problem - but am interested as we had an identical failure on holiday in South Africa. We had to force the case open as the lock and the mechanism seemed to have come adrift in that when moving the lever with the correct combination - the case neither opened or closed. I'm sending it back to Samsonite under warranty to hopefully get it repaired/replaced. I rang the UK number listed on the Samsonite website. Bit disappointed as Samsonite should be more reliable - particularly given the price of the case, at £295, isn't exactly cheap.
Apr 11, 2009 | Samsonite Tripod
Adaptor for Samosonite Tripod
not sure about the brand tripod but all good ones have a 1/4 standard screw that has blank shoulder so it spins freely yet stays in place there..see your local pro camera store for a 'camera mounting screw'..... or order from samy's camera online
Dec 08, 2008 | Samsonite Case & Tripod Kit for Digital...
Suitcase number locked combination forgotten
f'lite Samsonite combination lost and stuck locked:
I removed the lock unfastening the 2 torx screws from the case.
Next I removed the pin that holds the RED tab thingy in place and the spring ( all this does is pushthe assembly to the right when a number is moved..... Take a picture of this before you dissassemble it. push it allthe way through..if you have fat fingers you are screwed. Anyway, remove the red thingy, and then carefully lift the remaining plate out taking note of the orientation.
First of all: the solution is aligning the cogs to 0-0-0 like from the factory. This is easy to do. when you remove the plate above , carefully do so without launching the dials and the spring into space....no matter.
Look at the bottom of the plate and notice there is a notch that will correspond to the cogs still in place on the lock assembly that should still be in place.
The cogs sit on a spring that sit on the backside of the dials with the numbers you can see when locking the suitcase.
Here is the meat:
1. with your finger or something turn the cogs until the black dot aligns outmost.
2 align the cogs so that notch will correspond to the orientation on the plate you just looked at. (that's it)!
Carefully replace the plate with finger pressure and actuate the latch-it should be unlocked and at the 0-0-0 position. If not repeat 1 and 2.
Push the pin through again, through the red thingy and the spring. BAMMM! you just saved your self a zillion dollars...still having trouble...mail this to me and for $15. I fix it for yaz....
May 13, 2008 | Samsonite Tripod
Photography Logo
Top Samsonite Photography Experts
ittco
Level 1 Expert
Are you a Samsonite Photography Expert? Answer questions, earn points and help others
